Home » Modeling » Graphiti » Create Connection Programatically
Create Connection Programatically [message #722948] Wed, 07 September 2011 05:40 Go to next message
I am trying to create connections <FreeFormConnection> for my model element in my code using the below method. I am however unable to see my connection once it is added.
private PictogramElement createTransition(ContainerShape srcState,ContainerShape destState,MyTransition myTransition) {
		ChopboxAnchor srcAnchor=GraphitiUi.getPeService().createChopboxAnchor(srcState);
		srcAnchor.setReferencedGraphicsAlgorithm(srcState.getGraphicsAlgorithm());
		srcState.getAnchors().add(srcAnchor);
		ChopboxAnchor destAnchor=GraphitiUi.getPeService().createChopboxAnchor(destState);
		destAnchor.setReferencedGraphicsAlgorithm(destState.getGraphicsAlgorithm());
		destState.getAnchors().add(destAnchor);
		AddConnectionContext context = new AddConnectionContext(srcAnchor, destAnchor);
		context.setNewObject(myTransition);
		PictogramElement connection = iFeatureProvider.addIfPossible(context);
		return connection;
Am i missing something here ?
This post is related to the second half of the http://www.eclipse.org/forums/index.php/t/229987/
Thanks in advance for help.
Murthy
Re: Create Connection Programatically [message #723344 is a reply to message #722948] Thu, 08 September 2011 07:23 Go to previous messageGo to next message
Do you have an add feature that gets triggered when you do the call to
addIfPossible? It needs to be returned by the feature provide in
getAddFetaures and needs to return true on canAdd.
Michael
"Murthybhat" schrieb im Newsbeitrag news:j47dgd$kit$1@news.eclipse.org...
once it is added.
ChopboxAnchor
ChopboxAnchor
destAnchor);
return connection;
Murthy
Re: Create Connection Programatically [message #723533 is a reply to message #723344] Thu, 08 September 2011 14:33 Go to previous messageGo to next message
You can test Michaels suggestion by adding a check for null after the addIfPossible()
if( connection == null){
    // Add was not possible,  probably no addFeature available as Michael states
Jos
Re: Create Connection Programatically [message #723637 is a reply to message #723533] Thu, 08 September 2011 23:19 Go to previous messageGo to next message
Yes, I have a corresponding addFeature and a valid connection object(FreeFormConnection) is returned after adding. Do i have to explicitly set the start POINT and end POINT ?
//ADDMyTransitionFeature.java
public boolean canAdd(IAddContext context) {
			return true;
public PictogramElement add(IAddContext context) {
		IAddConnectionContext addConContext = (IAddConnectionContext) context;
		MyTransition addedTransition = (MyTransition) context.getNewObject();
		final Diagram targetDiagram = (Diagram) context.getTargetContainer();
		IPeCreateService peCreateService = Graphiti.getPeCreateService();
		// CONNECTION WITH POLYLINE
		Connection connection = peCreateService.createFreeFormConnection(targetDiagram);
		Anchor sourceAnchor = addConContext.getSourceAnchor();
		connection.setStart(sourceAnchor);
		Anchor targetAnchor = addConContext.getTargetAnchor();
		connection.setEnd(targetAnchor);
		IGaService gaService = Graphiti.getGaService();
		Polyline polyline = gaService.createPolyline(connection);
		polyline.setBackground(manageColor(IColorConstant.BLACK));
		polyline.setForeground(manageColor(IColorConstant.BLACK));
		polyline.setLineWidth(5);
		// creating the link
		link(connection, addedTransition);
		// add Text decorator for the reference name
		ConnectionDecorator textDecorator = peCreateService.createConnectionDecorator(connection, true, 0.5, true);
		Text text = gaService.createDefaultText(targetDiagram,textDecorator);
		StyleUtil.setStyleForTransition(targetDiagram,text);
		MyTransition eReference = (MyTransition) context.getNewObject();
		text.setValue(eReference.getName());
		// add the image decorator for the reference name
		ConnectionDecorator imgDecorator = peCreateService.createConnectionDecorator(connection, true, 0.4, true);
		Image eventImg = Graphiti.getGaService().createImage(imgDecorator,TRANSITION_IMG);
		Graphiti.getGaService().setLocationAndSize(eventImg, 0, 0, 25, 25);
		ConnectionDecorator cd;
		cd = peCreateService.createConnectionDecorator(connection, false, 1.0, true);
		createArrow(cd);
		// create link and wire it
		link(cd, addedTransition);
		return connection;
The text and image decorators are appearing correctly, except for the polyline. Any thoughts ?
Murthy
[Updated on: Thu, 08 September 2011 23:21] by Moderator
Re: Create Connection Programatically [message #723750 is a reply to message #723637] Fri, 09 September 2011 06:53 Go to previous messageGo to next message
What you're doing here seems to be correct. Could you additionally post your
addConnectionFeature?
Michael
"Murthybhat" schrieb im Newsbeitrag news:j4bvut$c2t$1@news.eclipse.org...
return true;
// add dynamic text decorator for the reference name
// set reference name in the text decorator
Image eventImg =
true);
createArrow(cd);
return connection;
Murthy
Re: Create Connection Programatically [message #724306 is a reply to message #723750] Sun, 11 September 2011 23:22 Go to previous messageGo to next message
Hi Michael,
I have attached my AddTransitionFeature.java here.
Thanks.
Murthy
[Updated on: Sun, 11 September 2011 23:35] by Moderator
Re: Create Connection Programatically [message #730362 is a reply to message #724306] Wed, 28 September 2011 04:55 Go to previous messageGo to next message
I have the same problem. The Connection is created without an Error but is not shown in the Diagram.
Is there any Solution for this problem
Henning
Re: Create Connection Programatically [message #730424 is a reply to message #730362] Wed, 28 September 2011 07:16 Go to previous messageGo to next message
Henning,
I still doubt that this is a general issue. Could you post your add
connection feature and/or a diagram file for further analysis?
Michael
Re: Create Connection Programatically [message #754538 is a reply to message #730424] Thu, 03 November 2011 01:24 Go to previous message
The connection problem is finally resolved. After a lot of digging around, it was a very small change that got this feature working.
I was creating a chop box anchor every time i wanted a new connection like below
But it seems that the anchors are already added. So I call the getAnchor method of the container, it returns the required anchor.
Anchor srcAnchor=getAnchor(srcState);
	private Anchor getAnchor(PictogramElement pe) {
		Anchor anchor= null;
		if (pe instanceof Anchor) {
			anchor= (Anchor) pe;
		} else if (pe instanceof AnchorContainer) {
			anchor= Graphiti.getPeService().getChopboxAnchor((AnchorContainer) pe);
		return anchor;
By replacing the former code with latter in my createTransition() method , I was able to resolve the problem. Thanks for all your suggestions.
Best Regards,
Murthy
[Updated on: Thu, 03 November 2011 01:25] by Moderator
Previous Topic:Using graphiti diagrams without GUI
Next Topic:Tabbed property sections are sometimes not activated.
Current Time: Sat Jul 19 21:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.25447 seconds
