Custom popupDialog: is this the right way to do id? [message #754711] |
Thu, 03 November 2011 19:40 |
I need to show a dialog with a "content assist look and feel", but my
eclipse rcp rich client application doesn't have any editor.. The dialog
is shown on a mousehover event... it's like a tooltip, but it contains a
custom composite with a tree or a table, and it must have the focus and
resizing management like a content assist popupDialog.
I did a new class like the one below, but the question is: maybe I am
using the wrong tool, or using it the wrong way... are there any ways to
use popupDialogs better than I did?
I didn't find any documentation on this topic... When this task will be
completed, I'll surely write a little tutorial!
Thank you in advance!
This is the class:
package it.rcpvision.project.popupdialogs;
import it.rcpvision.project.Model;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.jface.dialogs.PopupDialog;
import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.FocusEvent;
import org.eclipse.swt.events.FocusListener;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.ui.PlatformUI;
import org.eclipse.wb.swt.SWTResourceManager;
public class CustomPopupDialog extends PopupDialog {
public static final int POPUP_MAXIMUM_WIDTH = 400;
public static final int POPUP_MINIMUM_HEIGHT = 300;
private Model model;
private Point location;
private Composite dialogArea;
public CustomPopupDialog(Shell parent, Model model, Point location) {
super(parent, INFOPOPUP_SHELLSTYLE, true, false, false, false, false,
model.getTitle(), null);
this.model = model;
this.location = location;
protected Control createDialogArea(Composite parent) {
dialogArea = (Composite) super.createDialogArea(parent);
applyBackgroundColor(SWTResourceManager.getColor(SWT.COLOR_LIST_BACKGROUND),
dialogArea);
CustomizedComposite customComposite = new
CustomizedComposite(dialogArea, SWT.NONE);
GridDataFactory.fillDefaults().applyTo(customComposite);
return dialogArea;
protected void adjustBounds() {
super.adjustBounds();
Shell shell = this.getShell();
Rectangle displayBounds =
PlatformUI.getWorkbench().getDisplay().getBounds();
int popupWidth = POPUP_MAXIMUM_WIDTH;
int dialogAreaHeight = dialogArea.getClientArea().height;
int popupHeight = dialogAreaHeight < POPUP_MINIMUM_HEIGHT ?
POPUP_MINIMUM_HEIGHT : dialogAreaHeight;
if (popupWidth + location.x > displayBounds.width){
location.x = location.x - popupWidth;
if (popupHeight + location.y > displayBounds.height) {
location.y = location.y - popupHeight;
Rectangle popupDialogBounds = new Rectangle(location.x, location.y,
popupWidth, popupHeight);
shell.setBounds(popupDialogBounds);
shell);
shell.setBackgroundMode(SWT.INHERIT_FORCE);
Lorenzo Murrocu
Eclispe Developer
http://www.rcp-vision.com/
FUDForum. Page generated in 0.02374 seconds
