ATL:Transformation [message #74977] |
Thu, 14 February 2008 05:57  |
Originally posted by: ouldkonissa.yahoo.fr
I am doing a transformation of JPDL to BlueXml.
The rule is
rule Swimlane2BPMActor{
from e : JPDL!Swimlane
to out : BlueXML!BPMActor(
assignment<- if e.assignment.oclIsUndefined() then
else e.assignment.pooledactors
endif,
name<-e.name,
manage <- if JPDL!Task.allInstances()->size()>0 then
JPDL!Task.allInstances()->select(t|t.swimlane <>
OclUndefined)->select(t|t.swimlane.name = e.name)-> asSequence()
else
Sequence{}
endif
In the result i obtain
<profileset xsi:type="MMUseCase:BPMActor"
xmi:id="_0PlasdrpEdyWevM8ojuhEA" name="initiator" assignment="">
the problem is that in the three first manage i obtain a 'href' in
<manage
href=" platform:/resource/BlueXml/JPDL2BlueXML/TransfoXmlToJpdl.eco re#//@startstate/@task "/>
<manage
href=" /BlueXml/JPDL2BlueXML/TransfoJpdlToBlueXml.obl#_0Pi-cdrpEdyW evM8ojuhEA "/>
<manage
href=" /BlueXml/JPDL2BlueXML/TransfoJpdlToBlueXml.obl#_0Pi-ctrpEdyW evM8ojuhEA "/>
</profileset>
instead of having an xmi : id
xmi:id="_0PpsINrpEdyWevM8ojuhEA" name="marketing"
manage="_0PiXYNrpEdyWevM8ojuhEA" assignment=""/>
xmi:id="_0PpsIdrpEdyWevM8ojuhEA" name="engineering"
manage="_0Pi-cNrpEdyWevM8ojuhEA" assignment=""/>
Issa Koné
Re: ATL:Transformation [message #75062 is a reply to message #75041] |
Fri, 15 February 2008 08:16  |
Hello Quentin,
the resulting model is vaild because i can open it with the sample ecore
editor after having registered the target meta model. But when i rename
the resulting model in xmi and open it with a text editor, i find this
result where i have an 'href' to the name of the target model instead
of having an xmi : id like the others.
href="/BlueXml/JPDL2BlueXML/TransfoJpdlToBlueXml.obl
According to Rene Ladan it may be :
<<This looks like an issue with how EMF serializes the resulting model.
It also happens when
there are references to elements in your resulting model for which the
referenced elements only
exist in the input model.>>
Thanks for your reply.
Issa Koné
Quentin Glineur a écrit :
> Hi Issa,
> Is the resulting model valid ? I mean, is it just a matter of
> serialization or are facing a problem with the model structure ?
> Quentin GLINEUR
> issa kone a écrit :
>> Hello,
>> The rule is
>> else
>> endif,
>> name<-e.name,
>> else
>> Sequence{}
>> endif
>> <manage
>> <manage
>> <manage
>> </profileset>
>> Thanks
>> Issa Koné
FUDForum. Page generated in 0.03347 seconds
