Home » Archived » XML Schema Definition (XSD) » xsd import
xsd import [message #75587] Mon, 15 September 2008 03:12 Go to next message
hi,
To use the class XSDResourceImpl we need to add the plugin
dependency by adding the jar file(org.eclipse.xsd)
or some more settings are required ?Because each time i
access it ,it gives an error "The system cannot find the
path specified".What does it mean and how it can be removed
Re: xsd import [message #75621 is a reply to message #75587] Mon, 15 September 2008 08:01 Go to previous message
Gitanjali,
Comments below.
Gitanjali Punj wrote:
> hi,
Yes.
> Because each time i access it ,it gives an error "The system cannot
> find the path specified".What does it mean and how it can be removed
That's quite mysterious. Could you elaborate?
Re: xsd import [message #603289 is a reply to message #75587] Mon, 15 September 2008 08:01 Go to previous message
Gitanjali,
Comments below.
> hi,
Yes.
Previous Topic:xsd import
Next Topic:xsd import
Current Time: Sun Jul 20 10:03:04 EDT 2025
Powered by FUDForum. Page generated in 0.29269 seconds
