Home » Archived » Libra » "OSGI Bundle" facet should requires "Java" facet
"OSGI Bundle" facet should requires "Java" facet [message #754999] Sun, 06 November 2011 10:16 Go to next message
On Eclipse Indigo, I have tried to create a Faceted Project with the
"OSGI Bundle" Facet but get the following exception :
at
org.eclipse.jdt.internal.core.JavaElement.newNotPresentException(JavaElement.java:495)
at
org.eclipse.jdt.internal.core.JavaModelManager.getPerProjectInfoCheckExistence(JavaModelManager.java:2305)
at
org.eclipse.jdt.internal.core.JavaProject.getPerProjectInfo(JavaProject.java:1890)
at
org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspath(JavaProject.java:1940)
at
org.eclipse.jdt.internal.core.JavaProject.getAllPackageFragmentRoots(JavaProject.java:1413)
at
org.eclipse.jdt.internal.core.JavaProject.getAllPackageFragmentRoots(JavaProject.java:1408)
at
org.eclipse.libra.facet.OSGiBundleFacetInstallDelegate.getJavaSourceFolderPaths(OSGiBundleFacetInstallDelegate.java:320)
at
org.eclipse.libra.facet.OSGiBundleFacetInstallDelegate.getBundleClasspath(OSGiBundleFacetInstallDelegate.java:287)
at
org.eclipse.libra.facet.OSGiBundleFacetInstallDelegate.createBundleProjectDescription(OSGiBundleFacetInstallDelegate.java:134)
at
org.eclipse.libra.facet.OSGiBundleFacetInstallDelegate.doExecute(OSGiBundleFacetInstallDelegate.java:83)
at
org.eclipse.libra.facet.OSGiBundleFacetInstallDelegate.execute(OSGiBundleFacetInstallDelegate.java:76)
at
org.eclipse.wst.common.project.facet.core.internal.FacetedProject.callDelegate(FacetedProject.java:1477)
because the created project must have the java nature but doesn't have
then I conclude that the "Java" facet is required.
Attached a fix.
Best Regards.
  • Attachment: fix.patch
    (Size: 0.94KB, Downloaded 350 times)
Re: "OSGI Bundle" facet should requires "Java" facet [message #755968 is a reply to message #754999] Thu, 10 November 2011 05:58 Go to previous message
Hi Esteban,
Thank you for reporting this issue.
This is a bug that needs to be fixed. However, we don't want to enforce the OSGi facet to require the Java facet, because OSGi can be used also outside the context of Java. So, instead introducing such requirement, it would be better to make the code tolerant to the condition if the Java facet is not selected.
I've created a bug in Bugzilla to track the issue: https://bugs.eclipse.org/bugs/show_bug.cgi?id=363452
Kaloyan
Previous Topic:[WAR Product] Validation issue for classes provided by the application server
Next Topic:by using eclipse wtp3.3 create WAR product configuration,export war file,one error occurs
Current Time: Sun Jul 20 02:28:39 EDT 2025
Powered by FUDForum. Page generated in 0.03085 seconds
