Home » Archived » DSDP - Real-Time Software Components (RTSC) » new XML(...) error
new XML(...) error [message #754458] Wed, 02 November 2011 11:20 Go to next message
The following xs script has stopped was working with release 3_20_08_88
but does not work with release 3_22_01_21. I get the following error :
line 6: TypeError: The processing instruction target matching
"[xX][mM][lL]" is not allowed.
Line 6 is the one with new XML ...
Here is the script:
* ======== main ========
function main(args)
var build = new XML(readFile("package/package.bld.xml"));
var pkg = build.@name;
print("packageName=" + pkg);
var makefiles = build.makefiles.srcFile;
for (var i in makefiles)
var tmp = makefiles[i].@name;
var pos = tmp.lastIndexOf(".mak");
if (pos!=-1 && (tmp!="package.mak"))
goal = tmp.substring(0,pos);
print("buildGoal=" + goal);
var releases = build.releases.release;
for (var i in releases) {
print("releaseGoal=" + releases[i].@pname);
* ======== readFile ========
function readFile(fileName)
var ins = new java.io.BufferedReader(new java.io.FileReader(fileName));
var outs = new java.io.StringWriter();
var nextLine;
while ((nextLine = ins.readLine()) != null)
outs.write(nextLine);
outs.write("\n");
outs.flush();
return (outs.toString());
main(arguments);
Re: new XML(...) error [message #754479 is a reply to message #754458] Wed, 02 November 2011 13:07 Go to previous messageGo to next message
The cause is a bug in Rhino support for E4X:
https://bugzilla.mozilla.org/show_bug.cgi?id=336551
We have a workaround in xdc.loadXML(), so you should try:
var build = xdc.loadXML("package/package.bld.xml");
When you use new XML(), you are using the E4X support directly.
Re: new XML(...) error [message #762060 is a reply to message #754479] Wed, 07 December 2011 08:50 Go to previous message
it works. Thanks.
From : Sasha Slijepcevic <forums-noreply@eclipse.org>
Date : Wed Nov 02 2011 18:07:25 GMT+0100 (CET)
Previous Topic:excludeDirs not working when creating a release
Next Topic:How to add pre-built library to RTSC-ed one ?
Current Time: Sat Jul 19 23:08:01 EDT 2025
Powered by FUDForum. Page generated in 0.23232 seconds
