Home » Eclipse Projects » Eclipse 4 » Closeable parts
Closeable parts [message #659698] Tue, 15 March 2011 05:52 Go to next message
Hello ,
I am trying to make a part (in a partstack) be uncloseable.
I added the tag closeable="false" in the .e4xmi at the corresponding part definition but to no avail.
Thanks for any help!
Re: Closeable parts [message #659981 is a reply to message #659698] Wed, 16 March 2011 09:42 Go to previous messageGo to next message
On 03/15/2011 05:53 AM, AppleJus wrote:
> Hello ,
Are you using the correct tag? "NoClose"
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Closeable parts [message #662643 is a reply to message #659981] Thu, 31 March 2011 07:49 Go to previous messageGo to next message
I am also experimenting with this. Setting the checkbox "Closable" in the Workbenchmodel Editor does not have any effect on the file.
Manually setting the attribute closeable="false" has no effect.
Manually setting the attribute closeable="NoClose" leads to an Error: "Value 'NoClose' is not legal."
I also tried to modify the model of the Part:
	@Inject private MPart part;
	@PostConstruct
	public void postConstruct() {
		part.setCloseable(false);
This does not have any effect.
Christoph
[Updated on: Thu, 31 March 2011 07:50] by Moderator
Re: Closeable parts [message #662886 is a reply to message #662643] Fri, 01 April 2011 07:33 Go to previous messageGo to next message
> Manually setting the attribute closable="NoClose" leads to an Error:
> I also tried to modify the model:
> @PostConstruct
Also try part.getTags().add("NoClose");
PW
Paul Webster
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Closeable parts [message #663002 is a reply to message #662886] Fri, 01 April 2011 18:04 Go to previous messageGo to next message
works! Thank you
Re: Closeable parts [message #664291 is a reply to message #663002] Fri, 08 April 2011 05:54 Go to previous messageGo to next message
Hi Guys,
I can't get it to work even in a very simple sample. I think I am missing some very basic point.
This is my Part-Class:
public class TestPart {
	@Inject private Composite parent;
	@PostConstruct
		Text text = new Text(parent, SWT.MULTI);
		text.setText("Hello World");
The Part is Child of a Part Stack. The Label will still show the "X" for closing and closing is performed, when the "X" is clicked.
Maybe I have the wrong Version of Plugins? I am using the Plugins from eclipse-e4-repo-incubation-I20110329-2200.
Any help is greatly appreciated.
Christoph
Re: Closeable parts [message #664300 is a reply to message #664291] Fri, 08 April 2011 06:07 Go to previous messageGo to next message
Why don't you set the tag in the .e4xmi? My current guess is that you
can't change this at runtime because the CTabItem has been constructed
already before and IIRC SWT.Close is passed to the constructor.
Tom
Am 08.04.11 11:54, schrieb Christoph Keimel:
> Hi Guys,
> @PostConstruct
> Regards,
> Christoph
Re: Closeable parts [message #664302 is a reply to message #664300] Fri, 08 April 2011 06:27 Go to previous messageGo to next message
Hi Tom,
I knew I was missing something basic. Sometimes you can't see the trees in the forest Smile
Thanks for your help. Issue is solved.
Smile,
Christoph
Re: Closeable parts [message #664491 is a reply to message #659981] Sat, 09 April 2011 14:06 Go to previous messageGo to next message
MPart#setClosable(false) should now work as well in the latest nightly
builds [1]! The reason for the flag is that when we talk about
perspectives the view can be closeable in perspective A but not in B.
The only missing part is that it is not dynamic after the CTabItem has
been created [2].
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=342291
[2]https://bugs.eclipse.org/bugs/show_bug.cgi?id=342299
Am 16.03.11 14:42, schrieb Paul Webster:
>> Hello ,
> PW
Re: Closeable parts [message #734151 is a reply to message #664491] Thu, 06 October 2011 17:35 Go to previous messageGo to next message
This works fine for me to make a part not closeable, but how can I make the stack itself not closeable? MPartStack doesn't have setCloseable() and doesn't seem to heed the "NoClose" tag. Surely there's some simple way to do this?
Re: Closeable parts [message #734163 is a reply to message #734151] Thu, 06 October 2011 17:44 Go to previous messageGo to next message
What do you mean by not closeable? That it doesn't vanish when the last
entry in the stack is gone?
Then this is not yet supported because the behavior in 3.x is also like
it is today in e4. We already discussed this and it is far more easy to
implement in e4 than it is in 3.x where we still face issues to
correctly implement this really easy feature.
So please file a bug report this by setting a tag and respecting this
tag in the CleanupAddon.
Tom
Am 06.10.11 23:35, schrieb grillo321:
> way to do this?
Re: Closeable parts [message #734173 is a reply to message #734163] Thu, 06 October 2011 19:23 Go to previous message
There are two problems, 1) closing last part in stack closes stack and 2) minimizing initially empty stack closes it rather than minimizing it.
Added bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=360173
Previous Topic:XWT: difference between static and dynamic resource
Next Topic:how to set minimum size for windows or parts
Current Time: Sun Jul 20 06:19:05 EDT 2025
Powered by FUDForum. Page generated in 0.05492 seconds
