Home » Modeling » TMF (Xtext) » Calling Xtend generation from my Builder Participant(Xtext 2.0)
Calling Xtend generation from my Builder Participant [message #734376] Fri, 07 October 2011 11:00 Go to next message
I would like to start doing some of the code generation of my project with Xtend. I already have a Builder Participant registered, which xtends from JavaProjectBasedBuilderParticipant and implements IXtextBuilderParticipant.
If I combine my builder participant and the automatic xtext code generation, I get:
	at org.eclipse.xtext.builder.JavaProjectBasedBuilderParticipant.getConfiguredFileSystemAccess(JavaProjectBasedBuilderParticipant.java:112)
	at org.eclipse.xtext.builder.JavaProjectBasedBuilderParticipant.build(JavaProjectBasedBuilderParticipant.java:77)
	at altagracia.builder.XtextMyDSLBuilderParticipant.build(XtextMyDSLBuilderParticipant.java:41)
	at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
	at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:160)
	at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:182)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:85)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
I think I should somehow call the xtend generation from MyDSLBuilderParticipant.
My DSL projects don't need to have Java nature, and this exception appears when I add the java nature to my project (I think it registers two java builder participants).
I'm lost here, I would appreciate any advice.
Thanls!
Re: Calling Xtend generation from my Builder Participant [message #734377 is a reply to message #734376] Fri, 07 October 2011 11:05 Go to previous messageGo to next message
make sure you use the YourdslExecutableExtensionFactory in your plugin.xml (when registering the builerparticipant.
~Christian
[Updated on: Fri, 07 October 2011 11:08] by Moderator
Re: Calling Xtend generation from my Builder Participant [message #734380 is a reply to message #734377] Fri, 07 October 2011 11:13 Go to previous messageGo to next message
Hi, Christian.
I don't understand. My Xtext project works well and generates code alone. Its plugin.xml of the .ui project has the ExecutableExtensionFactory in it.
Now, I have another project with the builder participant which receives Xtext resources and generates code using Jet.
The exception is thrown when I have this "another project" and the xtext projects (doing the xtend generation) all opened.
Do you mean I have to register my ExecutableExtensionFactory in this other non-xtext project?
Re: Calling Xtend generation from my Builder Participant [message #734385 is a reply to message #734376] Fri, 07 October 2011 11:21 Go to previous messageGo to next message
Hi as i said. You get the NPE cause you do not use guice to create
the Builder participant. This is usually done with the
ExecuableExtensionFactory. You may have to create a own for your
plugin. Regards Christian
[Updated on: Fri, 07 October 2011 11:52] by Moderator
Re: Calling Xtend generation from my Builder Participant [message #734393 is a reply to message #734385] Fri, 07 October 2011 12:00 Go to previous message
maybe you can use this http://kthoms.wordpress.com/2011/09/28/moving-an-xtend-generator-into-its-own-plugin/
as a starting point.
~Christian
Previous Topic:About Xtext and GMF intergration
Next Topic:My first XText
Current Time: Sun Jul 20 14:27:23 EDT 2025
Powered by FUDForum. Page generated in 0.10650 seconds
