Home » Eclipse Projects » EclipseLink » Tool to run JPQL queries(Tool to run JPQL queries)
Tool to run JPQL queries [message #727179] Tue, 20 September 2011 11:12 Go to next message
Hello Gurus,
Is there a tool available in EclipseLink to run JPQL queries using persistent objects on the fly similar to running SQL queries on a sql developer?
Sridhar
Re: Tool to run JPQL queries [message #728091 is a reply to message #727179] Thu, 22 September 2011 10:11 Go to previous messageGo to next message
You may want to look into Eclipse Dali or other IDE's JPA support, or request this feature in your IDE.
EclipseLink is a runtime, and tooling is not part of its mandate. However, there is a SessionConsole in EclipseLink testing that can run JPQL queries, but it is pretty coupled with EclipseLink testing.
Re: Tool to run JPQL queries [message #728100 is a reply to message #727179] Thu, 22 September 2011 10:11 Go to previous messageGo to next message
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Re: Tool to run JPQL queries [message #728140 is a reply to message #728091] Thu, 22 September 2011 11:40 Go to previous messageGo to next message
Thanks for your input James. I am indeed using Eclipse (Eclipse Indigo Java EE IDE for Web Developers) as my IDE. I tried to search for SessionConsole by I cannot find it in my IDE. Is that something that I need to download seperately?
I am relatively new to Eclipse/JPA. I appreciate all your help.
Sridhar
(no subject) [message #728162 is a reply to message #728091] Thu, 22 September 2011 11:40 Go to previous messageGo to next message
Sridhar
Re: (no subject) [message #729584 is a reply to message #728140] Mon, 26 September 2011 11:20 Go to previous messageGo to next message
Eclipse has support for JPA project through the Eclipse Dali project. If it does not provide a query ability, you can request it in the Dali forums/bug base.
Re: (no subject) [message #729596 is a reply to message #728140] Mon, 26 September 2011 11:20 Go to previous message
Previous Topic:desktop Swing application with EclipseLink
Next Topic:@EmbeddedId in conjunction with InheritanceType.JOINED does not generate PK-Field
Current Time: Sat Jul 19 19:03:16 EDT 2025
Powered by FUDForum. Page generated in 0.04472 seconds
