Home » Eclipse Projects » Eclipse Scout » Connection string not excepted by Scout
Connection string not excepted by Scout [message #756076] Thu, 10 November 2011 14:26 Go to next message
to make a connection with my MS SQLServer database I have to enter the following JDBCMappingName
protected String getConfiguredJdbcMappingName() {
return "jdbc:sqlserver://localhost:1433;databaseName=MY_DATABASE";
If I open the Scout Object Properties Editor on the SQLService I get an error in this editor "Unaccepted value"
It won't accept the semicolon ";" between the port number and the databaseName.
I am doing this in a wrong way or is the a bug.
Tried to use the database properties field for this but without succes.
Regards Bertin
Re: Connection string not excepted by Scout [message #756137 is a reply to message #756076] Fri, 11 November 2011 03:11 Go to previous messageGo to next message
This might be a Scout SDK error (in Scout Properties View for SQL services) -> please file a bug.
I assume your application works with this mapping name.
In case of a "conflict" between your code and the Scout Tools (Scout Properties View in this case), your code win. This "Unaccepted value" just indicates that scout SDK could not interpret your code to represent it in the view.
Re: Connection string not excepted by Scout [message #756145 is a reply to message #756137] Fri, 11 November 2011 03:49 Go to previous messageGo to next message
Bug is filed
Re: Connection string not excepted by Scout [message #756155 is a reply to message #756145] Fri, 11 November 2011 04:56 Go to previous message
@bertin
Thank you.
For traceability: add a link of the bug in the forum and vice versa. (When the bug is opened, discussion should take place in bugzilla, but it is not always the case)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=363560
Previous Topic:*.product and config.ini files
Next Topic:User specific session data form
Current Time: Sat Jul 19 20:12:24 EDT 2025
Powered by FUDForum. Page generated in 0.03618 seconds
