Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] EMap Table not created
[Teneo] EMap Table not created [message #754552] Thu, 03 November 2011 05:12 Go to next message
ciao Martin
I just modeled an EMap as described here: http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_create_a_Map_in_EMF.3F
The reduced model is attached.
If I set the option "teneo.mapping.emap_as_true_map" to false, a reference table is created and I can store objects. If I don't set the option, no table at all is created and I can't store any objects.
Could this be a bug? I'm using the latest build: 1.2.0.v201111021608
Could the options be responsible?
<property name="hibernateProperties">
	<props>
		<prop key="hibernate.ejb.metamodel.generation">disabled</prop>
		<prop key="hibernate.transaction.auto_close_session">true</prop>
		<prop key="hibernate.transaction.flush_before_completion">true</prop>
		<prop key="hibernate.temp.use_jdbc_metadata_defaults">false</prop>
		<prop key="hibernate.hbm2ddl.auto">update</prop>
		<prop key="hibernate.jdbc.batch_size">2000</prop>
		<prop key="hibernate.cache.use_query_cache">false</prop>
		<prop key="hibernate.cache.use_second_level_cache">false</prop>
		<prop key="javax.persistence.transactionType">JTA</prop>
		<prop key="hibernate.transaction.manager_lookup_class">com.softmodeler.server.persistence.SoftmodelerTransactionManagerLookup</prop>
	</props>
</property>
<property name="persistenceProperties">
	<props>
		<!-- <prop key="teneo.mapping.emap_as_true_map">false</prop> -->
		<prop key="teneo.naming.default_id_feature">id</prop>
		<prop key="teneo.mapping.always_version">false</prop>
		<prop key="teneo.mapping.inheritance">TABLE_PER_CLASS</prop>
		<prop key="teneo.mapping.disable_econtainer">true</prop>
		<prop key="teneo.mapping.cascade_policy_on_non_containment">REFRESH</prop>
		<prop key="teneo.mapping.fetch_containment_eagerly">true</prop>
		<prop key="teneo.naming.sql_fk_name_prefix">fk_</prop>
	</props>
</property>
greets
Flavio
Re: [Teneo] EMap Table not created [message #754560 is a reply to message #754552] Thu, 03 November 2011 05:46 Go to previous messageGo to next message
He Flavio,
Before I try out the ecore model myself, do you see any hibernate errors/warnings when the database model gets created?
My feel is that there is something wrong with the ddl, otherwise you would see a table being created.
gr. Martin
On 11/03/2011 10:12 AM, Flavio Donze wrote:
> ciao Martin
> <props>
> </props>
> </property>
> <props>
> <!--<prop key="teneo.mapping.emap_as_true_map">false</prop> -->
> </props>
> </property>
> greets
> Flavio
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] EMap Table not created [message #754567 is a reply to message #754560] Thu, 03 November 2011 06:27 Go to previous messageGo to next message
Hi Martin
Thanks for the quick reply, your feeling was right! I didn't notice the errors:
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - Unsuccessful: create table [printtemplateset_templates] ([printtemplateset_templates_id] nvarchar(255) null, elt nvarchar(255) null, idx nvarchar(255) not null, primary key ([printtemplateset_templates_id], idx))
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - Eine PRIMARY KEY-Einschränkung kann für eine Spalte in der printtemplateset_templates-Tabelle, die NULL zulässt, nicht definiert werden.
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - Unsuccessful: alter table [printtemplateset_templates] add constraint FK9F785CD5A2AE9180 foreign key ([printtemplateset_templates_id]) references [printtemplateset]
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - Das printtemplateset_templates-Objekt wurde nicht gefunden, weil es nicht vorhanden ist oder Sie nicht über die entsprechenden Berechtigungen verfügen.
Did I model something wrong?
Re: [Teneo] EMap Table not created [message #754575 is a reply to message #754567] Thu, 03 November 2011 06:58 Go to previous messageGo to next message
I am afraid that you need to help me with the translation..
Can you summarize what the error is?
gr. Martin
On 11/03/2011 11:27 AM, Flavio Donze wrote:
> Hi Martin
The Netherlands
Re: [Teneo] EMap Table not created [message #754585 is a reply to message #754575] Thu, 03 November 2011 07:57 Go to previous messageGo to next message
Hi Martin
Sorry I had somehow in mind that you were German.
DE: Eine PRIMARY KEY-Einschränkung kann für eine Spalte in der printtemplateset_templates-Tabelle, die NULL zulässt, nicht definiert werden.
EN: A PRIMARY KEY-restriction can not be set on a column (that allows NULL) in the printtemplateset_templates-table.
DE : Das printtemplateset_templates-Objekt wurde nicht gefunden, weil es nicht vorhanden ist oder Sie nicht über die entsprechenden Berechtigungen verfügen.
EN: The printtemplateset_templates-Object was not found, because it does not exist or you don't have the according access privileges.
Does that make sense?
Re: [Teneo] EMap Table not created [message #754596 is a reply to message #754585] Thu, 03 November 2011 09:02 Go to previous messageGo to next message
Strange, which database is it?
Can you post some of the hbm (related to the emap) to see if it somehow is wrong?
gr. Martin
On 11/03/2011 12:57 PM, Flavio Donze wrote:
> Hi Martin
> access privileges.
The Netherlands
Re: [Teneo] EMap Table not created [message #754617 is a reply to message #754596] Thu, 03 November 2011 10:25 Go to previous messageGo to next message
Hi Martin
Here my setup:
SQL Server 2008 R2
Hibernate 3.6.2
I believe this is the part:
	<union-subclass name="com.softmodeler.model.impl.PrintTemplateSetImpl" entity-name="PrintTemplateSet" abstract="false" lazy="false" extends="BasicObject" table="`printtemplateset`">
		<meta attribute="eclassName" inherit="false">PrintTemplateSet</meta>
		<meta attribute="epackage" inherit="false">http:///www.softmodeler.com/model/softmodeler/1.0.0</meta>
		<property name="name" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
			<column not-null="false" unique="false" name="`name`"/>
		</property>
		<map name="templates" lazy="false" cascade="all,delete-orphan">
			<key update="true">
				<column name="`printtemplateset_templates_id`" not-null="false" unique="false"/>
			</key>
			<map-key type="java.lang.String"/>
			<element type="java.lang.String"/>
		</map>
	</union-subclass>
greets
Flavio
Re: [Teneo] EMap Table not created [message #754626 is a reply to message #754617] Thu, 03 November 2011 12:01 Go to previous messageGo to next message
Hi Flavio,
The problematic part is this one:
not-null="false" seems indeed strange for a key column.
The current code explicitly sets it to nullable, I removed that code and am doing a rebuild.
This is the related issue I entered for it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=362812
gr. Martin
On 11/03/2011 03:25 PM, Flavio Donze wrote:
> Hi Martin
> Here my setup:
> SQL Server 2008 R2
> Hibernate 3.6.2
> </property>
> <key update="true">
> </key>
> </map>
> </union-subclass>
> greets
> Flavio
The Netherlands
Re: [Teneo] EMap Table not created [message #754632 is a reply to message #754626] Thu, 03 November 2011 12:48 Go to previous messageGo to next message
The new build has been published, let me know if it solves it for you.
gr. Martin
On 11/03/2011 05:01 PM, Martin Taal wrote:
> Hi Flavio,
> gr. Martin
>> Hi Martin
>> Here my setup:
>> SQL Server 2008 R2
>> Hibernate 3.6.2
>> </property>
>> <key update="true">
>> </key>
>> </map>
>> </union-subclass>
>> greets
>> Flavio
The Netherlands
Re: [Teneo] EMap Table not created [message #754757 is a reply to message #754632] Fri, 04 November 2011 04:37 Go to previous message
Hi Martin
This solves the issue, table is being created and I can store objects.
Thanks a lot!
Flavio
Previous Topic:[Announce] Texo generates JPA Annotated Source Code
Next Topic:export from xml to EMF possibilities
Current Time: Sun Jul 20 08:35:41 EDT 2025
Powered by FUDForum. Page generated in 0.05523 seconds
