Home » Eclipse Projects » Virgo » Upgrading to Virgo 3.0.1 causing Uses violations
Upgrading to Virgo 3.0.1 causing Uses violations [message #733796] Wed, 05 October 2011 12:23 Go to next message
I am trying to upgrade from virgo 2.1.1 to 3.0.1, and I am getting Uses violations :
      Uses violation: <Import-Package: org.mortbay.jetty.security; version="0.0.0"> in bundle <fileserver_2.1.1[1317826595423]>
            Found conflicts:
                package        'javax.servlet.http_2.5.0' in bundle 'com.springsource.javax.servlet_2.5.0[71]' used by 'org.mortbay.jetty.security_6.1.9' in bundle 'com.springsource.org.mortbay.jetty.server_6.1.9[1317826595432]'
                conflicts with 'javax.servlet.http_3.0.0' in bundle 'javax.servlet_3.0.0.v201103241009[92]' used by 'org.springframework.web.servlet.view.jasperreports_3.0.5.RELEASE' in bundle 'org.springframework.web.servlet_3.0.5.RELEASE[1317826595845]'
How can I solve this conflict ?
Re: Upgrading to Virgo 3.0.1 causing Uses violations [message #733821 is a reply to message #733796] Wed, 05 October 2011 13:54 Go to previous messageGo to next message
Unfortunately the bundle com.springsource.org.mortbay.jetty.server_6.1.9 imports javax.servlet version with range [2.5.0, 3.0.0), Virgo Tomcat Server is released with the newer javax.servlet (i.e. 3.0.0) version.
You can try to find newer version for com.springsource.org.mortbay.jetty.server.
Or you can try to extend the version range in the current bundle that you use, for example [2.5.0, 4.0.0).
Java Servlet Specification latest version is compatible with the previous versions from User's perspective, so the second approach might be working also very well.
Re: Upgrading to Virgo 3.0.1 causing Uses violations [message #733850 is a reply to message #733821] Wed, 05 October 2011 15:23 Go to previous messageGo to next message
"Or you can try to extend the version range in the current bundle that you use, for example [2.5.0, 4.0.0)."
How can I do this to an compiled jar ?
Re: Upgrading to Virgo 3.0.1 causing Uses violations [message #733857 is a reply to message #733850] Wed, 05 October 2011 15:52 Go to previous messageGo to next message
Open com.springsource.org.mortbay.jetty.server.jar
Open META-INF/MANIFEST.MF
Extend the version ranges - see below
MANIFEST.MF
Bundle-DocURL: http://jetty.mortbay.org
Import-Package: javax.net.ssl,javax.security.cert,javax.servlet;versio
n="[2.5.0, 4.0.0)",javax.servlet.http;version="[2.5.0, 4.0.0)",javax.
xml.parsers,org.mortbay.component;version="[6.1.0, 7.0.0)",org.mortba
y.log;version="[6.1.0, 7.0.0)",org.mortbay.servlet;version="[6.1.0, 7
.0.0)",org.mortbay.thread;version="[6.1.0, 7.0.0)",org.mortbay.util;v
ersion="[6.1.0, 7.0.0)",org.mortbay.util.ajax;version="[6.1.0, 7.0.0)
",org.xml.sax,org.xml.sax.helpers
Bundle-SymbolicName: com.springsource.org.mortbay.jetty.server
Then replace the original MANIFEST.MF with the changed one
Re: Upgrading to Virgo 3.0.1 causing Uses violations [message #733892 is a reply to message #733857] Wed, 05 October 2011 17:23 Go to previous messageGo to next message
I guess another question is which Virgo package are you upgrading to. If you upgrading to Virgo Tomcat, have you considered trying Virgo Jetty package? Could that be a better approach for you as you already using jetty internally?
Virgo Jetty package is shipped with jetty v7.4.2.v20110526
Dmitry
Re: Upgrading to Virgo 3.0.1 causing Uses violations [message #735444 is a reply to message #733892] Tue, 11 October 2011 16:21 Go to previous message
Sorry for the late response, I ended up doing what Violeta suggested and changed the version range.
Now I have a new problem with Virgo 3.0.1, I am using activemq-web-console-5.5.0.war and with Virgo 2.1.1 it worked fine but after the upgrade I got this exception any idea why this is happening ?
22:09:01.685 [Thread-106] ERROR System.err - Oct 11, 2011 10:09:01 PM org.apache.catalina.core.StandardContext filterStart
22:09:01.685 [Thread-106] ERROR System.err - SEVERE: Exception starting filter session
22:09:01.685 [Thread-106] ERROR System.err - java.lang.ClassCastException: org.apache.activemq.web.SessionFilter cannot be cast to javax.servlet.Filter
22:09:01.686 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:252)
22:09:01.686 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.setFilterDef(ApplicationFilterConfig.java:372)
22:09:01.686 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:98)
22:09:01.686 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4584)
22:09:01.687 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5262)
22:09:01.687 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5257)
22:09:01.687 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
22:09:01.687 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
22:09:01.687 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
22:09:01.688 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
22:09:01.688 [Thread-106] ERROR System.err - 	at java.lang.Thread.run(Thread.java:662)
22:09:02.405 [Thread-106] ERROR System.err - Oct 11, 2011 10:09:02 PM org.apache.catalina.core.StandardContext filterStart
22:09:02.405 [Thread-106] ERROR System.err - SEVERE: Exception starting filter spring-rq
22:09:02.406 [Thread-106] ERROR System.err - java.lang.ClassCastException: org.springframework.web.filter.RequestContextFilter cannot be cast to javax.servlet.Filter
22:09:02.406 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:252)
22:09:02.406 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.setFilterDef(ApplicationFilterConfig.java:372)
22:09:02.407 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:98)
22:09:02.407 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4584)
22:09:02.407 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5262)
22:09:02.407 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5257)
22:09:02.407 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
22:09:02.408 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
22:09:02.408 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
22:09:02.408 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
22:09:02.408 [Thread-106] ERROR System.err - 	at java.lang.Thread.run(Thread.java:662)
22:09:02.411 [Thread-106] ERROR System.err - Oct 11, 2011 10:09:02 PM org.apache.catalina.core.StandardContext filterStart
22:09:02.412 [Thread-106] ERROR System.err - SEVERE: Exception starting filter audit
22:09:02.412 [Thread-106] ERROR System.err - java.lang.ClassCastException: org.apache.activemq.web.AuditFilter cannot be cast to javax.servlet.Filter
22:09:02.412 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:252)
22:09:02.412 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.setFilterDef(ApplicationFilterConfig.java:372)
22:09:02.412 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:98)
22:09:02.413 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4584)
22:09:02.413 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5262)
22:09:02.413 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5257)
22:09:02.413 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
22:09:02.413 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
22:09:02.414 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
22:09:02.414 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
22:09:02.414 [Thread-106] ERROR System.err - 	at java.lang.Thread.run(Thread.java:662)
22:09:02.417 [Thread-106] ERROR System.err - Oct 11, 2011 10:09:02 PM org.apache.catalina.core.StandardContext filterStart
22:09:02.417 [Thread-106] ERROR System.err - SEVERE: Exception starting filter sitemesh
22:09:02.418 [Thread-106] ERROR System.err - java.lang.ClassCastException: com.opensymphony.module.sitemesh.filter.PageFilter cannot be cast to javax.servlet.Filter
22:09:02.418 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:252)
22:09:02.418 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.setFilterDef(ApplicationFilterConfig.java:372)
22:09:02.418 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:98)
22:09:02.418 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4584)
22:09:02.419 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5262)
22:09:02.419 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5257)
22:09:02.419 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
22:09:02.419 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
22:09:02.419 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
22:09:02.419 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
22:09:02.420 [Thread-106] ERROR System.err - 	at java.lang.Thread.run(Thread.java:662)
22:09:02.421 [Thread-106] ERROR System.err - Oct 11, 2011 10:09:02 PM org.apache.catalina.core.StandardContext filterStart
22:09:02.422 [Thread-106] ERROR System.err - SEVERE: Exception starting filter spring
22:09:02.422 [Thread-106] ERROR System.err - java.lang.ClassCastException: org.apache.activemq.web.filter.ApplicationContextFilter cannot be cast to javax.servlet.Filter
22:09:02.423 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:252)
22:09:02.423 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.setFilterDef(ApplicationFilterConfig.java:372)
22:09:02.423 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:98)
22:09:02.424 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4584)
22:09:02.424 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5262)
22:09:02.424 [Thread-106] ERROR System.err - 	at org.apache.catalina.core.StandardContext$2.call(StandardContext.java:5257)
22:09:02.424 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
22:09:02.425 [Thread-106] ERROR System.err - 	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
22:09:02.425 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
22:09:02.425 [Thread-106] ERROR System.err - 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
22:09:02.426 [Thread-106] ERROR System.err - 	at java.lang.Thread.run(Thread.java:662)
Previous Topic:Just using Virgo as a dm extender (+ web extender)
Next Topic:Simple WAR with JDBC access
Current Time: Sun Jul 20 10:36:45 EDT 2025
Powered by FUDForum. Page generated in 0.05574 seconds
