Home » Eclipse Projects » EclipseLink » JPQL join and collection association (ManyToOne join returning too much in Collection association)
JPQL join and collection association [message #733915] Wed, 05 October 2011 19:23 Go to next message
I have a simple JPQL query (below) and I have 2 entities, PrintDocumentsInfo (the owner) and PrintItemInfo (the reverse); I have the ManyToOne mapping in the PrintDocumentsInfoList entity and the OneToMany mapping in the PrintItemInfo entity.
The fields and annotations are also below.
This query works. However, the Collection<PrintDocumentsInfo> in the PrintItemInfo class is not limited to PrintDocumentsInfo adviceStatus2 = 100.
Unfortunately, I get a Collection of all adviceStatus2 values whenever there is an adviceStatus2 == 100 in the any of the ForeignKeys that relate back to the PrintItemInfo table.
This seems so straightforward in the docs, tutorials, and books but no way can I get this to return the correct results. What am I missing?
Thanks in advance for you helpl
//the jpql join query
String jpqlString3 = "SELECT docs " +
"FROM PrintItemInfo info INNER JOIN info.printDocumentsInfoList docs " +
"WHERE docs.adviceStatus2 = 100 "
//this is the "owning" side of the relationship in the PrintDocumentsInfo class
@ManyToOne(targetEntity=PrintItemInfo.class)
@JoinColumn(name="PRINT_ITEM_ID2", referencedColumnName="PRINT_ITEM_ID")
private PrintItemInfo printItemInfo;
//this is the "inverse" side in the PrintItemInfo class
@OneToMany(targetEntity=PrintDocumentsInfo.class, mappedBy="printItemInfo")
private Collection<PrintDocumentsInfo> printDocumentsInfoList
= new TreeSet<PrintDocumentsInfo>();
Re: JPQL join and collection association [message #734078 is a reply to message #733915] Thu, 06 October 2011 11:36 Go to previous messageGo to next message
That is odd. I would expect that if you selected the info and accessed the docs, but selecting the docs seems like you would only get the filtered ones back.
What was the SQL that was generated?
You could try:
"SELECT docs FROM PrintDocumentsInfo docs WHERE docs.adviceStatus2 = 100 "
Re: JPQL join and collection association [message #734108 is a reply to message #734078] Thu, 06 October 2011 13:37 Go to previous message
I believe what is being said is that the query is correctly returning docs that reference a docs.adviceStatus2 = 100. What is being stated is that the returned and so managed PrintItemInfo's 1:M collection of PrintDocumentsInfo is fully populated and not filtered based on the query.
If so, this is as expected. The query is to give back fully populated PrintDocumentsInfo. All references will contain all the information associated to the entities as they exist in the database. So the PrintItemInfo's referenced from these returned PrintDocumentsInfo must be full populated and not use the criteria from the query, as doing so would corrupt the cache - these entities are managed so other queries in the same EntityManager context are expected to return the same instance.
My suggestion would be not access the PrintItemInfo's collection so that it remains untriggered, and just used the collection of PrintDocumentsInfo entities returned from the query directly, sorting them by their PrintItemInfo.
[Updated on: Thu, 06 October 2011 13:38] by Moderator
Previous Topic:Duplicate strings in o.e.p.internal.jpa.metadata.accessors.objects.MetadataClass
Next Topic:@Array doesn't seem to support basic types
Current Time: Sat Jul 19 19:22:40 EDT 2025
Powered by FUDForum. Page generated in 0.29302 seconds
