Home » Eclipse Projects » DTP » How to add a pop-up menu on Table items?
How to add a pop-up menu on Table items? [message #728758] Fri, 23 September 2011 16:51 Go to next message
I have an action that takes 1 to many tables and generates code or a report.
To add a pop-up menu to a java file I've found we do the following:
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
      id="org.eclipse.ui.articles.action.contribution.popup.object"
   objectClass="org.eclipse.core.resources.IFile"
   nameFilter="*.java">
   <filter
         name="projectNature"
         value="org.eclipse.jdt.core.javanature">
      </filter>
      <action
         id="org.eclipse.ui.articles.action.contribution.object.action1"
         label="Object Action 1"
         icon="icons/red_dot.gif"
         menubarPath="additions"
      class="org.eclipse.ui.articles.action.contribution.ObjectAction1Delegate">
      </action>
   </objectContribution>
</extension>
What is the object class to use?
Any link to the doc is appreciated.
Re: How to add a pop-up menu on Table items? [message #733507 is a reply to message #728758] Tue, 04 October 2011 18:22 Go to previous message
The Data Source Explorer is an implementation of the Eclipse Common
Navigator Framework. Take a look at the plugin.xml file in the
org.eclipse.datatools.data.core.ui plug-in to see how the Data menu gets
added to Table objects in the DSE.
> report. How to add a pop-up menu on Table items?
> <extension point="org.eclipse.ui.popupMenus"> <objectContribution
> <filter
> </filter>
> <action
> </action> </objectContribution> </extension>
Previous Topic:More than one select statement in SQL scrapbook?
Next Topic:java.lang.NoClassDefFoundError: org/eclipse/core/runtime/CoreException error while SQL parse
Current Time: Sun Jul 20 14:47:36 EDT 2025
Powered by FUDForum. Page generated in 0.08101 seconds
