Connection to database does not work [message #739513] |
Mon, 17 October 2011 11:00  |
Still having problems to connect to SQL Server database. When I execute the statement below (see Server code) the server never gives any result back. Instead it seems to come in some endless loop (see console log below).
I can perfectly connect to the database from a "normal" RCP application, so I think the problem is somewhere in the Scout part.
How can I fix this. Do I have to provide some additional configuration to the SQL service ?
Regards Bertin.
Server code:
public Object[][] getClientTableData() throws ProcessingException {
// return new Object[][]{{1, 1, "BJ", "Kiekebosch"}, {2, 2, "T", "Gaertner"}};
return SQL.select("" +
"SELECT id, piNumber, initials, lastname " +
" FROM Client");
Console log:
!ENTRY org.eclipse.scout.rt.server 2 0 2011-10-17 16:43:23.294
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.leaseConnection(SqlConnectionPool.java:127) closing dirty connection: ConnectionID:545
!ENTRY org.eclipse.scout.rt.server 2 0 2011-10-17 16:43:23.312
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.leaseConnection(SqlConnectionPool.java:127) closing dirty connection: ConnectionID:546
!ENTRY org.eclipse.scout.rt.server 2 0 2011-10-17 16:43:23.325
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.leaseConnection(SqlConnectionPool.java:127) closing dirty connection: ConnectionID:547
!ENTRY org.eclipse.scout.rt.server 2 0 2011-10-17 16:43:23.341
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.leaseConnection(SqlConnectionPool.java:127) closing dirty connection: ConnectionID:548
FUDForum. Page generated in 0.05931 seconds
