Home » Language IDEs » Java Development Tools (JDT) » How to distinguish UI / non-UI thread in eclipse development
How to distinguish UI / non-UI thread in eclipse development [message #753957] |
Mon, 31 October 2011 04:05  |
[If this is the wrong place to ask the following question, please kindly guide me to the right place. It may be more related to general eclipse plugin questions]
As we know that, Invalid Thread Access is one of the most frequent bugs in eclipse plugins. Specially, if an UI element is touched by a non-UI thread, an SWTException: invalid thread exception will be thrown. Here is a typical example in JDT: https://bugs.eclipse.org/bugs/show_bug.cgi?id=125868
So, my question is that when writing or modifying eclipse plugin, how can I know the current code will be invoked by UI-thread or not? For the above example, how could I know in advance that "org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)" will be invoked by non-UI thread? If I have a clear view of that, such bug can be avoided. I often encounter such bugs when modifying eclipse plugins, so really would like to receive suggestion and guidance.
A more general question is that: how eclipse framework initialize plugin classes, and invoke its methods? which classes will be invoked by UI thread, and which one will be invoked by non-UI thread? is that specified in xml file?
Thanks a lot, any suggest is highly appreciated.
-Sai
Re: How to distinguish UI / non-UI thread in eclipse development [message #754080 is a reply to message #753975] |
Mon, 31 October 2011 12:48   |
Thanks Deepak for your reply.
I am still a little bit confused at "how to identify UI thread from source code", i.e., given the source code of JDT, is it possible to tell which chuck of code is executed by UI thread, and which chuck of code (e.g., class, method) *may be* executed non-UI thread. (even not 100% precise). Since that error is so common, I even plan to write an automated program analysis tool to identify this potential errors (i.e., report all cases that a non-UI thread touches a UI element). So, would like to know your suggestion.
I entirely agree that UI thread is the thread that creates 'Display'. So, could I understand it in this way: all eclipse UI extensions (e.g., views, dialogs) are created by UI threads? and non-UI threads are spawned from UI thread to handle additional events?
For the confirmed JDT bug:
However, seems that through the whole stack trace, there is no "thread.start()" method. so, where does the non-UI thread come from? Did the eclipse framework spawn a non-UI thread for it? (which is not shown in the stack trace?)
Thanks a lot. Any suggestion are highly appreciated. I really would like to understand this problem.
-Sai
Deepak Azad wrote on Mon, 31 October 2011 06:15UI thread is the thread that creates the 'Display' i.e. the 'main'
thread (the thread which has the name 'main').
Create a breakpoint in the piece of code you want to know runs in UI
thread or not and then try to hit that breakpoint. You will know from
the Debug view if the code is being executed in 'main' thread or not.
Re: How to distinguish UI / non-UI thread in eclipse development [message #754084 is a reply to message #754080] |
Mon, 31 October 2011 13:02   |
More precisely, last stack trace shows:
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Class Worker extends the Thread, and is invoked from anywhere else (invoking its run method). I am wondering How could I know which thread (and class) creates the Work object, and start the Worker thread?
-Sai
Sai wrote on Mon, 31 October 2011 12:48Thanks Deepak for your reply.
-Sai
Re: How to distinguish UI / non-UI thread in eclipse development [message #754166 is a reply to message #754140] |
Tue, 01 November 2011 03:09   |
Thanks Deepak for your quick reply.
Yes, that is exactly what I am going to try, figuring out from where
run() is invoked, and report potential Invalid Thread bugs. We now trying
to use a few static analysis (e.g., call graph, points-to, data-flow) techniques
to fulfill this goal. (hopefully, we can get acceptable results. If so, we
would like to contribute the built tool to the eclipse community, since this
error is so common and hard to prevent).
Following the previous thread, I am still a little bit confused on the following
few points:
1. The Worker class that extends Thread, seems to be the de facto "thread" class in eclipse. To avoid invalid thread access problem, a Worker object that touches UI element should only be invoked by UI-thread, or wrapping UI operations using "Display.asyncExec/syncExec", right? In that sense, why does "where does Thread/Worker objects are created, and been started from another place" matter? As long as the UI operations in Worker/thread are wrapped by "Display.asyncExec/syncExec", that is fine. I do not have extensive experience in hacking eclipse, so can be wrong. Please correct me. Thank you.
2. Following 1., how could I identify code that will be executed in a non-UI thread. Can I assume that the extension points (e.g., a view, a dialog) are invoked by eclipse's UI thread? and other threads that are spawned from the extension points are non-UI thread? Or, is it possible that an extension point can be invoked by a non-thread also? I am not sure on this point.
Thank you very much, really appreciate your help.
Deepak Azad wrote on Mon, 31 October 2011 23:20On 10/31/2011 10:32 PM, Sai wrote:
Theoretically you should be able to analyze the code, e.g. search
references to the Thread/Worker and then figure out from where run() is
invoked. However, this is not going to be easy to implement as a
Thread/Worker object could be created in one place and then started from
another place.
Re: How to distinguish UI / non-UI thread in eclipse development [message #754362 is a reply to message #754166] |
Wed, 02 November 2011 06:45   |
> following
> few points:
I meant that the code analysis will get complicated..
Note that there is also org.eclipse.ui.progress.UIJob.
As long as the UI
> sure on this point.
I don't know if there are any such 'rules'.
Re: How to distinguish UI / non-UI thread in eclipse development [message #754483 is a reply to message #754362] |
Wed, 02 November 2011 13:30   |
Thanks a lot, Deepak.
As far as I understand, UIJob seems to be a wrapping thread for the Display.asyncExec method. Here is the code I found:
UIJob#run
public final IStatus run(final IProgressMonitor monitor) {
if (monitor.isCanceled()) {
return Status.CANCEL_STATUS;
Display asyncDisplay = getDisplay();
if (asyncDisplay == null || asyncDisplay.isDisposed()) {
asyncDisplay.asyncExec(new Runnable() {
public void run() {
result = runInUIThread(monitor); //overriden by its sub classes
This information is very useful for analysis, for example, the tool can encode (and assume) the runInUIThread method is safe to perform UI operations.
May I ask, like UIJob, are there another commonly-used wrapper class in eclipse framework to perform UI operations?
Thanks a lot
-Sai
Deepak Azad wrote on Wed, 02 November 2011 06:45On 11/1/2011 12:39 PM, Sai wrote:
> following
> few points:
As long as the UI
> sure on this point.
Current Time: Sat Jul 19 19:48:23 EDT 2025
Powered by FUDForum. Page generated in 0.06033 seconds
