Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] How to programmatically display a View?
[EEF] How to programmatically display a View? [message #735025] Mon, 10 October 2011 12:56 Go to next message
I have a GMF/Obeo designer modeler and I use EEF for my property sheet.
I would like to implement a listener on an EditPart of my diagram which will show an EEF view of my choice.
I know how to catch the event on my diagram, but I can't figure out how to active the EEF view.
Do you have any idea?
Xavier
Re: [EEF] How to programmatically display a View? [message #735189 is a reply to message #735025] Tue, 11 October 2011 03:37 Go to previous messageGo to next message
Xavier,
Here's how we open the properties view for double click in the Sample
Ecore Editor.
public void mouseDoubleClick(MouseEvent event)
if (event.button == 1)
try
getEditorSite().getPage().showView("org.eclipse.ui.views.PropertySheet");
catch (PartInitException exception)
EcoreEditorPlugin.INSTANCE.log(exception);
On 10/10/2011 6:56 PM, Xavier Seignard wrote:
> Hello,
> Regards,
> Xavier
Re: [EEF] How to programmatically display a View? [message #735219 is a reply to message #735189] Tue, 11 October 2011 05:35 Go to previous messageGo to next message
Thanks Ed, but in my case the property view is actually opened.
My problem is that when I click on an edit part of my diagram which is actually binded to nothing of the semantic model, but if someone click on that edit part I would like to display a particular EEF view (i.e the property sheet of a given model element) so that (s)he can edit it seamlessly.
Anyway, thanks for your advice it helped me to understand some useful stuff.
Xavier
Re: [EEF] How to programmatically display a View? [message #735281 is a reply to message #735219] Tue, 11 October 2011 08:03 Go to previous messageGo to next message
I tried to override the PropertiesEditionSection.resolveSemanticObject(Object object) as described here : http://eclipsercpdev.blogspot.com/2011/10/use-eclipse-eef-as-property-sheet-for.html in order to return the desired EObject when I click on my EditPart of the diagram.
But the view is not updated accordingly. Only the title is updated.
Any idea?
Xavier
Re: [EEF] How to programmatically display a View? [message #735282 is a reply to message #735281] Tue, 11 October 2011 08:18 Go to previous messageGo to next message
Sorry, my bad, it's the opposite : But the title of the view is not updated accordingly. Only the view is updated.
Re: [EEF] How to programmatically display a View? [message #736106 is a reply to message #735282] Thu, 13 October 2011 11:32 Go to previous messageGo to next message
Hello?
Is the solution I implemented is the best way to do it?
I'm not sure because I had to code it with introspection in order not to introduce cyclic dependencies between edit plugin and diagramming one.
Any idea people?
Xavier
Re: [EEF] How to programmatically display a View? [message #739254 is a reply to message #736106] Mon, 17 October 2011 05:03 Go to previous message
Hi Xavier,
It's a good way to do that. I don't understand why this cause a cyclic
dependency with your diagram plugin ?
Goulwen
Le 13/10/2011 17:32, Xavier Seignard a écrit :
> Hello?
> Any idea people?
> Regards,
> Xavier
Previous Topic:[EEF] Use EEF to generate property sheet editor for Graphiti
Next Topic:Howto use xsd2Ecore so that the xmi-files can be validated with xsd?
Current Time: Sat Jul 19 22:42:18 EDT 2025
Powered by FUDForum. Page generated in 0.03206 seconds
