[EEF] Where are generated the junit tests?? [message #731252] |
Fri, 30 September 2011 07:51  |
Hello dear EEF users/developers,
I checked the "Junit test cases" in the EEF gen and specified the folder, then generated the eef architecture and I can't see the junit test cases?
What does that should generate?
Xavier
Re: [EEF] Where are generated the junit tests?? [message #731288 is a reply to message #731252] |
Fri, 30 September 2011 10:13  |
hi xavier,
EEF tests generators will generates an swtbot plugin that will test the
eef generated properties/widget automaticaly.
you must checkout the test generator[1] and test runtime[2] from the
cvs, they are not included in the update site.
you can see an example of generated tests in cvs, too [3].
[1]
http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.emf/org.eclipse.emf.eef/plugins/org.eclipse.emf.eef.tests.codegen/?root=Modeling_Project
[2]
http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.emf/org.eclipse.emf.eef/plugins/org.eclipse.emf.eef.runtime.tests/?root=Modeling_Project
[3]
http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.emf/org.eclipse.emf.eef/tests/org.eclipse.emf.eef.tests.nonreg.junit/?root=Modeling_Project
Le 30/09/2011 13:51, Xavier Seignard a écrit :
> Hello dear EEF users/developers, I checked the "Junit test cases" in the
> Regards,
> Xavier
Stéphane Bouchet, OBEO
FUDForum. Page generated in 0.05939 seconds
