[ATL] Atl plugin problem ecore with referenced ecore [message #755012] |
Sun, 06 November 2011 14:15  |
i've followed this two topics (http://www.eclipse.org/forums/index.php/t/217023/ and http://www.eclipse.org/forums/index.php/mv/msg/214674/686524/#msg_686524) but when i put the correct path of my two metamodel (IN and OUT metamodels) i receive these errors:
Resource for org.eclipse.emf.ecore.impl.EClassImpl@3af42ad0 (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@2bd1e730 (eProxyURI: exp.ecore#//OpaqueExpression) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@1505bd58 (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@16df1832 (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@704f459c (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@409cb0f4 (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@44d3db51 (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@9d7fbfb (eProxyURI: exp.ecore#//OpaqueExpression) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@39e57e8f (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@8888e6c (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@4839e5b5 (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
Resource for org.eclipse.emf.ecore.impl.EClassImpl@671381e7 (eProxyURI: named.ecore#//NamedElement) is null; cannot be referenced
org.eclipse.m2m.atl.core.ATLCoreException: Error loading /home/nino/eclipse/mngr2ctxmngr/source/manager1.mngr: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'name' not found. (file:///home/nino/eclipse/mngr2ctxmngr/source/manager1.mngr, 3, 126)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:70)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:84)
at mngr2ctxmngr.ATLplugin.files.Mngr2ctxmngr.loadModels(Mngr2ctxmngr.java:132)
at mngr2ctxmngr.ATLplugin.files.Mngr2ctxmngr.main(Mngr2ctxmngr.java:86)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'name' not found. (file:///home/nino/eclipse/mngr2ctxmngr/source/manager1.mngr, 3, 126)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:65)
... 3 more
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'name' not found. (file:///home/nino/eclipse/mngr2ctxmngr/source/manager1.mngr, 3, 126)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeature(XMLHandler.java:1991)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeature(XMLHandler.java:1955)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.handleUnknownFeature(XMIHandler.java:151)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2709)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:80)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2193)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFeatureType(XMLHandler.java:2159)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2035)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:134)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1840)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1023)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:501)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumentParser.java:179)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(XMLNSDocumentScannerImpl.java:377)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2755)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:140)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:242)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1511)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1290)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
... 5 more
I think problem is that my two ecore file loads other ecore files as resource and use elements defined there. The atl plugin didn't see them. there is any way to solve this problem?
[Updated on: Sun, 06 November 2011 14:19] by Moderator
Re: [ATL] Atl plugin problem ecore with referenced ecore [message #755190 is a reply to message #755182] |
Mon, 07 November 2011 11:10   |
Ok! i've recreated the atl plugin and in wizard when it ask to select in and out metamodel i selected "browse" button and i chose from registred metamodel my two metamodel and now eProxyUri problem is solved but i've another error:
Metamodel contains several classifiers with same name: Element
org.eclipse.m2m.atl.engine.emfvm.VMException: mngr.impl.ManagerStateImpl
at __applyRoot#38(mngr2ctxmngrND.atl[15:4-15:58])
local variables: self=mngr2ctxmngrND : ASMModule, link=TransientLink {rule = Root, sourceElements = {i2 = mngr.impl.ManagerImpl@4b142196 (name: null, qualifiedName: null), i1 = mngr.impl.ManagerImpl@362f0d54 (name: null, qualifiedName: null)}, targetElements = {o = ctxmngr.impl.ContextManagerImpl@25961581 (name: null, qualifiedName: null)}, variables = {}}, i1=IN1!<unnamed>, i2=IN2!<unnamed>, o=OUT!<unnamed>
at __exec__#8(mngr2ctxmngrND.atl)
local variables: self=mngr2ctxmngrND : ASMModule, e=TransientLink {rule = Root, sourceElements = {i2 = mngr.impl.ManagerImpl@4b142196 (name: null, qualifiedName: null), i1 = mngr.impl.ManagerImpl@362f0d54 (name: null, qualifiedName: null)}, targetElements = {o = ctxmngr.impl.ContextManagerImpl@25961581 (name: null, qualifiedName: null)}, variables = {}}
at main#24(mngr2ctxmngrND.atl)
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.adapter.EMFModelAdapter.set(EMFModelAdapter.java:684)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:474)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:388)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:208)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch(EMFVMLauncher.java:139)
at mngr2ctxmngr.atlplugin.files.Mngr2ctxmngr.doMngr2ctxmngr(Mngr2ctxmngr.java:179)
at mngr2ctxmngr.atlplugin.files.Mngr2ctxmngr.main(Mngr2ctxmngr.java:88)
Caused by: java.lang.ArrayStoreException: mngr.impl.ManagerStateImpl
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.java:124)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList.java:424)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUnique(NotifyingListImpl.java:331)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:315)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:307)
at org.eclipse.m2m.atl.engine.emfvm.adapter.EMFModelAdapter.set(EMFModelAdapter.java:615)
... 8 more
FUDForum. Page generated in 0.04353 seconds
