Home » Language IDEs » ServerTools (WTP) » New file extension for Web Tools xml editor
New file extension for Web Tools xml editor [message #736094] Thu, 13 October 2011 11:03 Go to next message
Hi all,
I want to associate Web Tools XML editor with new file extension. I'm trying do it this way:
<!--The org.eclipse.wst.xml.core.xmlsource content type is only for
		handling some special cases of ill-formed xml in a reasonable
		manner, and should not be emulated by clients. The two content
		types are often used interchangeably by the XML component, but
		please use org.eclipse.core.runtime.xml instead. -->
	<extension point="org.eclipse.wst.sse.ui.editorConfiguration">
		<sourceViewerConfiguration
			class="org.eclipse.wst.xml.ui.StructuredTextViewerConfigurationXML"
			target="hadesclipse.editor.hml" />
		<contentOutlineConfiguration
			class="org.eclipse.wst.xml.ui.views.contentoutline.XMLContentOutlineConfiguration"
		<quickOutlineConfiguration
			class="org.eclipse.wst.xml.ui.internal.quickoutline.XMLQuickOutlineConfiguration"
		<propertySheetConfiguration
			class="org.eclipse.wst.xml.ui.views.properties.XMLPropertySheetConfiguration"
		<documentationTextHover
        	class="org.eclipse.wst.xml.ui.internal.taginfo.XMLTagInfoHoverProcessor"
        	target="hadesclipse.editor.hml">
  		</documentationTextHover>
  		<doubleClickStrategy
        	class="org.eclipse.wst.xml.ui.internal.doubleclick.XMLDoubleClickStrategy"
  		</doubleClickStrategy>
		<provisionalConfiguration
			type="sourceeditingtexttools"
			class="org.eclipse.wst.xml.ui.internal.provisional.XMLSourceEditingTextTools"
			type="characterpairmatcher"
			class="org.eclipse.wst.xml.ui.internal.text.XMLDocumentRegionEdgeMatcher"
			type="foldingstrategy"
			class="org.eclipse.wst.xml.ui.internal.projection.XMLFoldingStrategy"
			type="org.eclipse.jface.text.quickassist.IQuickAssistProcessor"
			class="org.eclipse.wst.xml.ui.internal.correction.XMLQuickAssistProcessor"
			type="autoeditstrategy"
			class="org.eclipse.wst.xml.ui.internal.autoedit.StructuredAutoEditStrategyXML"
		<provisionalDefinition
			type="preferencepages"
			value="org.eclipse.wst.xml.ui.preferences.xml.xml, org.eclipse.wst.sse.ui.preferences.xml.source, org.eclipse.wst.sse.ui.preferences.xml.templates, org.eclipse.wst.sse.ui.preferences.xml.colors, org.eclipse.wst.sse.ui.preferences.xml.contentassist"
			type="spellingregions"
			value="XML_COMMENT_TEXT, XML_CONTENT, XML_DEFAULT"
			type="activecontexts"
			value="org.eclipse.core.runtime.xml, org.eclipse.wst.xml.navigation, org.eclipse.wst.xml.cleanup, org.eclipse.wst.xml.selection, org.eclipse.wst.xml.dependencies, org.eclipse.wst.xml.grammar, org.eclipse.wst.xml.expand, org.eclipse.wst.xml.occurrences, org.eclipse.wst.sse.comments"
	</extension>
   <extension
         point="org.eclipse.ui.editors">
      <editor
			contributorClass="org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditorActionBarContributor"
			class="org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditorPart"
            icon="icons/sample.gif"
            id="hadesclipse.editors.HMLEditor"
            name="HMLEditor">
            <contentTypeBinding
        		 contentTypeId="hadesclipse.editor.hml"/>
       </editor>
   </extension>
   	<!-- HML model content type -->
	<extension point="org.eclipse.core.contenttype.contentTypes">
      <content-type id="hadesclipse.editor.hml"
       base-type="org.eclipse.core.runtime.xml"
       name="HML model"
       file-extensions="hml"
       priority="high">
      </content-type>
   </extension>
Syntax Colouring, formatting and code folding works, but i have no idea why code completion does not works.When I'm pressing ctrl+spacebar in the left bootom corner shows "No completions avaible". Shoud I add something to plugin.xml ?
please help.
Re: New file extension for Web Tools xml editor [message #736118 is a reply to message #736094] Thu, 13 October 2011 11:53 Go to previous messageGo to next message
Is the root issue being able to open the XML Editor on your own filename extension? If so, and those files are valid XML, you can just add a new file-association, or content type whose base type is XML, using the org.eclipse.core.contenttype.contentTypes extension point.
Re: New file extension for Web Tools xml editor [message #736156 is a reply to message #736118] Thu, 13 October 2011 13:23 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Thu, 13 October 2011 11:53
... you can just add a new file-association, or content type whose base type is XML, using the org.eclipse.core.contenttype.contentTypes extension point.
I think I'm doing this:
       name="HML model"
       priority="high">
      </content-type>
   </extension>
and editor is associated with *.hml files, but code assistance don't work
[Updated on: Thu, 13 October 2011 13:40] by Moderator
Re: New file extension for Web Tools xml editor [message #736233 is a reply to message #736156] Thu, 13 October 2011 16:56 Go to previous messageGo to next message
Does it work for a file with identical contents named *.xml?
Re: New file extension for Web Tools xml editor [message #736258 is a reply to message #736233] Thu, 13 October 2011 17:29 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Thu, 13 October 2011 16:56
Yes
Re: New file extension for Web Tools xml editor [message #748207 is a reply to message #736258] Mon, 24 October 2011 11:03 Go to previous message
Just to make sure I'm not missing anything obvious, your file does refer to a schema or DTD, right?
Previous Topic:How to get bundle org.eclipse.jpt.core 2.3.0?
Next Topic:How to create a dynamic web project from existing source folders?
Current Time: Sat Jul 19 06:25:51 EDT 2025
Powered by FUDForum. Page generated in 0.04427 seconds
