Home » Language IDEs » C / C++ IDE (CDT) » boost compiling problem
boost compiling problem [message #753942] Mon, 31 October 2011 00:07 Go to next message
Hello, I tried to use boost in Eclipse on Windows. My testing program:
#include <iostream>
#include <boost/filesystem.hpp>
using namespace boost::filesystem;
int main(int argc, char* argv[])
if (argc < 2)
std::cout << "Usage: tut1 path\n";
return 1;
std::cout << argv[1] << " " << file_size(argv[1]) << '\n';
return 0;
Thanks for help.
The build error message:
**** Rebuild of configuration Debug for project hello ****
**** Internal Builder is used for build ****
g++ -IC:\boost_1_47_0 -O0 -g3 -Wall -c -fmessage-length=0 -o src\hello.o ..\src\hello.cpp
g++ -o hello.exe src\hello.o
src\hello.o: In function `_static_initialization_and_destruction_0':
C:/boost_1_47_0/boost/system/error_code.hpp:214: undefined reference to `boost::system::generic_category()'
C:/boost_1_47_0/boost/system/error_code.hpp:215: undefined reference to `boost::system::generic_category()'
C:/boost_1_47_0/boost/system/error_code.hpp:216: undefined reference to `boost::system::system_category()'
src\hello.o: In function `ZN5boost11filesystem311path_traits7convertEPKcRSbIwSt11char_traitsIwESaIwEERKSt7codecvtIwciE':
C:/boost_1_47_0/boost/filesystem/v3/path_traits.hpp:113: undefined reference to `boost::filesystem3::path_traits::convert(char const*, char const*, std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >&, std::codecvt<wchar_t, char, int> const&)'
src\hello.o: In function `ZN5boost11filesystem34path7codecvtEv':
C:/boost_1_47_0/boost/filesystem/v3/path.hpp:388: undefined reference to `boost::filesystem3::path::wchar_t_codecvt_facet()'
src\hello.o: In function `ZN5boost11filesystem39file_sizeERKNS0_4pathE':
C:/boost_1_47_0/boost/filesystem/v3/operations.hpp:366: undefined reference to `boost::filesystem3::detail::file_size(boost::filesystem3::path const&, boost::system::error_code*)'
collect2: ld returned 1 exit status
Build error occurred, build is stopped
Time consumed: 1422 ms.
Re: boost compiling problem [message #754070 is a reply to message #753942] Mon, 31 October 2011 12:10 Go to previous messageGo to next message
boost Filesystem needs to be built before you can use the library.
If you have done so, please put the following libraries in your list of libraries to link against:
boost system and boost filesystem (I can't remember the exact names for windows).
Re: boost compiling problem [message #754116 is a reply to message #754070] Mon, 31 October 2011 17:39 Go to previous messageGo to next message
Yes, I tried to build boost binaries on my windows machine for eclipse, but hasn't been successful.
I think I first need to build the bjam tool. but I didn't find the jam/ directory under boost/tools/ directory.
Any ideas on how to build boost for eclipse on Windows machine?
Thanks.
Re: boost compiling problem [message #754126 is a reply to message #754070] Mon, 31 October 2011 19:09 Go to previous message
I am able to build the binaries now. They are placed under C:\boost_1_47_0\stage\lib. To test the filesystem library. I added "boost_filesystem-mgw46-mt-1_47" to the MinGW C++ linker's 'libraries', but I still get an undefined reference problem:
There are two libraries built for filesystem under stage/lib:
libboost_filesystem-mgw46-mt-1_47.a
libboost_filesystem-mgw46-mt-d-1_47.a
Anything wrong here?
**** Rebuild of configuration Debug for project Hello ****
g++ -IC:\boost_1_47_0 -O0 -g3 -Wall -c -fmessage-length=0 -osrc\hello.o ..\src\hello.cpp
g++ -LC:\boost_1_47_0\stage\lib -oHello.exe src\hello.o -lboost_filesystem-mgw46-mt-1_47
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x65): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0xb3): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x3b4): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x427): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x52c): more undefined references to `boost::system::system_category()' follow
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x3755): undefined reference to `boost::system::generic_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x377c): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x3795): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x37d9): undefined reference to `boost::system::generic_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x38c2): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x39ed): undefined reference to `boost::system::generic_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x3a13): undefined reference to `boost::system::generic_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x3b08): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x3b30): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x3b72): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x3d22): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x3e5d): undefined reference to `boost::system::system_category()'
C:\boost_1_47_0\stage\lib/libboost_filesystem-mgw46-mt-1_47.a(operations.o):operations.cpp:(.text+0x4ad2): more undefined references to `boost::system::system_category()' follow
Time consumed: 1112 ms.
Previous Topic:PathEntry Marker jobs never finishes, blocks many other jobs
Next Topic:Debug Problem With CDT
Current Time: Sat Jul 19 22:47:15 EDT 2025
Powered by FUDForum. Page generated in 0.06051 seconds
