Home » Modeling » TMF (Xtext) » LWC11 XText Submission(quite a few problems ...)
LWC11 XText Submission [message #728628] Fri, 23 September 2011 10:57 Go to next message
I find the LWC11 XText submission a very good tutorial to learn some of the most advanced features of Xtext and am trying to follow it step by step.
There is a warning that XText 2.0 was not fully stabilized when this was written, and indeed this is creating some problems when trying to run it using Eclipse 3.7 and XText 2.0.1.
I have reached the last section of Phase 1.1, Implementing the Scope Provider.
The paper gives:
public class InstancesScopeProvider extends XbaseScopeProvider {
public IScope createLocalVarScopeForBlock(final XBlockExpression block, final int indexOfContextExpressionInBlock,
final IScope parentScope) {
The @Override triggers an error because now XbaseScopeProvider.createLocalVarScopeForBlock has one more parameter (Boolean referredFromClosure). Should I add the parameter to the method then ?
There is a similar problem with the next method:
public IScope createLocalVarScope(final EObject context, final EReference reference, final IScope parentScope,
final boolean includeCurrentBlock, final int idx) {
if (context instanceof Instance) {
return MapBasedScope.createScope(parentScope, Scopes.scopedElementsFor(localVars));
} else {
return super.createLocalVarScope(context, reference, parentScope, includeCurrentBlock, idx);
The parameter list of super.createLocalVarScope is now quite different:
protected IScope createLocalVarScope(IScope parentScope, LocalVariableScopeContext scopeContext) {
How should that be handled ?
Thanks for help
MS
Re: LWC11 XText Submission [message #728699 is a reply to message #728628] Fri, 23 September 2011 13:10 Go to previous messageGo to next message
(1) yes why not adding the param
(2) have a look at the domain model example shipped with xtext (signature of createLocalVarScope has changed to - there should be a @override too)
~Christian
Re: LWC11 XText Submission [message #728890 is a reply to message #728699] Sat, 24 September 2011 04:25 Go to previous message
Thanks Christian, that will keep me going.
MS
Previous Topic:Crossreferences & XText 2
Next Topic:ImportURIScopingFragment vs. ImportNamespacesScopingFragment
Current Time: Sun Jul 20 05:43:01 EDT 2025
Powered by FUDForum. Page generated in 0.04568 seconds
