Home » Modeling » EMF » CDO timeout exception in 4.0 maintenance release.
CDO timeout exception in 4.0 maintenance release. [message #755995] |
Thu, 10 November 2011 07:36  |
Some time ago we had a timeout exception (stack trace below).
We solved it in CDO build:
4.0.100.v20110610-0736
Unfortunately with the current CDO 4.0 maintenance build
(http://www.eclipse.org/cdo/downloads/#maintenance_weekly) , this
problem krept back in. I am not sure what was exactly patched in the
build 4.0.100.v20110610-0736, and why it's not in the current
maintenance build.
I need to be on the maintenance build for another necessary path.
Christophe
osgi> [ERROR] java.util.concurrent.TimeoutException
org.eclipse.net4j.util.WrappedException:
at org.eclipse.net4j.util.WrappedException.wrap(WrappedException.java:51)
at
org.eclipse.net4j.signal.SignalProtocol.sendSetTimeout(SignalProtocol.java:496)
at
org.eclipse.net4j.signal.SignalProtocol.doAfterActivate(SignalProtocol.java:258)
at
org.eclipse.net4j.util.lifecycle.Lifecycle.deferredActivate(Lifecycle.java:234)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:76)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:99)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:89)
at
org.eclipse.spi.net4j.ChannelMultiplexer.initChannel(ChannelMultiplexer.java:213)
at org.eclipse.spi.net4j.Connector.initChannel(Connector.java:330)
at
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:142)
at
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:1)
at org.eclipse.net4j.signal.SignalProtocol.open(SignalProtocol.java:139)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.createProtocol(CDONet4jSessionImpl.java:191)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.openSession(CDONet4jSessionImpl.java:216)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.doActivate(CDONet4jSessionImpl.java:123)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:72)
at
org.eclipse.emf.internal.cdo.session.CDOSessionConfigurationImpl.openSession(CDOSessionConfigurationImpl.java:250)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurationImpl.openSession(CDONet4jSessionConfigurationImpl.java:98)
at
com.netxforge.netxstudio.data.cdo.CDODataProvider.openSession(CDODataProvider.java:178)
at
com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.initResources(ServerUtils.java:276)
at
com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.initialize(ServerUtils.java:272)
at
com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.access$0(ServerUtils.java:271)
at
com.netxforge.netxstudio.server.ServerUtils.initializeServer(ServerUtils.java:250)
at
com.netxforge.netxstudio.server.ServerUtils$ServerElementProcessor$1.notifyLifecycleEvent(ServerUtils.java:311)
at
org.eclipse.net4j.util.lifecycle.LifecycleEventAdapter.notifyEvent(LifecycleEventAdapter.java:30)
at org.eclipse.net4j.util.event.Notifier.fireEventSafe(Notifier.java:136)
at org.eclipse.net4j.util.event.Notifier.fireEvent(Notifier.java:100)
at
org.eclipse.net4j.util.lifecycle.Lifecycle.deferredActivate(Lifecycle.java:247)
at
at
at
org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:201)
at
org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:110)
at
org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:61)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
at java.lang.Thread.run(Thread.java:680)
Caused by: java.util.concurrent.TimeoutException
at
org.eclipse.net4j.util.io.IOTimeoutException.createTimeoutException(IOTimeoutException.java:46)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:255)
at
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:419)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:87)
at
org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:73)
at
org.eclipse.net4j.signal.SignalProtocol.sendSetTimeout(SignalProtocol.java:492)
.... 36 more
Caused by: org.eclipse.net4j.util.io.IOTimeoutException
at
org.eclipse.net4j.buffer.BufferInputStream.ensureBuffer(BufferInputStream.java:204)
at
org.eclipse.net4j.buffer.BufferInputStream.read(BufferInputStream.java:116)
at java.io.DataInputStream.readBoolean(DataInputStream.java:225)
at
org.eclipse.net4j.signal.SetTimeoutRequest.confirming(SetTimeoutRequest.java:48)
at
org.eclipse.net4j.signal.SetTimeoutRequest.confirming(SetTimeoutRequest.java:1)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:123)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:326)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:103)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:51)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
.... 40 more
!ENTRY org.eclipse.net4j.util 4 0 2011-11-08 14:09:25.414
!MESSAGE java.util.concurrent.TimeoutException
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
.... 36 more
at
at
at
at
at
at
Re: CDO timeout exception in 4.0 maintenance release. [message #756582 is a reply to message #756331] |
Mon, 14 November 2011 07:10   |
Hi Eike,
It seems that Christophe still has this issue with the latest maintenance build. Christophe, can you paste the code
which sets the timeout?
Also can you debug to see which timeout values are really used on the server? For example set a breakpoint in the
location where the exception is thrown, probably the timeout value is present there somewhere.
gr. Martin
On 11/12/2011 07:08 AM, Eike Stepper wrote:
> Hi Christophe,
> I think you've already been in touch with Martin Taal regarding this issue. Bug
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=350146 hasn't been fixed in any stream, yet.
> But this one has been fixed in both 4.1 and 4.0:
> 351264: Automatically send client-side protocol timeouts to server, as well
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=351264
> Does that help?
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> Am 10.11.2011 13:36, schrieb Christophe Bouhier:
>> Hi,
>> Unfortunately with the current CDO 4.0 maintenance build (http://www.eclipse.org/cdo/downloads/#maintenance_weekly) ,
>> this problem krept back in. I am not sure what was exactly patched in the build 4.0.100.v20110610-0736, and why it's
>> not in the current maintenance build.
>> Best regards,
>> Christophe
>> org.eclipse.net4j.util.WrappedException: java.util.concurrent.TimeoutException
>> at org.eclipse.net4j.signal.SignalProtocol.sendSetTimeout(SignalProtocol.java:496)
>> at org.eclipse.net4j.signal.SignalProtocol.doAfterActivate(SignalProtocol.java:258)
>> at org.eclipse.net4j.util.lifecycle.Lifecycle.deferredActivate(Lifecycle.java:234)
>> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:99)
>> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:89)
>> at org.eclipse.spi.net4j.ChannelMultiplexer.initChannel(ChannelMultiplexer.java:213)
>> at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:142)
>> at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:1)
>> at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.createProtocol(CDONet4jSessionImpl.java:191)
>> at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.openSession(CDONet4jSessionImpl.java:216)
>> at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.doActivate(CDONet4jSessionImpl.java:123)
>> at org.eclipse.emf.internal.cdo.session.CDOSessionConfigurationImpl.openSession(CDOSessionConfigurationImpl.java:250)
>> at
>> at com.netxforge.netxstudio.data.cdo.CDODataProvider.openSession(CDODataProvider.java:178)
>> at com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.initResources(ServerUtils.java:276)
>> at com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.initialize(ServerUtils.java:272)
>> at com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.access$0(ServerUtils.java:271)
>> at com.netxforge.netxstudio.server.ServerUtils.initializeServer(ServerUtils.java:250)
>> at com.netxforge.netxstudio.server.ServerUtils$ServerElementProcessor$1.notifyLifecycleEvent(ServerUtils.java:311)
>> at org.eclipse.net4j.util.lifecycle.LifecycleEventAdapter.notifyEvent(LifecycleEventAdapter.java:30)
>> at org.eclipse.net4j.util.lifecycle.Lifecycle.deferredActivate(Lifecycle.java:247)
>> at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:201)
>> at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:110)
>> at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
>> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
>> at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
>> at org.eclipse.net4j.util.io.IOTimeoutException.createTimeoutException(IOTimeoutException.java:46)
>> at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:419)
>> at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:87)
>> at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:73)
>> at org.eclipse.net4j.signal.SignalProtocol.sendSetTimeout(SignalProtocol.java:492)
>> ... 36 more
>> at org.eclipse.net4j.buffer.BufferInputStream.ensureBuffer(BufferInputStream.java:204)
>> at org.eclipse.net4j.buffer.BufferInputStream.read(BufferInputStream.java:116)
>> at org.eclipse.net4j.signal.SetTimeoutRequest.confirming(SetTimeoutRequest.java:48)
>> at org.eclipse.net4j.signal.SetTimeoutRequest.confirming(SetTimeoutRequest.java:1)
>> at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:123)
>> at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:103)
>> ... 40 more
>> !STACK 0
>> at
>> ... 36 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: CDO timeout exception in 4.0 maintenance release. [message #756584 is a reply to message #756582] |
Mon, 14 November 2011 07:16   |
Hi Eike, Martin,
This is where we set the timeout:
// Create configuration
final CDOSessionConfiguration sessionConfiguration = CDONet4jUtil
.createSessionConfiguration();
sessionConfiguration.setConnector(connector);
sessionConfiguration.setRepositoryName(REPO_NAME);
final IPasswordCredentialsProvider credentialsProvider = new
PasswordCredentialsProvider(
new PasswordCredentials(serverSideLogin,
serverSideLogin.toCharArray()));
sessionConfiguration.getAuthenticator().setCredentialsProvider(
credentialsProvider);
// set to a minute
sessionConfiguration.setSignalTimeout(IDataProvider.SIGNAL_TIME_OUT);
return sessionConfiguration;
The SIGNAL_TIME_OUT value is
public static final long SIGNAL_TIME_OUT = 60 * 1000;
Elsewhere we also set the Commit timeout:
((org.eclipse.emf.cdo.net4j.CDOSession.Options) cdoSession.options())
.setCommitTimeout(CDODataProvider.COMMIT_TIMEOUT);
public static final int COMMIT_TIMEOUT = 500; // seconds.
rgds Christophe.
On 14-11-11 13:10, Martin Taal wrote:
> Hi Eike,
> maintenance build. Christophe, can you paste the code which sets the
> timeout?
> server? For example set a breakpoint in the location where the exception
> gr. Martin
>> Hi Christophe,
>> issue. Bug
>> in any stream, yet.
>> well
>> Does that help?
>> Cheers
>> /Eike
>>> Hi,
>>> Best regards,
>>> Christophe
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 36 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 40 more
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 36 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: CDO timeout exception in 4.0 maintenance release. [message #756589 is a reply to message #756584] |
Mon, 14 November 2011 07:36   |
And do you have a change to debug into the cdo code, then you can see what timeout value is actually being used on the
server. This can provide some extra info I guess.
gr. Martin
On 11/14/2011 01:16 PM, Christophe Bouhier wrote:
> Hi Eike, Martin,
> final IPasswordCredentialsProvider credentialsProvider = new PasswordCredentialsProvider(
> // set to a minute
> rgds Christophe.
>> Hi Eike,
>> timeout?
>> gr. Martin
>>> Hi Christophe,
>>> issue. Bug
>>> in any stream, yet.
>>> well
>>> Does that help?
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> Best regards,
>>>> Christophe
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 36 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 40 more
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 36 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
The Netherlands
Re: CDO timeout exception in 4.0 maintenance release. [message #756593 is a reply to message #756589] |
Mon, 14 November 2011 08:17   |
> what timeout value is actually being used on the server. This can
Yes, I will provide this later.
rgds Christophe
> gr. Martin
>> Hi Eike, Martin,
>> // set to a minute
>> rgds Christophe.
>>> Hi Eike,
>>> timeout?
>>> gr. Martin
>>>> Hi Christophe,
>>>> issue. Bug
>>>> in any stream, yet.
>>>> well
>>>> Does that help?
>>>> Cheers
>>>> /Eike
>>>>> Hi,
>>>>> Best regards,
>>>>> Christophe
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 36 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 40 more
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 36 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: CDO timeout exception in 4.0 maintenance release. [message #756796 is a reply to message #756593] |
Tue, 15 November 2011 02:12   |
Hey Guys,
I'm with a customer this entire week but I will try to give feedback ASAP...
Cheers
/Eike
Am 14.11.2011 14:17, schrieb Christophe Bouhier:
> rgds Christophe
>> gr. Martin
>>> Hi Eike, Martin,
>>> // set to a minute
>>> rgds Christophe.
>>>> Hi Eike,
>>>> timeout?
>>>> gr. Martin
>>>>> Hi Christophe,
>>>>> issue. Bug
>>>>> in any stream, yet.
>>>>> well
>>>>> Does that help?
>>>>> Cheers
>>>>> /Eike
>>>>>> Hi,
>>>>>> Best regards,
>>>>>> Christophe
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 36 more
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 40 more
>>>>>> !STACK 0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 36 more
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: CDO timeout exception in 4.0 maintenance release. [message #756800 is a reply to message #756796] |
Tue, 15 November 2011 02:21   |
Am 15.11.2011 08:12, schrieb Eike Stepper:
> Hey Guys,
Oh, please submit a bugzilla to remind me!
> Cheers
> /Eike
>> rgds Christophe
>>> gr. Martin
>>>> Hi Eike, Martin,
>>>> // set to a minute
>>>> rgds Christophe.
>>>>> Hi Eike,
>>>>> timeout?
>>>>> gr. Martin
>>>>>> Hi Christophe,
>>>>>> issue. Bug
>>>>>> in any stream, yet.
>>>>>> well
>>>>>> Does that help?
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> Hi,
>>>>>>> Best regards,
>>>>>>> Christophe
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> ... 36 more
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> ... 40 more
>>>>>>> !STACK 0
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> ... 36 more
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
Re: CDO timeout exception in 4.0 maintenance release. [message #756818 is a reply to message #756800] |
Tue, 15 November 2011 04:24  |
>> Hey Guys,
>> ASAP...
Thanks, here is the bug ID.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=363784
>> Cheers
>> /Eike
>>> rgds Christophe
>>>> gr. Martin
>>>>> Hi Eike, Martin,
>>>>> // set to a minute
>>>>> rgds Christophe.
>>>>>> Hi Eike,
>>>>>> timeout?
>>>>>> exception
>>>>>> gr. Martin
>>>>>>> Hi Christophe,
>>>>>>> issue. Bug
>>>>>>> fixed
>>>>>>> in any stream, yet.
>>>>>>> server, as
>>>>>>> well
>>>>>>> Does that help?
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> Hi,
>>>>>>>> patched in
>>>>>>>> Best regards,
>>>>>>>> Christophe
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> ... 36 more
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> ... 40 more
>>>>>>>> !STACK 0
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> ... 36 more
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
Current Time: Sun Jul 20 12:10:50 EDT 2025
Powered by FUDForum. Page generated in 0.05751 seconds
