Agent Controller Corrupted Zip? [message #74078] |
Tue, 13 June 2006 11:33  |
Originally posted by: apowers.cmu.edu
I think the version of the program you're using to make zip files may be
buggy. I'm getting corrupted error files on multiple versions of zip
when I try to download the Agent Controller.
Specifically, the two files I've tried are:
http://www.eclipse.org/downloads/download.php?file=/tptp/4.1 .0.1/TPTP-4.1.0.1/tptpdc.all_platforms-TPTP-4.1.0.1.zip
and
http://www.eclipse.org/downloads/download.php?file=/tptp/4.1 .0.1/TPTP-4.1.0.1/tptpdc.linux_ia32-TPTP-4.1.0.1.zip
I'm getting unzip errors. I'm using Fedora Core 3 on a PIV, with the
built in unzip, UnZip 5.51. I've also tried another linux machine with
UnZip 5.50.
On the FC3 machine, trying to "unzip
tptpdc.all_platforms-TPTP-4.1.0.1.zip" I get this error at the end:
linking: tptp/tptpdc/solaris_sparc/lib/libxerces-c.so warning:
symbolic link (tptp/tptpdc/solaris_sparc/lib/libxerces-c.so) failed
error: zipfile probably corrupt (segmentation violation)
The resulting folder only contains tptp/tptpdc/solaris_sparc/ and some
files inside that -- no other folders. Since I'm working in linux that's
not enough I'm guessing.
Unzip 5.50 seems to succesfully unzip this.
When I try to "unzip tptpdc.linux_ia32-TPTP-4.1.0.1.zip" I get this
instead, towards the end of the output:
linking: 2/lib/libxerces-c.so warning: symbolic link
(2/lib/libxerces-c.so) failed
On UnZip 5.50, unzip just freezes somewhere in the middle when I try to
"unzip tptpdc.linux_ia32-TPTP-4.1.0.1.zip". It's hard to tell if it's
the same file.
Eventually I was able to get it to unzip by unzipping the
tptpdc.all_platforms-TPTP-4.1.0.1.zip on the old linux machine and then
tarballing it and moving it over to my newer machine. But I suspect the
zip program you're using be doing something odd.
Re: Agent Controller Corrupted Zip? [message #74096 is a reply to message #74078] |
Tue, 13 June 2006 17:45  |
I have tested both zip files you mentioned in your message, and I could
unzip them both without error. I unzipped the file on a Red Hat
Enterprise Linux AS release 4, running UnZip 5.51. Sometimes the files are
corrupted during download. Please try to download the files again and run
unzip again.
FUDForum. Page generated in 0.06712 seconds
