Gemini JPA] predeploy Exception [message #755481] |
Tue, 08 November 2011 10:59  |
Hi All,
On App startup, if Entity X in bundle A extends Entity Y in bundle B and bundle A depends on bundle B I get NullPointerException (s.below). It's happened only at startup. After all bundles are loaded, and I create my own EntityManager - everything is fine. If All Entities are in the same bundle is everything fine too.
Any ideas how to make it correctly ?
osgi> EclipseLinkProvider starting...
GeminiServicesUtil registering provider service for org.eclipse.persistence.jpa.PersistenceProvider
GeminiServicesUtil successfully registered provider service for org.eclipse.persistence.jpa.PersistenceProvider
GeminiExtender listening
GeminiExtender looking at existing bundles:
javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [puTest] failed.
Internal Exception: java.lang.NullPointerException
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1385)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.callPredeploy(JPAInitializer.java:98)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.initPersistenceUnits(JPAInitializer.java:306)
at org.eclipse.gemini.jpa.provider.GeminiOSGiInitializer.initializeFromBundle(GeminiOSGiInitializer.java:119)
at org.eclipse.gemini.jpa.provider.EclipseLinkOSGiProvider.assignPersistenceUnitsInBundle(EclipseLinkOSGiProvider.java:191)
at org.eclipse.gemini.jpa.PersistenceBundleExtender.tryAssigningPersistenceUnitsInBundle(PersistenceBundleExtender.java:172)
at org.eclipse.gemini.jpa.PersistenceBundleExtender.bundleChanged(PersistenceBundleExtender.java:314)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1569)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1505)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1500)
at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.processDelta(PackageAdminImpl.java:487)
at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.doResolveBundles(PackageAdminImpl.java:253)
at org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1.run(PackageAdminImpl.java:173)
at java.lang.Thread.run(Thread.java:680)
Caused by: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:221)
... 17 more
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.discoverMappedSuperclassesAndInheritanceParents(EntityAccessor.java:241)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.preProcess(EntityAccessor.java:514)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage1(MetadataProject.java:1590)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:517)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:526)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1320)
... 16 more
for example:
bundle A:
@Entity
public class X extends Y{
private String name;
public String getName() {
return name;
public void setName(String name) {
this.name = name;
bundle B:
@MappedSuperclass
public class Y {
@Id
protected long id;
public long getId() {
return id;
public void setId(long id) {
this.id = id;
FUDForum. Page generated in 0.04415 seconds
