Home » Eclipse Projects » Virgo » snaps host not working when deployed from within Eclipse (STS) onto Virgo [SOLVED](when deployed via admin console it does)
icon5.gif  snaps host not working when deployed from within Eclipse (STS) onto Virgo [SOLVED] [message #727069] Tue, 20 September 2011 06:55 Go to next message
EDIT: NB, I could resolve this issue by changing the bundle versions in template.mf from 1.0 to 3.0.1.RELEASE.
I still wonder if JSF2+xhtml could be used instead of JSF (with snaps)... but now I should be able to try it out myself too perhaps. Smile
Hi all,
I'm experimenting some more with snaps, and I've noticed that when deploying the org.eclipse.virgo.snaps.sample.animal host from inside Springsource Tool Suite, it doesn't pick up the client animals. If I deploy it via the admin console it works.
And a host deployed via admin console does pick up the clients-deployed-via-STS as well as the ones deployed via the admin console.
Is this normal behavior? And if so, is there a way to work around so that I could also deploy hosts via Eclipse itself?
And while I'm here... I was also wondering if it would be possible to use JSF2+xhtml instead of JSP's using the same snaps build? As perhaps the same level of hooks could be used depending on how snaps was implemented.
Thanks a lot in advance!!
Jochen
[Updated on: Tue, 20 September 2011 08:01] by Moderator
Re: snaps host not working when deployed from within Eclipse (STS) onto Virgo [SOLVED] [message #727098 is a reply to message #727069] Tue, 20 September 2011 08:09 Go to previous message
Glad you got it working. On the point of JSF+xhtml, I see no reason why it shouldn't work just fine. What hooks are you referring to? In the host it's just a filter there isn't any magic going on behind the scenes.
Chris.
Previous Topic:Problem deploying a plan that contains an already active bundle
Next Topic:Problem deploying a plan that contains an already active bundle
Current Time: Sat Jul 19 12:54:36 EDT 2025
Powered by FUDForum. Page generated in 0.26606 seconds
