AJDT 2.0.0 + Eclipse 3.5 ClassNotFoundException [message #74281] |
Mon, 29 June 2009 11:59  |
I just upgraded to the new Eclipse and AJDT.
Set up - a fresh Eclipse 3.5 with the full AJDT installation, a newly
created workspace.
After the restart followed the AJDT installation I had an error window
with the message:
The org.eclipse.jdt.ui.javaElementFilters plug-in extension
"org.eclipse.ajdt.javamodel.CompilationUnitFilter" specifies a viewer
filter class which does not exist.
Plug-in "org.eclipse.ajdt.ui" was unable to instantiate class
" org.eclipse.ajdt.internal.ui.lazystart.CompilationUnitFilter ".
org/eclipse/ajdt/core/ras/FFDC
The log file revealed the problem:
!MESSAGE Plug-in org.eclipse.ajdt.core was unable to load class
org.eclipse.ajdt.core.AJSourceTransformer.
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
An error occurred while automatically activating bundle
org.eclipse.ajdt.core (27).
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at
org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
at
org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:449)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.jdt.internal.ui.filters.FilterDescriptor$1.run(F ilterDescriptor.java:132)
at
org.eclipse.jdt.internal.ui.filters.FilterDescriptor.createV iewerFilter(FilterDescriptor.java:136)
at
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup$FilterIt em.getFilterInstance(CustomFiltersActionGroup.java:183)
at
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.updateVi ewerFilters(CustomFiltersActionGroup.java:516)
at
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.<init>(CustomFiltersActionGroup.java:271)
at
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.<init>(CustomFiltersActionGroup.java:237)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup. <init>(PackageExplorerActionGroup.java:148)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. makeActions(PackageExplorerPart.java:789)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. createPartControl(PackageExplorerPart.java:496)
at
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:367)
at
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:226)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at
org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActi ve(WorkbenchPage.java:4212)
at
org.eclipse.ui.internal.WorkbenchPage$18.runWithException(Wo rkbenchPage.java:3271)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at
org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at
at
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: org.osgi.framework.BundleException: Exception in
org.eclipse.ajdt.core.AspectJPlugin.start() of bundle
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:805)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:754)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 66 more
Caused by: java.lang.NoClassDefFoundError:
org/aspectj/ajde/core/ICompilerConfiguration
at org.eclipse.ajdt.core.AspectJPlugin.start(AspectJPlugin.java :131)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:782)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:773)
... 71 more
Caused by: java.lang.ClassNotFoundException:
org.aspectj.ajde.core.ICompilerConfiguration
at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:489)
at
at
at
... 75 more
Re: AJDT 2.0.0 + Eclipse 3.5 ClassNotFoundException [message #600136 is a reply to message #74281] |
Mon, 29 June 2009 13:38  |
The important part of the exception stack trace is below. This says that
for some reason, ICompilerConfiguration was not found. And this cascades to
a bunch of other exceptions, first that the ajdt.core plugin cannot be
started, and then that AJSourceTransformer cannot be loaded (because its
plugin cannot be started).
I am not sure why ICompilerConfiguration cannot be found. But it is
possible that your ajdt installation failed in some way and therefore the
org.aspectj.ajde plugin cannot be loaded.
Did you have any problems with installation or do you have any other errors
in your error log?
On 29/06/09 8:59 AM, in article
d4d52d0fc34d9d024e7889129299d9a7$1@www.eclipse.org, "Fu Zebest"
> at
> ava:489)
> at
> at
> at
> sLoader.java:105)
> ... 75 more
Re: AJDT 2.0.0 + Eclipse 3.5 ClassNotFoundException [message #600144 is a reply to message #74300] |
Tue, 30 June 2009 04:14  |
> in your error log?
No there was no problem with a clean Eclipse installation with a clean
workspace.
The log file is filled with the exception stacktraces all rooted to the
org.aspectj.ajde.core.ICompilerConfiguration.
Even more weird thing - I cannot find this class anywhere in my Eclipse
installation. Which plugin contains it?
Forgot to mention the exact AJDT version - 2.0.0.e35x-20090625-1000.
Re: AJDT 2.0.0 + Eclipse 3.5 ClassNotFoundException [message #600152 is a reply to message #74317] |
Tue, 30 June 2009 13:17  |
The plugin is org.aspectj.ajde.
Make sure that the plugin is installed and the version should be
1.6.5.20090618034232 (although if it is a slightly different version, should
be OK). Also, make sure that the class exists inside of that plugin.
Did you install through the update site or through a zip file?
On 30/06/09 1:14 AM, in article
99d22748aae8ee9183f4ccd56a4dd516$1@www.eclipse.org, "Fu Zebest"
>> in your error log?
> workspace.
FUDForum. Page generated in 0.05504 seconds
