Home » Eclipse Projects » Platform - User Assistance (UA) » Searching in help does not work
Searching in help does not work [message #735611] Wed, 12 October 2011 07:30 Go to next message
As mentioned in other posts, I try to provide a help for an application with the usage of my own implementation of a toc provider. The provider builds a toc dynamically with topics that reffer to xhtml content provided in the same plugin aa well as xhtml content provided in other plugins.
A simple example looks as follows:
- bundleA with bundleA.xhtml
- bundleB with bundleB.xhtml
- bundelB also provides the toc provider, which is registerd via the extension point org.eclipse.help.toc
The href to the content is allways /bundleId/path/to/content (eg. /bundleA/bundleA.xhtml and /bundleB/bundleB.xhtml).
The toc and the content for both bundels is displayed correctly when I click at the topics. My problem is, that only matches in bundelB are found, which is the bundel that defines also the toc provider, if I try to search the help.
Re: Searching in help does not work [message #737336 is a reply to message #735611] Fri, 14 October 2011 19:20 Go to previous messageGo to next message
I would need to see an example to understand the issue. Can you file a bug report with the two bundles attached?
Re: Searching in help does not work [message #739482 is a reply to message #737336] Mon, 17 October 2011 10:20 Go to previous message
Hallo Chris,
I filed a bug report (bug 361143) as requested in your post.
Riccardo
Previous Topic:helpData.xml Ignored for Infocenter Startup
Next Topic:Maximized welcome page
Current Time: Sat Jul 19 15:41:07 EDT 2025
Powered by FUDForum. Page generated in 0.06086 seconds
