Home » Archived » BIRT » Legend label for series when grouped by key
Legend label for series when grouped by key [message #731005] Thu, 29 September 2011 13:01 Go to next message
I am having this datetime chart in which I have grouped the y axis data by ID column. Thus the chart automatically creates all the requisite series. Now ID column in the legend list doesn't go for great viewing. So I want to replace the ID with its corresponding name. But there seems no way to do it Sad
I even tried a data cube. In it one can specify a display field for key field. So for ID key field, I had display field of associated text and all was good until I realized that chart is not picking up date time group as date time but as text!! And I cannot change the text to datetime. So though the legend shows fine, since the x axis is now text in chart, it is not scaled properly for one.
I will appreciate your help.
Re: Legend label for series when grouped by key [message #731019 is a reply to message #731005] Thu, 29 September 2011 13:37 Go to previous messageGo to next message
Is there anyway you can share a sample report with the issue that we can
run? For example create a scripted data source and hard code some
values and add your chart. If you can post the report.
Jason
> no way to do it :(
Re: Legend label for series when grouped by key [message #731042 is a reply to message #731019] Thu, 29 September 2011 14:42 Go to previous messageGo to next message
Yeah, I will do that. But meanwhile, I was thinking if
function beforeDrawLegendItem( lerh, bounds, icsc )
lerh.getLabel().setCaption(dataSetRow["TAG"]);
would work by looking up in dataset. But apparently dataset is not valid in the context of function.
Re: Legend label for series when grouped by key [message #731055 is a reply to message #731042] Thu, 29 September 2011 14:56 Go to previous messageGo to next message
No it is not, but if Tag is already part of the chart data I can show
you how to get it. If it is not you can always put it in a global
variable and get it from script. Tell me which is your scenario and I
will explain how to do it.
Jason
Re: Legend label for series when grouped by key [message #731169 is a reply to message #731055] Fri, 30 September 2011 03:37 Go to previous messageGo to next message
I have attached the report with a scripted data source. Report has two chart instances, one using a data set and the other data cube made from data set.
In first example, I was unable to change the series label from id to a name from that dataSetRow.
In the second chart example, though series label can be changed by having a different display text for id column, the x series is taken as text. I cannot change it to time Sad
Re: Legend label for series when grouped by key [message #731306 is a reply to message #731169] Fri, 30 September 2011 11:10 Go to previous messageGo to next message
You can always uses a hidden table to load up a hashmap with key value
pairs and then use this map in the beforeDrawLegendItem to lookup the
new value. Have a look at the attached example. Notice the table is
hidden and I use an oncreate script on the table detail row to load up
the hm and then uses a beforeDrawLegendItem script to read it.
Jason
> In the second chart example, though series label can be changed by having a different display text for id column, the x series is taken as text. I cannot change it to time :(
Re: Legend label for series when grouped by key [message #731372 is a reply to message #731306] Fri, 30 September 2011 14:45 Go to previous messageGo to next message
Thanks Jason.
I worked on Sql Server Reporting Services a couple of years back. From what I see in birt it feels like a different world with enormous possibilities. Of course I can't overstate the nightmare SSRS had become for anything custom:)
I wish to gain more insight of scripting and function and variable scope and age. If you could suggest some sources.
Thanks again.
Re: Legend label for series when grouped by key [message #731395 is a reply to message #731372] Fri, 30 September 2011 16:01 Go to previous messageGo to next message
Check
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.php
There are a lot of materials on birt-exchange.org.
http://www.birt-exchange.org/org/devshare/designing-birt-reports/339-birt-advanced-report-and-chart-scripting-examples/
You also can check birtworld.blogspot.com. We have a lot scripting
articles posted there.
http://birtworld.blogspot.com/2010/02/birt-crosstab-scripting.html
http://birtworld.blogspot.com/2010/08/birt-charting-scripting-overview.html
We also have several chapters on scripting in the Integrating and
Extending BIRT 3rd edition:
http://www.amazon.com/Integrating-Extending-BIRT-Eclipse-ebook/dp/B005GVFKKS/ref=tmm_kin_title_0?ie=UTF8&m=AG56TWVU5XWC2&qid=1317323690&sr=8-2
Jason
On 9/30/2011 2:45 PM, pkj5ue wrote:
> Thanks Jason. I worked on Sql Server Reporting Services a couple of
> Thanks again.
Re: Legend label for series when grouped by key [message #798165 is a reply to message #731005] Tue, 14 February 2012 05:34 Go to previous message
I did in my report next.
The put into Y series Grouping the expression: row["TB_GROUP_ID"]+"|"+row["GROUP_NAME"]
And I added the script for the chart:
S = lerh.getLabel().getCaption().getValue();
S = S.substr(S.indexOf("|")+1);
lerh.getLabel().getCaption().setValue(S);
All works wonderful.
Previous Topic:Report Legend
Next Topic:Change Chart Grouping unit and interval
Current Time: Sat Jul 19 19:06:34 EDT 2025
Powered by FUDForum. Page generated in 0.04914 seconds
