Home » Archived » BIRT » Problem when reading Chart from ReportDesignHandle
Problem when reading Chart from ReportDesignHandle [message #757445] Fri, 18 November 2011 08:23 Go to next message
I am trying to read a chart from a ReportDesignHandle based on the example from pp 325 in Integrating and Extending BIRT:
http://www.amazon.com/Integrating-Extending-BIRT-Jason-Weathersby/dp/0321580303
But after adding a chart dynamically I cannot read it from the ReportDesignHandle. Here is what I do:
    ReportDesignHandle report = BEngine.getEngine().createDesign();
    // Create dummy chart
    Chart dummyChart = getDummyChart();
    assertNotNull(dummyChart);
    // Embed dummy chart in an ExtendedItem
    ExtendedItemHandle chartHandle = report.getElementFactory().newExtendedItem(null, "Chart");
    try {
      chartHandle.getReportItem().setProperty("chart.instance", dummyChart);
    } catch (ExtendedElementException e) {
      e.printStackTrace();
    // Add ExtendedItem to report.... Is this the problem?
    try {
      report.getBody().add(chartHandle);
    } catch (ContentException e) {
    } catch (NameException e) {
    // Test that we can read the chart from the report
    Chart chart = null;
    List contents = report.getBody().getContents();
    for (Object object : contents) {
      if (object instanceof ListHandle) {
        // Never entered!
      if (object instanceof ExtendedItemHandle) {
        System.out.println("Ext Item found!");
        ExtendedItemHandle eih = (ExtendedItemHandle) object;
        chart = (Chart) eih.getProperty("chart.instance");
    assertNotNull(chart);
But the last line fails, the chart is null.
I simply want to add the chart to the body of the report and not the footer as described in the book. Should it not be ok to do:
If I save the report after adding it to the report and open it in the designer I see the chart in the design/body.
Any ideas?
Re: Problem when reading Chart from ReportDesignHandle [message #757457 is a reply to message #757445] Fri, 18 November 2011 08:58 Go to previous messageGo to next message
From the GroupOnYAxis example from org.eclipse.birt.chart.examples\src\org\eclipse\birt\chart\examples\api\data I see that the chart is read by first calling: getReportItem on the ExtendedItemHandle:
Chart cm = (Chart) eih.getReportItem().getProperty( "chart.instance" ); //$NON-NLS-1$
This seems to solve the problem, but is not how its described in the Birt book if anyone else is using this book as a reference.
Re: Problem when reading Chart from ReportDesignHandle [message #757836 is a reply to message #757445] Fri, 18 November 2011 12:21 Go to previous message
Is the code in this if executing?
BTW once you add a chart to the report you also need to setup bindings
to a dataset using the api as well.
Jason
> try {
> try {
> Chart chart = null;
> // Never entered!
> Any ideas?
Previous Topic:Avoid multiple sheets in excel using Tribix
Next Topic:Two Platforms
Current Time: Sat Jul 19 21:44:17 EDT 2025
Powered by FUDForum. Page generated in 0.04513 seconds
