Home » Modeling » EMF » Xcore and Ecore references
Xcore and Ecore references [message #726896] Mon, 19 September 2011 16:35 Go to next message
I'm using Xcore and have a problem with it is combined with MWE. Xcore
allows referencing the standard Ecore EDataTypes like EInt, EBoolean
etc. When serializing, the references are encoded with platform:/plugin
URIs instead of the http:// variant, as if the EcorePackage was loaded
from Ecore.ecore instead refering to the global instance. Loading the
model into an editor works fine, but when using MWE to run a generator
(xtend2) the references do not resolve, so I end up with proxy EDataType
objects without instanceClass or instanceClassName. I have to manually
replace the platform:/plugin URIs with the http:// variant in the ecore
file to make it work.
I know there are cases when a platform:/plugin is preferable to the
http:// variant, e.g. when the latter isn't registered and the former
does actually refer to the ecore file. But in this case, I cannot see
why Xcore would want to load the model, rather than refer to the global one.
Hallvard
Re: Xcore and Ecore references [message #726913 is a reply to message #726896] Mon, 19 September 2011 17:53 Go to previous messageGo to next message
Hallvard,
Is this something that could/should be solved with some additional
registration/mapping in the standalone stepup for Xcore?
On 19/09/2011 4:35 PM, Hallvard Trætteberg wrote:
> platform:/plugin URIs instead of the http:// variant, as if the
> EcorePackage was loaded from Ecore.ecore instead refering to the
> global instance. Loading the model into an editor works fine, but when
> using MWE to run a generator (xtend2) the references do not resolve,
> so I end up with proxy EDataType objects without instanceClass or
> instanceClassName. I have to manually replace the platform:/plugin
> URIs with the http:// variant in the ecore file to make it work.
> global one.
> Hallvard
Re: Xcore and Ecore references [message #727013 is a reply to message #726913] Tue, 20 September 2011 03:47 Go to previous messageGo to next message
I don't think this setup is used after the ecore is created, so the
change of URI has to be done either inside (and throughout) Xcore or in
the converter action.
I tried changing the URI in XcoreImportedNamespaceAwareScopeProvider,
but that seemed to break lots of things. I then changed
ConvertToEcoreActionDelegate as follows:
new WorkspaceModifyOperation()
protected void execute(IProgressMonitor progressMonitor)
try
progressMonitor.beginTask("", 1);
if (ecoreXcore != null)
// new code added to save with different URI
Resource ecoreResource =
resourceSet.getResource(URI.createURI("platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore"),
false);
if (ecoreResource != null) {
ecoreResource.setURI(URI.createURI(EcorePackage.eNS_URI));
I.e. I rename the Ecore.ecore resources (just before the content is
added and the resource is saved). This seems to have the desired effect
on the saved ecore and genmodel file.
BTW, to minor issues:
1) The genmodel opens in the reflective editor and not the EMF Generator
editor.
2) It would be great to have an option in the xcore editor to do this
conversion on each save, or a button for the action.
Hallvard
Re: Xcore and Ecore references [message #727014 is a reply to message #727013] Tue, 20 September 2011 03:59 Go to previous messageGo to next message
> editor.
Fix for issue 1), change the contentType key to
"org.eclipse.emf.codegen.genmodel":
workbenchPage.openEditor(new
FileEditorInput(genModelFile),
workbenchWindow.getWorkbench().getEditorRegistry().getDefaultEditor(genModelFile.getFullPath().toString(),
Platform.getContentTypeManager().getContentType("org.eclipse.emf.codegen.genmodel")).getId());
Hallvard
Re: Xcore and Ecore references [message #727084 is a reply to message #727013] Tue, 20 September 2011 07:19 Go to previous messageGo to next message
Hallvard,
Comments below.
> in the converter action.
I though it was using the Xcore directly that was the problem...
So it's in the result of the converter that's a problem...
> as follows:
> @Override
> try
> false);
> effect on the saved ecore and genmodel file.
I think the fix should be to ensure that MWE can properly find the
serialized version of Ecore that has an associated GenModel. Models
that extend Ecore (they shouldn't but people still do) will need that
version.
> Generator editor.
Yes, I noticed the wrong editor opens. We could be more explicit about
which one we want opened...
Like a builder or something. But we really want folks to be able to use
*.xcore directly for that purpose with no need for *.genmodel or *.ecore
resources to exist...
> Hallvard
Re: Xcore and Ecore references [message #727088 is a reply to message #727013] Tue, 20 September 2011 07:19 Go to previous messageGo to next message
Hallvard,
Comments below.
> as follows:
> @Override
> try
> false);
version.
> Generator editor.
> Hallvard
Re: Xcore and Ecore references [message #727710 is a reply to message #727084] Wed, 21 September 2011 16:48 Go to previous messageGo to next message
On 20.09.11 13.19, Ed Merks wrote:
> Hallvard,
> Comments below.
> serialized version of Ecore that has an associated GenModel. Models that
> extend Ecore (they shouldn't but people still do) will need that version.
The debugger reveals that it tries to resolve the EBoolean type and
correctly finds the Ecore.ecore Resource in the ResourceSet. However,
this resource is empty, presumably because the platform:/plugin/... URI
isn't supported in standalone mode.
Using a URI mapping to redirect the platform:/plugin/... URI to the
correct Ecore jar sounds tricky.
After some experimentation, I ended up with the following trick (xtend
syntax):
val ecorePluginUri =
URI::createURI("platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore")
for (res : resourceSet.resources) {
if (ecorePluginUri.equals(res.URI) && res.contents.size == 0) {
res.contents.add(EcoreUtil::copy(EcorePackage::eINSTANCE as
EPackage))
I.e. I make a copy of the ecore package and insert it into the
Ecore.ecore resource.
>> Generator editor.
Yes, use a different content type key (as shown in an earlier message).
I completely agree.
Hallvard
Re: Xcore and Ecore references [message #727811 is a reply to message #727710] Wed, 21 September 2011 21:55 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
Hallvard,<br>
<br>
Comments below.<br>
<br>
<br>
On 21/09/2011 4:48 PM, Hallvard Tr&aelig;tteberg wrote:
<blockquote cite="mid:j5dhsh$nk9$1@news.eclipse.org" type="cite">On
<br>
<blockquote type="cite">Hallvard,
<br>
<br>
Comments below.
<br>
<br>
On 20/09/2011 3:47 AM, Hallvard Tr&aelig;tteberg wrote:
<br>
<br>
<br>
content is
<br>
desired
<br>
<br>
</blockquote>
the
<br>
Models that
<br>
version.
<br>
</blockquote>
<br>
and correctly finds the Ecore.ecore Resource in the ResourceSet.
However, this resource is empty, presumably because the
platform:/plugin/... URI isn't supported in standalone mode.
<br>
<br>
the correct Ecore jar sounds tricky.
<br>
</blockquote>
Not really.&nbsp;&nbsp; EcorePlugin.INSTANCE.getBaseURL() should return the
appropriate URL, e.g.,<br>
<blockquote><a class="moz-txt-link-freetext" href="jar:file:/C:/sandbox/eclipse-modeling-indigo-csa/eclipse/plugins/org.eclipse.emf.ecore_2.7.0.v20110605-0747.jar!/">jar:file:/C:/sandbox/eclipse-modeling-indigo-csa/eclipse/plugins/org.eclipse.emf.ecore_2.7.0.v20110605-0747.jar!/</a><br>
</blockquote>
So you could remap platform:/plugin/org.eclipse.emf.ecore/ to that
URL.&nbsp; That should properly redirect any references to things in the
Ecore plugin to things in the jar.<br>
<br>
(xtend syntax):
<br>
<br>
URI::createURI("platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore")<br>
<br>
&nbsp;&nbsp; if (ecorePluginUri.equals(res.URI) &amp;&amp; res.contents.size
== 0) {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; res.contents.add(EcoreUtil::copy(EcorePackage::eINSTANCE as
EPackage))
<br>
&nbsp;&nbsp; }
<br>
<br>
<br>
<br>
<blockquote type="cite">BTW, to minor issues:
<br>
<br>
Generator editor.
<br>
</blockquote>
about
<br>
<br>
</blockquote>
<br>
message).
<br>
<br>
<blockquote type="cite">But we really want folks to be able to use
<br>
*.ecore
<br>
<br>
</blockquote>
<br>
I completely agree.
<br>
<br>
Hallvard
<br>
</blockquote>
</body>
</html>
Re: Xcore and Ecore references [message #728492 is a reply to message #727811] Fri, 23 September 2011 06:41 Go to previous message
Originally posted by:
On 22.09.11 03.55, Ed Merks wrote:
> Hallvard,
> Not really. EcorePlugin.INSTANCE.getBaseURL() should return the
> So you could remap platform:/plugin/org.eclipse.emf.ecore/ to that URL.
> That should properly redirect any references to things in the Ecore
That's certainly a useful method (and advice). The following seemed to
work, when put in my DSL's standalone setup:
String baseEcoreUrl = EcorePlugin.INSTANCE.getBaseURL().toExternalForm();
ExtensibleURIConverterImpl.URI_MAP.put(URI.createURI("platform:/plugin/org.eclipse.emf.ecore/"),
URI.createURI(baseEcoreUrl));
Thanks!
Hallvard
Previous Topic:[CDO]: How to start the CDO-Server from a command shell without eclipse
Next Topic:[XPand/MWE] Update sites for latest Juno versions
Current Time: Sun Jul 20 15:04:47 EDT 2025
Powered by FUDForum. Page generated in 0.21458 seconds
