Home » Language IDEs » PHP Development Tools (PDT) » Shotcut Shift + F2 (PHP Manual) not working(I can not use the PHP Manual (opened by the shortcut Shift + F2))
Shotcut Shift + F2 (PHP Manual) not working [message #755213] Mon, 07 November 2011 12:05 Go to next message
Hallo everyone,
I'm very new in the Forum.
I develop in PHP and I started using the Eclipse PDT.
I installed the Helios Service Release 2 (Build id : 20110218-0911) on Windows 7 and I'm locally using the Free edition of Zend Server (the Community edition).
Everything is working but the PHP Manual inside the editor.
I discovered the possibility (because I saw it on a colleague's machine) to open the PHP Manual with the topic of what I'm pointing with my cursor with the shortcut "Shift + F2" ... but on my Eclipse it does not work.
I already checked The "Windows/Preferences/PHP/PHP Manual" option and I've got "php.net" set there.
I also checked the Key Assist (Ctrl + Shift + L) and on the command "Open Manual" I've got the Binding combination "Shift + F2".
Eaven so ... it does not work.
Is there someone that can help on this.
Thanks a lot.
Re: Shotcut Shift + F2 (PHP Manual) not working [message #755290 is a reply to message #755213] Mon, 07 November 2011 18:08 Go to previous messageGo to next message
right click on the project,
menu: configure->add php support
see if that helps
Re: Shotcut Shift + F2 (PHP Manual) not working [message #755354 is a reply to message #755290] Tue, 08 November 2011 03:53 Go to previous message
Thank you for your answer Ben.
I tried but that menu option is disabled (see the picture), is there something I shoul do to get it enabled ?
Thanks again
  • Attachment: snap001.jpg
    (Size: 284.83KB, Downloaded 574 times)
Previous Topic:Syntax error using goto
Next Topic:[HELP - BUG???] Syntax Coloring Doesn't Work on eclipse-php 3.0.2.v201102768 on x86 Debian Squeeze
Current Time: Sun Nov 02 06:28:48 EST 2025
Powered by FUDForum. Page generated in 0.45971 seconds
