Home » Eclipse Projects » Eclipse Platform » How to add parameters to CommandContributionItemParameter
How to add parameters to CommandContributionItemParameter [message #734307] Fri, 07 October 2011 08:14 Go to next message
I want to add parameters to a CommandContributionItemParameter. I have the following code:
Map<String, Object> commandParamametersMap = new HashMap<String, Object>();
commandParamametersMap.put("name",  object);
param.parameters = commandParamametersMap;
This does not throw an Exception but the CommandContributionItem I create from this paramater is not displayed in the context menu. It is displayed when not passing parameters to it. Is there a convenient way to pass parameters to my CommandContributionItemParameter?
Ralph
Re: How to add parameters to CommandContributionItemParameter [message #753484 is a reply to message #734307] Thu, 27 October 2011 08:49 Go to previous messageGo to next message
How is your command defined? You can only pass an object into it if that object is a String, or you define a parameter converter.
PW
Re: How to add parameters to CommandContributionItemParameter [message #753487 is a reply to message #753484] Thu, 27 October 2011 08:58 Go to previous message
I found out that I need to have parameters connected to my command in plugin.xml. These ones I connected to parameter converters. This works fine for me. Thanks for
your reply.
Ralph
Previous Topic:Parameterized commands and key bindings
Next Topic:Global IStatusLineManager.setMessage(...)
Current Time: Sat Jul 19 06:27:41 EDT 2025
Powered by FUDForum. Page generated in 0.04495 seconds
