Home » Archived » M2M (model-to-model transformation) » [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:320)
[ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:320) [message #74895] |
Tue, 12 February 2008 08:08  |
Originally posted by: r.c.ladan.tue.nl
I'm using ATL from CVS updated today (2008-02-12), mainly to avoid a known error
with the 2.0.0 release build and because the update manager wouldn't let me
install the latest integration build.
Calling ATL from java gives the below exception (the program continues to run).
The simplified code leading to this is:
ByteArrayInputStream[] inModels = {null, null, null, null};
ByteArrayOutputStream[] outModels = {null, null, null, null};
String inTransformation = "replace_cpu";
for (int j = 0; j < 4; j++) {
// initialize outModels[j]
inModels[j] = new ByteArrayInputStream(outModels[j].toByteArray());
Transform transform = new Transform();
outModels[j] = new ByteArrayOutputStream();
transform.doATLTransformation(inModels, inTransformation, outModels);
with doATLTransformation being:
public void doATLTransformation(ByteArrayInputStream[] inModels, String inTransformation, ByteArrayOutputStream[] outModels) throws IOException {
this.amh = AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF); // crashes here
Is this a known bug or something to worry about?
Eclipse 3.3.1.1 M20071023-1652
EMF 2.3.1.v200709252135
Rene
SEVERE: null
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:320)
at org.eclipse.m2m.atl.engine.AtlEMFModelHandler.<init>(AtlEMFModelHandler.java:203)
at org.eclipse.m2m.atl.engine.AtlModelHandler.getDefault(AtlMod elHandler.java:62)
at transform.Transform.doATLTransformation(Transform.java:90)
at call_custom.MetaEditor.variate(MetaEditor.java:203)
at call_custom.MetaEditor.doParse(MetaEditor.java:143)
at call_custom.MetaEditor$1.doExecuteWithResult(MetaEditor.java :60)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:246)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:137)
at org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
at call_custom.MetaEditor.run(MetaEditor.java:68)
at org.eclipse.ui.internal.handlers.ActionDelegateHandlerProxy. execute(ActionDelegateHandlerProxy.java:271)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:475)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:429)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:165)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:470)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:821)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:879)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:568)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:510)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:126)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:114 1)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:975)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:971)
at org.eclipse.swt.widgets.Widget.wmKeyDown(Widget.java:1570)
at org.eclipse.swt.widgets.Control.WM_KEYDOWN(Control.java:3992 )
at org.eclipse.swt.widgets.Tree.WM_KEYDOWN(Tree.java:5480)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3701 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5370)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4364 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:32 [message #74940 is a reply to message #74895] |
Thu, 14 February 2008 02:45   |
It seems that AtlEMFModelHandler cannot load the ATL metamodel (a .ecore
file in the src/ folder).
We used to have an ant script to copy .ecore files from src/ to bin/.
However, this script was only necessary on some machines, not on others.
We realized that the problem was with compiler settings: on some
machines, .ecore files were in the exclusion list of files to be copied
from src/ to bin/.
We tried to solve the problem by setting per-project compiler settings.
Then, we removed the ant script, which was making the compilation
process a bit slower.
However, it seems that you may still have this problem. Can you please
check your Java compiler settings? If we have forgotten to set
something, we will add it.
Frédéric Jouault
Rene Ladan wrote:
> known error
> to run).
> IOException {
> // crashes here
> Rene
> SEVERE: null
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:32 [message #74960 is a reply to message #74940] |
Thu, 14 February 2008 03:49   |
I updated to todays CVS vesion and added the resource/ directory
containing a.o. ATL-0.2.ecore to bin.includes of org.eclipse.m2m.atl.engine
Now the file shows up in the generated jar file.
Rene
Frédéric Jouault wrote:
> from src/ to bin/.
> Frédéric Jouault
> Rene Ladan wrote:
>> Hi,
>> known error
>> let me
>> to run).
>> inModels[j] = new
>> IOException {
>> this.amh =
>> Thanks,
>> Rene
>> SEVERE: null
>> at
>> at
>> at
Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:32 [message #74970 is a reply to message #74960] |
Thu, 14 February 2008 05:18   |
Unfortunately this doesn't help solving the exception :(
Any more ideas/howtos?
Rene
>> Hi,
>> .ecore file in the src/ folder).
>> copied from src/ to bin/.
>> settings. Then, we removed the ant script, which was making the
>> compilation process a bit slower.
>> Thanks,
>> Frédéric Jouault
>> Rene Ladan wrote:
>>> Hi,
>>> known error
>>> let me
>>> continues to run).
>>> inModels[j] = new
>>> outModels);
>>> IOException {
>>> this.amh =
>>> Thanks,
>>> Rene
>>> SEVERE: null
>>> at
>>> at
>>> at
Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:32 [message #75680 is a reply to message #75645] |
Mon, 03 March 2008 10:19   |
--------------000305020602030504000809
Rene Ladan wrote:
> Rene Ladan wrote:
>> After testing a version from August 2007, I updated to todays HEAD. I
>> cleaned
>> any remaining files/directories having 'm2m' in their name from my
>> Eclipse directory
>> and reinstalled. Now the issue seems to be solved, but the call to
>> getDefault() now
>> seems to hang on something :
>> FIXME hangs
> If I single-step debug this in the Eclipse debugger, the debugger hangs
> at a
> seemingly random point somewhere in this statement (i.e. two successive
> debugging
> sessions yield two different hanging points).
> Could this be an Eclipse / EMF problem? Updating to the latest EMF
> (2.3.2 20080228)
> doesn't help.
I've attached two stack traces (one from right before executing the statement,
one where it seems to hang (F5-F7-F7 in the debugger).
Rene
name="stack-halted.txt"
Content-Disposition: inline;
filename="stack-halted.txt"
mt2 [Eclipse Application]
org.eclipse.equinox.launcher.Main at localhost:2317
Thread [main] (Suspended)
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2393
Workbench.runUI() line: 2353
Workbench.access$4(Workbench) line: 2219
Workbench$4.run() line: 466
Realm.runWithDefault(Realm, Runnable) line: 289
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 461
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
IDEApplication.start(IApplicationContext) line: 106
EclipseAppHandle.run(Object) line: 169
EclipseAppLauncher.runApplication(Object) line: 106
EclipseAppLauncher.start(Object) line: 76
EclipseStarter.run(Object) line: 363
EclipseStarter.run(String[], Runnable) line: 176
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: not available
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: not available
Method.invoke(Object, Object...) line: not available
Main.invokeFramework(String[], URL[]) line: 508
Main.basicRun(String[]) line: 447
Main.run(String[]) line: 1173
Main.main(String[]) line: 1148
Daemon Thread [State Data Manager] (Running)
Daemon Thread [Framework Event Dispatcher] (Running)
Daemon Thread [Start Level Event Dispatcher] (Running)
Thread [Worker-0] (Running)
Daemon Thread [Java indexing] (Running)
Thread [Worker-1] (Running)
Thread [Worker-2] (Running)
Thread [Worker-3] (Running)
Thread [Worker-4] (Running)
Thread [Worker-5] (Running)
C:\Program Files\Java\jre1.6.0_03\bin\javaw.exe (3 mrt 2008 16:14:04)
name="stack-before.txt"
filename="stack-before.txt"
org.eclipse.equinox.launcher.Main at localhost:2246
Thread [main] (Suspended (breakpoint at line 86 in Transform))
Transform.doATLTransformation(ByteArrayInputStream[], ByteArrayInputStream, String, ByteArrayOutputStream[]) line: 86
MetaEditor.variate() line: 582
MetaEditor.doParse(EObject) line: 205
MetaEditor$1.doExecute(IProgressMonitor, IAdaptable) line: 84
MetaEditor$1(AbstractEMFOperation).execute(IProgressMonitor, IAdaptable) line: 137
DefaultOperationHistory.execute(IUndoableOperation, IProgressMonitor, IAdaptable) line: 511
MetaEditor.run(IAction) line: 93
ActionDelegateHandlerProxy.execute(ExecutionEvent) line: 271
Command.executeWithChecks(ExecutionEvent) line: 475
ParameterizedCommand.executeWithChecks(Object, Object) line: 429
HandlerService.executeCommand(ParameterizedCommand, Event) line: 165
WorkbenchKeyboard.executeCommand(Binding, Event) line: 470
WorkbenchKeyboard.press(List, Event) line: 821
WorkbenchKeyboard.processKeyEvent(List, Event) line: 879
WorkbenchKeyboard.filterKeySequenceBindings(Event) line: 568
WorkbenchKeyboard.access$3(WorkbenchKeyboard, Event) line: 510
WorkbenchKeyboard$KeyDownFilter.handleEvent(Event) line: 126
EventTable.sendEvent(Event) line: 66
Display.filterEvent(Event) line: 1141
Tree(Widget).sendEvent(Event) line: 937
Tree(Widget).sendEvent(int, Event, boolean) line: 962
Tree(Widget).sendEvent(int, Event) line: 947
Tree(Widget).sendKeyEvent(int, int, int, int, Event) line: 975
Tree(Widget).sendKeyEvent(int, int, int, int) line: 971
Tree(Widget).wmKeyDown(int, int, int) line: 1570
Tree(Control).WM_KEYDOWN(int, int) line: 3992
Tree.WM_KEYDOWN(int, int) line: 5480
Tree(Control).windowProc(int, int, int, int) line: 3701
Tree.windowProc(int, int, int, int) line: 5370
Display.windowProc(int, int, int, int) line: 4364
OS.DispatchMessageW(MSG) line: not available [native method]
OS.DispatchMessage(MSG) line: 2265
Display.readAndDispatch() line: 3291
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2389
C:\Program Files\Java\jre1.6.0_03\bin\javaw.exe (3 mrt 2008 16:00:20)
--------------000305020602030504000809--
Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:32 [message #75768 is a reply to message #75680] |
Wed, 05 March 2008 05:17   |
--------------000504040603070708060400
Rene Ladan wrote:
> Rene Ladan wrote:
>>> I cleaned
>>> Eclipse directory
>>> getDefault() now
>>> FIXME hangs
>> hangs at a
>> successive debugging
>> (2.3.2 20080228)
>> doesn't help.
> statement,
I've also discussed this a bit on the eclipse.platform newsgroup without
any real results.
Some observations:
* if I debug the program with the source of org.eclipse.m2m.atl.engine
opened, the program doesn't hang but crashes with the exception mentioned
in the subject because it cannot find ATL-0.2.ecore, although this file is
in org.eclipse.m2m.atl.engine/resources. It also cannot find the file if
I put it in the a resources folder in the runtime root directory of the
program.
* Restarting Eclipse without the jar file in the plugins/ directory (forcing
the program to use the source directly) doesn't produce the hang, but crashes
the program because it cannot find ATL-0.2.ecore
* Restarting Eclipse with ATL-0.2.ecore removed from the jar file and without
any sources opened produces the hang instead of the file-not-found crash.
* If I debug the program without the ATL sources opened, it always hangs
(both with and without ATL-0.2.ecore in the jar file).
* Pressing F5-F5-F7 in the debugger makes the debugger hang on a
workbench.runEventLoop() method (iirc).
So although the resource file is in the correct location of the jar file, it
cannot run properly. I've attached the contents of the jar file.
Rene
name="contents.txt"
filename="contents.txt"
Archive: ../../../eclipse/plugins/org.eclipse.m2m.atl.engine_2.0.0.20 0802251526.jar
Length Method Size Ratio Date Time CRC-32 Name
0 Stored 0 0% 02-25-08 15:27 00000000 META-INF/
1104 Defl:N 484 56% 02-25-08 15:27 08a7166a META-INF/MANIFEST.MF
0 Stored 0 0% 02-25-08 15:27 00000000 lib/
1464 Defl:N 711 51% 02-25-08 15:27 064e2b8b about.html
615 Defl:N 321 48% 02-25-08 15:27 db21d870 about.ini
173 Defl:N 138 20% 02-25-08 15:27 b0129966 about.mappings
805 Defl:N 411 49% 02-25-08 15:27 e086838b about.properties
1574 Defl:N 1579 -0% 02-25-08 15:27 a7999f60 atl32.png
81634 Defl:N 79370 3% 02-25-08 15:27 c4308a93 lib/ATL-parser.jar
15754 Defl:N 14722 7% 02-25-08 15:27 502a0bb6 lib/org.eclipse.gmt.tcs.extractor_1.0.0.jar
22635 Defl:N 20502 9% 02-25-08 15:27 5b65b159 lib/org.eclipse.gmt.tcs.injector_1.0.0.jar
2414 Defl:N 2419 -0% 02-25-08 15:27 476ff164 modeling32.png
99 Defl:N 96 3% 02-25-08 15:27 78c0f422 plugin.properties
358 Defl:N 172 52% 02-25-08 15:27 8b135145 plugin.xml
0 Stored 0 0% 03-05-08 10:44 00000000 org/eclipse/
0 Stored 0 0% 03-05-08 10:44 00000000 org/eclipse/m2m/
0 Stored 0 0% 03-05-08 10:44 00000000 org/eclipse/m2m/atl/
0 Stored 0 0% 03-05-08 10:44 00000000 org/eclipse/m2m/atl/engine/
1121 Defl:N 595 47% 02-25-08 15:26 4c85b8ca org/eclipse/m2m/atl/engine/Atl2004Compiler.class
5665 Defl:N 2517 56% 02-25-08 15:26 4f966b17 org/eclipse/m2m/atl/engine/AtlCompiler.class
5734 Defl:N 2668 54% 02-25-08 15:26 94266f80 org/eclipse/m2m/atl/engine/AtlDefaultCompiler.class
12762 Defl:N 4846 62% 02-25-08 15:26 23e7c11f org/eclipse/m2m/atl/engine/AtlEMFModelHandler.class
1410 Defl:N 712 50% 02-25-08 15:26 df1b7770 org/eclipse/m2m/atl/engine/AtlEngineMessages.class
7112 Defl:N 3040 57% 02-25-08 15:26 bda571eb org/eclipse/m2m/atl/engine/AtlLauncher.class
5993 Defl:N 2405 60% 02-25-08 15:26 4abcab18 org/eclipse/m2m/atl/engine/AtlModelHandler.class
768 Defl:N 429 44% 02-25-08 15:26 5fe71435 org/eclipse/m2m/atl/engine/AtlNbCharFile$Line.class
3900 Defl:N 2134 45% 02-25-08 15:26 f1bc4946 org/eclipse/m2m/atl/engine/AtlNbCharFile.class
4574 Defl:N 1950 57% 02-25-08 15:26 adf9a4f3 org/eclipse/m2m/atl/engine/AtlParser.class
368 Defl:N 220 40% 02-25-08 15:26 3cbd4405 org/eclipse/m2m/atl/engine/AtlStandaloneCompiler.class
817 Defl:N 399 51% 02-25-08 15:26 768af777 org/eclipse/m2m/atl/engine/AtlSuperimposeModule$AtlSuperimpo seModuleException.class
8276 Defl:N 3894 53% 02-25-08 15:26 3c592aaa org/eclipse/m2m/atl/engine/AtlSuperimposeModule.class
492 Defl:N 311 37% 02-25-08 15:26 2c04ab77 org/eclipse/m2m/atl/engine/CompilerNotFoundException.class
1107 Defl:N 492 56% 02-25-08 15:26 b25cd3c3 org/eclipse/m2m/atl/engine/CompileTimeError.class
1136 Defl:N 586 48% 02-25-08 15:26 4fc40b39 org/eclipse/m2m/atl/engine/EnginePlugin.class
1150 Defl:N 565 51% 02-25-08 15:26 e931630a org/eclipse/m2m/atl/engine/MarkerMaker$1.class
7224 Defl:N 3210 56% 02-25-08 15:26 7d6c3127 org/eclipse/m2m/atl/engine/MarkerMaker.class
928 Defl:N 383 59% 02-25-08 15:26 0c852db9 org/eclipse/m2m/atl/engine/messages.properties
1403 Defl:N 631 55% 02-25-08 15:26 3bb857c5 org/eclipse/m2m/atl/engine/ProblemConverter.class
0 Stored 0 0% 03-05-08 10:44 00000000 org/eclipse/m2m/atl/engine/resources/
12477 Defl:N 1995 84% 02-25-08 15:26 e1f69958 org/eclipse/m2m/atl/engine/resources/ATL-WFR.asm
546043 Defl:N 24632 96% 02-25-08 15:26 5dc5f983 org/eclipse/m2m/atl/engine/resources/ATLToASMCompiler.asm
12056 Defl:N 1634 86% 02-25-08 15:26 ade9e89a org/eclipse/m2m/atl/engine/resources/atltypespropagation.asm
1415 Defl:N 459 68% 02-25-08 15:26 f9f084fe org/eclipse/m2m/atl/engine/resources/Problem.ecore
77286 Defl:N 10242 87% 02-25-08 15:26 8b261452 org/eclipse/m2m/atl/engine/resources/strings.asm
17545 Defl:N 2250 87% 02-25-08 15:26 03e0727f org/eclipse/m2m/atl/engine/resources/typeencoding.asm
0 Stored 0 0% 03-05-08 10:21 00000000 resources/
34495 Defl:N 2961 91% 02-25-08 15:26 f1bf3232 org/eclipse/m2m/atl/engine/resources/ATL-0.2.ecore
901886 197085 78% 48 files
--------------000504040603070708060400--
Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:32 [message #75995 is a reply to message #75768] |
Thu, 06 March 2008 04:02  |
Rene Ladan wrote:
> Rene Ladan wrote:
>> Rene Ladan wrote:
>>>> I cleaned
>>>> Eclipse directory
>>>> getDefault() now
>>>> FIXME hangs
>>> hangs at a
>>> (2.3.2 20080228)
>>> doesn't help.
>> statement,
> any real results.
> Some observations:
> program.
> (forcing
> crashes
> without
Some more observations:
* Exporting the org.m2m.atl.engine.vm plugin as-is works, but this way Eclipse
cannot resolve "import org.m2m.atl.engine.*" . Two solutions to this problem:
(a) Extract the embedded org.m2m.atl.engine.jar file from the generated
org.m2m.atl.engine_2.0.0-datetime.jar file
(b) Remove the embedded file from its containing jar file and replace it with
its contents (preserving the directory structure)
* When choosing solution (a), Eclipse doesn't hang on the
AtlModelHandler.getDefault() statement, but it gives an exception that it
cannot find ATL-0.2.ecore, and continues running the program with a null
metamodel.
* When choosing solution (b), Eclipse hangs on the AtlModelHandler.getDefault()
statement. I've added some println statements to the getDefault() method, when
using solution (b) it never makes it to here in AtlModelHandler::getDefault() :
public static AtlModelHandler getDefault(String repository) {
AtlModelHandler ret = (AtlModelHandler)defaultModelHandlers.get(repository);
if(ret == null) {
if(AMH_EMF.equals(repository)) {
System.out.println("AtlModelHandler::getDefault() : before");
Any ideas?
Rene
Current Time: Sat Jul 19 20:24:24 EDT 2025
Powered by FUDForum. Page generated in 0.27617 seconds
