Problems with stupid model tutorial [message #745854] |
Sat, 22 October 2011 23:23  |
That looks like the last step of the StupidModel Tutorial is not reproduceable for me.
The link www.eclipse.org/amp/documentation/contents/Tutorials.html#Actions_Part_II
After i have performed described steps (create Rule, create Selection, Create Query Available, Create Query Within (with Bug Vision 4), Create interseption and create move, i have received next errors in console
Workflow interrupted. Reason: Couldn't load resource under /my.stupidmodel/My.metaabm : org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.metaabm.act.impl.AAllImpl@2548c3ac (label: (&) Available() Query Copy, ID: _And_AvailableQueryCopy)' is not legal. (/my.stupidmodel/My.metaabm, -1, -1)
And one more thing - i created Bug Rule exactly like Initialize action - Selection, Query Spatial Available, and Move - and it worked. But i'm not sure how to use interseption, looks like it doesnt work for me anyway.
Can somebody approve this behavior?
Eclipse 3.7.1 Indigo, AMP - nightly builds.
Re: Problems with stupid model tutorial [message #746788 is a reply to message #745854] |
Sun, 23 October 2011 14:10   |
Andrey wrote on Sat, 22 October 2011 23:23
Try renaming that node manually to something else. If you keep having problems, please attach the model to your message and I'll take a look at it.
Quote:And one more thing - i created Bug Rule exactly like Initialize action - Selection, Query Spatial Available, and Move - and it worked. But i'm not sure how to use interseption, looks like it doesnt work for me anyway.
Yes, it's a bit tricky. The thing to remember is that whenever you drag an action on top os another action, the drag target becomes the new parent for the dragged node. To make an Intersection (All), you'll just need to drag to the first parent node (e.g. "Neightbor") and then hold down the option key while you drag to the second parent node (e.g. "Available").
Re: Problems with stupid model tutorial [message #748886 is a reply to message #746788] |
Mon, 24 October 2011 19:56   |
little more precisely
according Stupid Model Tutorial I created Bug Rule, then created Selection->Select in Bug Rule (with empty agent). Then created Selection->Query (Spatial: Available) in Selection. Then created Selection->query(Spatial: within(Bug Vision)) in Selection. After this i have situation like on screen-1.png
Then i create intersection for first (Available, not Within) query, as described in tutorial - see screen-2.png
Now, as described in tutorial, i start to drag the itersection (with Control key pressed) and move it up to second query (Within (bug vision)), and drop - see screen-3.png
Now i add the move command to last intersection - see result on screen-4.png
After it i press save and receive next error - see screen-5.png (I marked errors by nubmers: #1, #2, #3, #4, #5 to list text for them below)
2 things more:
1) i tryed to press alt key, shift key and also tryed to press ctrl key after start dragging and before start draggin. looks like correct for me do it with pressed ctrl (nevermind for my platform when it was pressed - before start draggin or after)
2) i'm using ubuntu linux 10.10. I tryed also windows to make sure it is not linux specific behavior. Looks like Windows version reproduce the same problem for me - the same exception.
below are texts for exceptions.
exception #1
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.metaabm.act.impl.AAllImpl@3c61a8f3 (label: (&) Available() Query Copy, ID: _And_AvailableQueryCopy)' is not legal. (platform:/resource/my.stupidmodel/My.metaabm, -1, -1)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.metaabm.ide.MetaABMEditor.createModel(MetaABMEditor.java:927)
at org.metaabm.ide.MetaABMEditor.createPages(MetaABMEditor.java:1021)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
at org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAction(OpenActionGroup.java:133)
at org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAction(MainActionGroup.java:330)
at org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen(ResourceNavigator.java:787)
at org.eclipse.ui.views.navigator.ResourceNavigator$6.open(ResourceNavigator.java:499)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.metaabm.act.impl.AAllImpl@3c61a8f3 (label: (&) Available() Query Copy, ID: _And_AvailableQueryCopy)' is not legal. (platform:/resource/my.stupidmodel/My.metaabm, -1, -1)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2663)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1149)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHandler.java:1228)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endDocument(AbstractSAXParser.java:737)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:516)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:242)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1511)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1290)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
... 77 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.move(BasicEList.java:669)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.doMove(NotifyingListImpl.java:1335)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.move(NotifyingListImpl.java:1320)
at org.eclipse.emf.common.util.AbstractEList.move(AbstractEList.java:539)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1204)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2658)
... 93 more
exception #2
... 93 more
exception #3
exception #4
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.metaabm.act.impl.AMoveImpl@2f9b087d (label: Move Bug Copy, ID: moveBugCopy)' is not legal. (platform:/resource/my.stupidmodel/My.metaabm, -1, -1)
Caused by: java.lang.IndexOutOfBoundsException: targetIndex=0, size=0
at org.eclipse.emf.common.util.BasicEList.move(BasicEList.java:664)
... 93 more
exception #5
hope it will help.
Re: Problems with stupid model tutorial [message #757068 is a reply to message #756104] |
Wed, 16 November 2011 06:04  |
Hi again. Really thanks for the answer
Your advise was very usefull. I even think this way is little simpler then first one.
But i can not have it work anyway.
Now i have next problem: as fast as i add 2 queries and intersection, i have an error in my Bug.java:
public void bugRule() {
Object bugCopy = (Object) ((org.ascape.model.space.Discrete) getMy()
.getGrid2D().getSpace()).findRandomAvailable(
((org.ascape.model.CellOccupant) this).getHostCell(), null,
false, bugCopy.getMy().getBugVision());
if (bugCopy != null) {
error exactly at this line
Obviously, since bugCopy is Object, it doest have getMy() method. When i try to cast it to Bug, like this
((Bug)bugCopy).getMy().getBugVision()
it sure says me "bugCopy may be not initialized".
When i do next
(call getMy from currect bug) it looks like it works right and moving works too after it (with some corrections too).
So, after corrections code works and looks like works right. But i did not can have generated code to work right ever in case with intersection (without intersection, if BugRule is exactly like initialize, all works perfect).
Please, advise.
Currect project file is attached.
Attachment: My.metaabm
(Size: 7.88KB, Downloaded 600 times)
FUDForum. Page generated in 0.05839 seconds
