Home » Eclipse Projects » Eclipse Scout » Connection to database does not work(SQL Server connection)
Connection to database does not work [message #739513] Mon, 17 October 2011 11:00 Go to next message
Still having problems to connect to SQL Server database. When I execute the statement below (see Server code) the server never gives any result back. Instead it seems to come in some endless loop (see console log below).
I can perfectly connect to the database from a "normal" RCP application, so I think the problem is somewhere in the Scout part.
How can I fix this. Do I have to provide some additional configuration to the SQL service ?
Regards Bertin.
Server code:
  public Object[][] getClientTableData() throws ProcessingException {
//    return new Object[][]{{1, 1, "BJ", "Kiekebosch"}, {2, 2, "T", "Gaertner"}};
    return SQL.select("" +
        "SELECT id, piNumber, initials, lastname " +
        " FROM Client");
Console log:
!ENTRY org.eclipse.scout.rt.server 2 0 2011-10-17 16:43:23.294
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.leaseConnection(SqlConnectionPool.java:127) closing dirty connection: ConnectionID:545
!ENTRY org.eclipse.scout.rt.server 2 0 2011-10-17 16:43:23.312
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.leaseConnection(SqlConnectionPool.java:127) closing dirty connection: ConnectionID:546
!ENTRY org.eclipse.scout.rt.server 2 0 2011-10-17 16:43:23.325
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.leaseConnection(SqlConnectionPool.java:127) closing dirty connection: ConnectionID:547
!ENTRY org.eclipse.scout.rt.server 2 0 2011-10-17 16:43:23.341
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.leaseConnection(SqlConnectionPool.java:127) closing dirty connection: ConnectionID:548
Re: Connection to database does not work [message #739522 is a reply to message #739513] Mon, 17 October 2011 11:11 Go to previous messageGo to next message
At the code location that writes that log entry it is running the test statement to check if the connection is alive.
service.callbackTestConnection(candidate.conn);
This calls AbstractSqlService.callbackTestConnection that delegates to:
protected void execTestConnection(Connection conn) throws Throwable {
ISqlStyle s = getSqlStyle();
if (s != null) {
s.testConnection(conn);
The sql style used is the one returned by ISqlService.getSqlStyle.
Please take special note on the "testConnection" method in the MSSQLStyle.
To start with just leave it empty. That should fix your problem.¨
Then find a suitable test statement for MS SQL databases.
In Oracle it is for example "SELECT 1 FROM DUAL". But this does not work in MS SQL.
Please write in this forum, what statement you are currently using.
Does that help?
I assume andy already sent you some code. however here all together:
The MS SQL service code:
public abstract class AbstractMsSqlSqlService extends AbstractSqlService {
  @ConfigProperty(ConfigProperty.SQL_STYLE)
  @Order(80)
  @ConfigPropertyValue("org.eclipse.scout.rt.server.services.common.jdbc.style.MSSQLSqlStyle.class")
  protected Class<? extends ISqlStyle> getConfiguredSqlStyle() {
    return org.eclipse.scout.rt.server.services.common.jdbc.style.MSSQLSqlStyle.class;
  @ConfigProperty(ConfigProperty.STRING)
  @Order(100)
  @ConfigPropertyValue("\"com.microsoft.sqlserver.jdbc.SQLServerDriver\"")
  protected String getConfiguredJdbcDriverName() {
    return "com.microsoft.sqlserver.jdbc.SQLServerDriver";
  @Order(110)
  @ConfigPropertyValue("\"jdbc:sqlserver://[host][:port];DatabaseName=[database]\"")
  protected String getConfiguredJdbcMappingName() {
    return "jdbc:sqlserver://[host][:port];DatabaseName=[database]";
and the style it references to:
public class MSSQLSqlStyle extends AbstractSqlStyle {
  private static final long serialVersionUID = 1L;
  public String getConcatOp() {
    return "+";
  public String getLikeWildcard() {
    return "%";
  protected int getMaxListSize() {
    return 1000;
  public boolean isLargeString(String s) {
    return (s.length() > 4000);
  public boolean isBlobEnabled() {
    return true;
  public boolean isClobEnabled() {
    return true;
  public String createDateTimeIsNow(String attribute) {
    return "TRUNC(" + attribute + ", 'MI')=TRUNC(SYSDATE, 'MI')";
  public String createDateTimeIsNotNow(String attribute) {
    return "TRUNC(" + attribute + ", 'MI')!=TRUNC(SYSDATE, 'MI')";
  public void testConnection(Connection conn) throws SQLException {
    XXX your code
Re: Connection to database does not work [message #740375 is a reply to message #739522] Tue, 18 October 2011 08:45 Go to previous messageGo to next message
now it works fine.
This is what I used to test the connection to SQL Server 2008.
public class RidMSSQLStyle extends MSSQLSqlStyle {
    Statement testStatement = null;
    try {
      testStatement = conn.createStatement();
      testStatement.execute("SELECT count(*) FROM dbo.sysobjects");
    finally {
      if (testStatement != null) try {
        testStatement.close();
      catch (Throwable t) {
and for the completeness, my specialization of SQLServive. Notice the method getConfiguredSqlStyle()
public class MsSqlService extends AbstractSqlService implements IService {
    return "jdbc:sqlserver://localhost";
  protected String getConfiguredJdbcProperties() {
    return "database=MPYDB_RID";
  protected String getConfiguredPassword() {
    return "XXX";
  protected String getConfiguredUsername() {
    return "XXX";
    //return org.eclipse.scout.rt.server.services.common.jdbc.style.MSSQLSqlStyle.class;
    return MPXRid.server.services.common.sql.RidMSSQLStyle.class;
Re: Connection to database does not work [message #741055 is a reply to message #740375] Wed, 19 October 2011 02:21 Go to previous message
Hi Bertin
For better performance, I would suggest to change the test-statement as follows:
SELECT count(1) FROM dbo.sysobjects
Best Regards
Daniel
Previous Topic:Scout RT - Questions...
Next Topic:Server Plugins
Current Time: Sat Jul 19 12:22:20 EDT 2025
Powered by FUDForum. Page generated in 0.07797 seconds
