Home » Modeling » TMF (Xtext) » PROBLEM: JvmTypeReference to Enum within a class does NOT work
icon4.gif  PROBLEM: JvmTypeReference to Enum within a class does NOT work [message #744098] Fri, 21 October 2011 19:31 Go to next message
I have the following (partly) grammar:
Import:
	'import' importedNamespace=QualifiedNameWithWildCard ';'
QualifiedNameWithWildCard:
	QualifiedName ('.' '*')?
Attribute:
	name = ID ':' type = JvmTypeReference ';'
It accepts the creation of an attribute, but there is a problem with the JvmTypeReference to an enum. Referring to an enum that is in a file of its own works fine, after importing it. But when trying to refer to an enum within an (abstract) class, both public does not work.
Example Code:
AbstractClass.java does NOT work
public abstract class AbstractClass {
	public enum InnerEnum{
		One(1),
		Two(2)
		private int number = -1;
		private InnerEnum(int code){
			this.number = code;
		public int getNumber(){
			return number;
and this DOES work:
InnerEnum.java
	One(1),
	Two(2)
		this.number = code;
		return number;
How can I change my syntax to allow the InnerEnum to be accepted as the type for the Attribute?
Thanks a lot,
Erik
[Updated on: Fri, 21 October 2011 19:45] by Moderator
Re: PROBLEM: JvmTypeReference to Enum within a class [message #744102 is a reply to message #744098] Fri, 21 October 2011 19:33 Go to previous messageGo to next message
It did not allow me to add the import links, because I did not yet post 5 messages, but I have these two lines in my grammar:
import "http :// www . eclipse .org / xtext / common / JavaVMTypes" as types
import "http :// www . eclipse .org / emf / 2002 / Ecore" as ecore
Without the spaces of course.
[Updated on: Fri, 21 October 2011 19:33] by Moderator
Re: PROBLEM: JvmTypeReference to Enum within a class [message #744764 is a reply to message #744102] Sat, 22 October 2011 06:16 Go to previous messageGo to next message
how does your import look like?
aimport like
import org.eclipse.xtext.example.domainmodel.AbstractClass$InnerEnum
attr : AbstractClass$InnerEnum
works for me
~Christian
Re: PROBLEM: JvmTypeReference to Enum within a class [message #748103 is a reply to message #744764] Mon, 24 October 2011 09:44 Go to previous message
Ah thanks a lot. That works!
The $ feels slightly cumbersome and counter intuitive though, just for my understanding, why isn't this possible?
import org.eclipse.xtext.example.domainmodel.AbstractClass.InnerEnum
attr : InnerEnum
Like it would be in java.
Anyway, thanks again!
Previous Topic:Matching braces in comments
Next Topic:Xbase - Custom XVariableDeclaration
Current Time: Sun Jul 20 11:01:32 EDT 2025
Powered by FUDForum. Page generated in 0.03694 seconds
