Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Table.setSortColumn sets column background to grey
Table.setSortColumn sets column background to grey [message #753889] |
Sun, 30 October 2011 03:11  |
When running Table.setSortColumn the background of the selected column is set to grey. I want the background to stay white similar to the behaviour in Windows Explorer, Outlook etc. Is this possible?
I have tried Table.setBackground but it didn't work.
I am running SWT 3.7.1 on Windows 7.
Re: Table.setSortColumn sets column background to grey [message #753990 is a reply to message #753951] |
Mon, 31 October 2011 07:20   |
I've tried the following:
If I set the table background to white there is no change.
If I set the table background to red the background changes to red.
If I set the table background to 'widgetBackground' the selected column changes to white and all other columns change to grey!
Could this be a bug?
My test code below:
import org.eclipse.swt.SWT;
public class SetSortColumnTest extends Shell {
private static Display display;
private Table table;
private Color white;
private Color red;
private Color widgetBackground;
* Launch the application.
* @param args
public static void main(String args[]) {
try {
display = Display.getDefault();
SetSortColumnTest shell = new SetSortColumnTest(display);
shell.open();
shell.layout();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
} catch (Exception e) {
e.printStackTrace();
* Create the shell.
* @param display
public SetSortColumnTest(Display display) {
super(display, SWT.SHELL_TRIM);
createContents();
* Create contents of the shell.
protected void createContents() {
setText("SWT Application");
setSize(327, 308);
setLayout(new GridLayout(1, false));
ToolBar toolBar = new ToolBar(this, SWT.FLAT | SWT.RIGHT);
toolBar.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
ToolItem tltmNormal = new ToolItem(toolBar, SWT.NONE);
tltmNormal.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
table.setBackground(null);
tltmNormal.setText("Normal");
ToolItem tltmWhite = new ToolItem(toolBar, SWT.NONE);
tltmWhite.addSelectionListener(new SelectionAdapter() {
table.setBackground(white);
tltmWhite.setText("White");
ToolItem tltmRed = new ToolItem(toolBar, SWT.NONE);
tltmRed.addSelectionListener(new SelectionAdapter() {
table.setBackground(red);
tltmRed.setText("Red");
ToolItem tltmWidgetBackground = new ToolItem(toolBar, SWT.NONE);
tltmWidgetBackground.addSelectionListener(new SelectionAdapter() {
table.setBackground(widgetBackground);
tltmWidgetBackground.setText("Widget Background");
table = new Table(this, SWT.BORDER | SWT.FULL_SELECTION);
table.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true, 1, 1));
table.setHeaderVisible(true);
table.setLinesVisible(true);
TableColumn tblclmnColumn1 = new TableColumn(table, SWT.NONE);
tblclmnColumn1.setWidth(100);
tblclmnColumn1.setText("Column 1");
TableColumn tblclmnColumn2 = new TableColumn(table, SWT.NONE);
tblclmnColumn2.setWidth(100);
tblclmnColumn2.setText("Column 2");
TableColumn tblclmnColumn3 = new TableColumn(table, SWT.NONE);
tblclmnColumn3.setWidth(100);
tblclmnColumn3.setText("Column3");
table.setSortColumn(tblclmnColumn2);
table.setSortDirection(SWT.UP);
white = display.getSystemColor(SWT.COLOR_WHITE);
red = display.getSystemColor(SWT.COLOR_RED);
widgetBackground = display.getSystemColor(SWT.COLOR_WIDGET_BACKGROUND);
protected void checkSubclass() {
// Disable the check that prevents subclassing of SWT components
Re: Table.setSortColumn sets column background to grey [message #754047 is a reply to message #754001] |
Mon, 31 October 2011 11:15   |
On 31/10/2011 12:38 Thomas Singer ha scritto:
> Tom Schindl wrote on Mon, 31 October 2011 03:02
>> did you try to set the item.setBackground(int,Color) which will overrule
>> the native coloring?
> No, I've did not tried, because I don't want to override the normal native
> coloring. I just want the sorting column background to be the same
platform
> specific coloring like the non-sorting columns.
A couple of tricks:
1. Add an SWT.EraseItem event listener to the Table and just fill with
the background color:
table.addListener(SWT.EraseItem, new Listener() {
public void handleEvent(Event event) {
event.gc.setBackground(((TableItem) event.item).getBackground());
event.gc.fillRectangle(event.getBounds());
2. Set the item background to a slightly different color than the
platform default, like if platform default is white (255,255,255) set it
to 254,255,255 or 254,254,254:
RGB rgb =
Display.getDefault().getSystemColor(SWT.COLOR_LIST_BACKGROUND).getRGB();
if (rgb.red > 0) {
rgb.red--;
if (rgb.green > 0) {
rgb.green--;
if (rgb.blue > 0) {
rgb.blue--;
Color rowColor = new Color(Display.getDefault(), rgb);
Both of these disable the sort background, option 1 enables the owner
draw events so it may have some performance hits.
Hope this helps.
Marco.
Re: Table.setSortColumn sets column background to grey [message #754098 is a reply to message #754047] |
Mon, 31 October 2011 14:35   |
Thanks for your reply.
I'm not to keen on the first method if it has performance problems.
I've tried the second method but it didn't work. The selected column remained grey.
Test code below:
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.RGB;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.ToolBar;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.widgets.ToolItem;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
private Color red;
private Color rowColor;
private RGB rgb;
* @param args
try {
shell.open();
shell.layout();
display.sleep();
* Create the shell.
* @param display
createContents();
setSize(327, 308);
ToolItem tltmNewRgb = new ToolItem(toolBar, SWT.NONE);
tltmNewRgb.addSelectionListener(new SelectionAdapter() {
table.setBackground(rowColor);
tltmNewRgb.setText("New RGB");
rgb = Display.getDefault().getSystemColor(SWT.COLOR_LIST_BACKGROUND).getRGB();
System.out.println("red: " + rgb.red);
System.out.println("green: " + rgb.green);
System.out.println("blue: " + rgb.blue);
rowColor = new Color(Display.getDefault(), 254, 254, 254);
Re: Table.setSortColumn sets column background to grey [message #754866 is a reply to message #754179] |
Fri, 04 November 2011 12:56  |
Thanks again for your help but it's still not meeting my requirement.
Method one doesn't seem to work at all for me.
Method two only changes the background colour of table items so the rest of the selected column is still displayed in grey.
My code is below.
BTW does anyone know why the SWT table behaves like this? I can't recall ever seeing this behaviour in a windows application so I don't think it is native behaviour of a table widget.
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.TableItem;
private Color red;
private RGB rgb;
* @param args
try {
shell.open();
shell.layout();
display.sleep();
* Create the shell.
* @param display
createContents();
setSize(327, 308);
1, 1));
System.out.println("Erase Item event has fired.");
TableItem tableItem = new TableItem(table, SWT.NONE);
tableItem.setText("New TableItem");
TableItem tableItem_1 = new TableItem(table, SWT.NONE);
tableItem_1.setText("New TableItem");
TableItem tableItem_2 = new TableItem(table, SWT.NONE);
tableItem_2.setText("New TableItem");
.getRGB();
tableItem.setBackground(rowColor);
tableItem_1.setBackground(rowColor);
tableItem_2.setBackground(rowColor);
Current Time: Sun Jul 20 12:03:39 EDT 2025
Powered by FUDForum. Page generated in 0.06006 seconds
