Re: CVS or GIT? [message #730056 is a reply to message #729893] |
Tue, 27 September 2011 10:49   |
Ah, thanks. I failed to guess that https:// is for authorized access, http:// for anonymous (is that so? perhaps the wiki should'nt mention then https:// as valid protocol for anonymous access)
I don't recall now when/how I was directed to the CVS download, (from the Eclipse software update?) perhaps it would be convenient to add some warning file to the CVS files, to state that not the valid repositories are in GIT.
A doubt about required plugins: the help page lists
org.eclipse.graphiti
org.eclipse.graphiti.ui
org.eclipse.graphiti.mm
as (apparently) the "core" (needed) plugins, "org.eclipse.graphiti.pattern" for an "framework for an alternative generic approach to combine all implementation aspects in one pattern" (no idea about what that means, I guess for a normal scenario it's not needed), plus other miscelaneous (docs, tutorials, tests) plugins: org.eclipse.graphiti.doc org.eclipse.graphiti.examples.common org.eclipse.graphiti.examples.tutorial org.eclipse.graphiti.tests
In the repository (and in the 0.8.1 download file) I see more plugins. Apart from sources, and some that are seemingly doc-test related, I see:
org.eclipse.graphiti.export.batik
org.eclipse.graphiti.ui.capabilities
org.eclipse.graphiti.releng (only in repository)
org.eclipse.graphiti.site (only in repository ; website?)
I wonder if which ones are needed, and if the above page needs some update.
[Updated on: Tue, 27 September 2011 13:43] by Moderator
Re: CVS or GIT? [message #730474 is a reply to message #730056] |
Wed, 28 September 2011 08:56  |
Hernan,
thanks for pointing out.
I removed https from the Git anonymous access section in the wiki.
Regarding CVS files: since the repository is strictly read-only there is no
chance to get such a file in. Hopefully all links have been updated now, so
at least no one should be pointed there any more. In case you still find a
link please let me know.
Regarding the plugin structure: Yes, there are plugins missing on that docu
page. I filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=359217 to track
that.
The rest of the plugins is not user oriented, but only needed for release
engineering and grouping stuff, I added a description to
http://wiki.eclipse.org/GMP/Graphiti#Plugin_Structure
Michael
FUDForum. Page generated in 0.06369 seconds
