Home » Modeling » TMF (Xtext) » problem with 2.0->2.1 update
problem with 2.0->2.1 update [message #755708] Wed, 09 November 2011 06:05 Go to next message
could anyone help?
after updating to xtext 2.1 from 2.0 i get the following exception when running the mwe workflow for my language
0    [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering platform uri '/home/garyt/workspace3/cork'
318  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
321  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
333  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
333  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
1313 [main] ERROR ipse.xtext.generator.LanguageConfig  - [TransformationDiagnostic: null:204 Cannot find type for 'XBlockExpression'. (ErrorCode: NoSuchTypeAvailable)]
1316 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher  - Problems instantiating module uk.ac.leeds.nsxl2.cork.Cork: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: Problems instantiating module uk.ac.leeds.nsxl2.cork.Cork: java.lang.reflect.InvocationTargetException
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:90)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:73)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:64)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:55)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.reflect.InvocationTargetException
	at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:56)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:143)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:114)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalSwitch(Mwe2ExecutionEngine.java:66)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:142)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:80)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.create(Mwe2ExecutionEngine.java:62)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:88)
	... 5 more
Caused by: java.lang.reflect.InvocationTargetException
	at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:54)
	... 38 more
Caused by: java.lang.IllegalStateException: Problem parsing 'classpath:/uk/ac/leeds/nsxl2/cork/Cork.xtext':[TransformationDiagnostic: null:204 Cannot find type for 'XBlockExpression'. (ErrorCode: NoSuchTypeAvailable)]
	at org.eclipse.xtext.generator.LanguageConfig.setUri(LanguageConfig.java:185)
	... 43 more
i enclose the mwe workflow file and the xtext file
regards
gary
Re: problem with 2.0->2.1 update [message #755713 is a reply to message #755708] Wed, 09 November 2011 06:20 Go to previous messageGo to next message
Looks OK on first sight. Do you have a plugin dependency to org.eclipse.xtext.xbase?
Re: problem with 2.0->2.1 update [message #755721 is a reply to message #755708] Wed, 09 November 2011 06:38 Go to previous messageGo to next message
Hi Gary,
please make sure that you register the generated EPackage for Xbase in
the standalone setup of your workflow.
Sebastian
On 09.11.11 12:05, gary s thompson wrote:
> could anyone help?
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> ... 5 more
> ... 38 more
> ... 43 more
> regards
> gary
Re: problem with 2.0->2.1 update [message #755738 is a reply to message #755721] Wed, 09 November 2011 07:33 Go to previous messageGo to next message
Sebastian Zarnekow wrote on Wed, 09 November 2011 06:38
And how exactly do I do this?
Re: problem with 2.0->2.1 update [message #755745 is a reply to message #755738] Wed, 09 November 2011 08:07 Go to previous messageGo to next message
Simply add this line to the StandaloneSetup section:
registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
Re: problem with 2.0->2.1 update [message #755748 is a reply to message #755738] Wed, 09 November 2011 08:19 Go to previous messageGo to next message
See the docs.
http://www.eclipse.org/Xtext/documentation/2_1_0/020-grammar-language.php#package_declarations_3
Sebastian
Re: problem with 2.0->2.1 update [message #755772 is a reply to message #755748] Wed, 09 November 2011 09:44 Go to previous messageGo to next message
Thanks! The MWE2 workflow now runs flawlessly, but ...
I get two dozens of Java and Xtend errors (see attachment).
I am working with your (otherwise unmodified) domain model tutorial material in <git://github.com/szarnekow/Xtext-Workshop-Development-Workspace.git> as of 2011-07-05. Does it have any incompatibilities wrt Xtext 2.1?
[Updated on: Wed, 09 November 2011 10:30] by Moderator
Re: problem with 2.0-&amp;gt;2.1 update [message #755773 is a reply to message #755772] Wed, 09 November 2011 09:45 Go to previous messageGo to next message
[I'd delete this outdated and emptied message, if only I could.] Sad
[Updated on: Wed, 09 November 2011 10:35] by Moderator
Re: problem with 2.0-&amp;gt;2.1 update [message #757116 is a reply to message #755773] Wed, 16 November 2011 10:00 Go to previous messageGo to next message
many thanks for the various suggestions! I have been able to eliminate the previous error by carry out the following steps
1. updating the explicit version numbers asccociated with the xtext imports in the MANIFEST.MF file
2. adding registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
however I still have a problem, I now get the following exception while building with mwe
319  [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage'
780  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
783  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
795  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
795  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
2133 [main] INFO  ipse.emf.mwe.utils.DirectoryCleaner  - Cleaning /home/garyt/workspace3/cork/uk.ac.leeds.nsxl2.cork/../uk.ac.leeds.nsxl2.cork/src-gen
2362 [main] INFO  ipse.emf.mwe.utils.DirectoryCleaner  - Cleaning /home/garyt/workspace3/cork/uk.ac.leeds.nsxl2.cork/../uk.ac.leeds.nsxl2.cork.ui/src-gen
2863 [main] INFO  ipse.xtext.generator.LanguageConfig  - generating infrastructure for uk.ac.leeds.nsxl2.cork.Cork with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, ParseTreeConstructorFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, Ecore2XtextValueConverterServiceFragment, JavaValidatorFragment, ImportURIScopingFragment, SimpleNamesFragment, FormatterFragment, LabelProviderFragment, OutlineTreeProviderFragment, QuickOutlineFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment, CompareFragment, BuilderIntegrationFragment, QuickfixProviderFragment, TypesGeneratorFragment, XbaseGeneratorFragment
6876 [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.cork.nsxl2.leeds.ac.uk/cork/Cork' from 'platform:/resource/uk.ac.leeds.nsxl2.cork/src-gen/uk/ac/leeds/nsxl2/cork/Cork.genmodel'
32615 [main] INFO  or.validation.JavaValidatorFragment  - generating Java-based EValidator API
39654 [main] INFO  text.generator.junit.Junit4Fragment  - generating Compare Framework infrastructure
39773 [main] ERROR g.eclipse.xtext.generator.Generator  - Cannot override final binding 'final org.eclipse.xtext.naming.IQualifiedNameProvider -> org.eclipse.xtext.naming.SimpleNameProvider (contributed by org.eclipse.xtext.generator.exporting.SimpleNamesFragment)'
java.lang.IllegalStateException: Cannot override final binding 'final org.eclipse.xtext.naming.IQualifiedNameProvider -> org.eclipse.xtext.naming.SimpleNameProvider (contributed by org.eclipse.xtext.generator.exporting.SimpleNamesFragment)'
	at org.eclipse.xtext.generator.CompositeGeneratorFragment.internalGetGuiceBindings(CompositeGeneratorFragment.java:170)
	at org.eclipse.xtext.generator.CompositeGeneratorFragment.getGuiceBindingsRt(CompositeGeneratorFragment.java:124)
	at org.eclipse.xtext.generator.Generator.generateGuiceModuleRt(Generator.java:334)
	at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:127)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
	at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
	at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
	at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:97)
39774 [main] INFO  .emf.mwe2.runtime.workflow.Workflow  - Done.
Also as a comment I have read about mwe in the documentation. However, I am still not sure what options and fragments I need in the mwe file. Whats more is there an overall document of what the available fragments are?
one again may thanks for any help
regards
gary
Re: problem with 2.0-&amp;gt;2.1 update [message #757149 is a reply to message #757116] Wed, 16 November 2011 13:52 Go to previous messageGo to next message
As for your direct problem: https://bugs.eclipse.org/bugs/show_bug.cgi?id=362655
You can use this as a workaround: https://github.com/dslmeinte/LessCss/blob/master/nl.dslmeinte.xtext.css/src/nl/dslmeinte/xtext/CorrectedSimpleNamesFragment.java
Re: problem with 2.0-&amp;gt;2.1 update [message #819897 is a reply to message #757149] Tue, 13 March 2012 09:12 Go to previous message
The correct URL for CorrectedSimpleNamesFragment is https://github.com/dslmeinte/LessCss/blob/c72ffb6d2a66703ad5001847e8ba83342856c791/nl.dslmeinte.xtext.css/src/nl/dslmeinte/xtext/css/CorrectedSimpleNamesFragment.java
but it doesn't work with Xtext 2.0 Sad Even when I enable it in my mwe2 instead of
fragment = exporting.SimpleNamesFragment {}
I still get the same error as before:
java.lang.IllegalStateException: Cannot override final binding 'final org.eclipse.xtext.naming.IQualifiedNameProvider -> org.eclipse.xtext.naming.SimpleNameProvider (contributed by com.avanon.eclipse.i18n_dsl.scoping.CorrectedSimpleNamesFragment)'
Previous Topic:importURI and importNamespace
Next Topic:Helping Xtext to resolve cross references across several files
Current Time: Sun Jul 20 10:05:06 EDT 2025
Powered by FUDForum. Page generated in 0.91670 seconds
