Home » Newcomers » Newcomers » ClassCastException:java.util.ArrayList cannot be cast to
ClassCastException:java.util.ArrayList cannot be cast to [message #754789] Fri, 04 November 2011 07:14 Go to next message
Hi folks,
Can somebody help me with this?
I am getting the following notification when I run my program in Eclipse:
Exception in thread "main" java.lang.ClassCastException: java.util.ArrayList cannot be cast to ie.ds.personApp.Person
at ie.ds.personApp.CrecheApp.searchPerson(CrecheApp.java:206)
at ie.ds.personApp.CrecheApp.main(CrecheApp.java:294)
It relates to the following line:
if(((Person) crecheArray).getFirstname().equalsIgnoreCase(firstname.getText())&&
in this method:
public void searchPerson(List<Person> crecheArray)
String PersonRecord = "";
String s0 = "First name:";
String s1 = "Surname:";
JTextField firstname = new JTextField("");
JTextField surname = new JTextField("");
Object message[] = new Object[4];
message[0] = s0;
message[1] = firstname;
message[2] = s1;
message[3] = surname;
JOptionPane.showConfirmDialog(null, message, "Search records",
JOptionPane.OK_CANCEL_OPTION, JOptionPane.QUESTION_MESSAGE,blankIcon);
//for(int i=0;i<count;i++)
// if(crecheArray[i].getFirstname().equalsIgnoreCase(firstname.getText())&&
// crecheArray[i].getLastname().equalsIgnoreCase(surname.getText()))
// childRecord+=crecheArray[i];
int i = 0;
for(Person registered:crecheArray)
((List<Person>) crecheArray).get(i).getSurname().equalsIgnoreCase(surname.getText()))
PersonRecord+=crecheArray.get(i);
else
if(PersonRecord=="")
JOptionPane.showMessageDialog(null,"No Matching Records Found");
else
JOptionPane.showMessageDialog(null,PersonRecord,"Matching Records",JOptionPane.INFORMATION_MESSAGE);
Any help is much appreciated..
Re: ClassCastException:java.util.ArrayList cannot be cast to [message #754942 is a reply to message #754789] Sat, 05 November 2011 12:01 Go to previous messageGo to next message
On 11/04/2011 06:14 AM, noviceEclipse wrote:
> Hi folks,
> if(((Person)
> in this method:
> message[0] = s0;
> message[2] = s1;
> int i = 0;
> if(((Person)
> ((List<Person>)
> else
> else
This forum is for Eclipse specific questions. You asking a general Java
question. You should ask on a general Java forum.
Re: ClassCastException:java.util.ArrayList cannot be cast to [message #754958 is a reply to message #754789] Sat, 05 November 2011 16:58 Go to previous messageGo to next message
On 2011.11.04 5:14, noviceEclipse wrote:
> Hi folks,
>[snip]
I'd personally suggest JavaRanch.com or stackoverflow.com.
Re: ClassCastException:java.util.ArrayList cannot be cast to [message #754976 is a reply to message #754958] Sun, 06 November 2011 04:40 Go to previous message
And if you do so, I suggest to post code that nicely conforms to the
"Code Conventions for the Java Programming Language" [1] as it is more
pleasant to read which drastically increases your chance for an answer.
[1] http://www.oracle.com/technetwork/java/codeconv-138413.html
Michael
Previous Topic:UnsupportedOperationException
Next Topic:The jar file cannot be exported into itself
Current Time: Sun Jul 20 15:11:58 EDT 2025
Powered by FUDForum. Page generated in 0.08191 seconds
