Home » Modeling » GMF (Graphical Modeling Framework) » Weird bug with Eclipse BPMN modeler in SetCommand.create
Weird bug with Eclipse BPMN modeler in SetCommand.create [message #726360] Sat, 17 September 2011 11:59 Go to next message
Hi, I'm using the BPMN modeler code to create drag'n'drop annotations, and it's working fine excepted that when the annotation icon is added, the entire editor seems like "resetting" and two simple views (extending ViewPart and no observers, no interacting with editing domain) are weirdly closed
The code which is provoking the closure is the following
protected Command createEAnnotationDropCommand(final EAnnotation ea, final EModelElement element)
		AbstractTransactionalCommand command = new EasyCommand(element)
			protected CommandResult doExecuteWithResult
					IProgressMonitor monitor, IAdaptable info)
			throws ExecutionException
				if (element.getEAnnotation(ea.getSource()) != null)
					RemoveCommand.create(getEditingDomain(), element,
							EcorePackage.eINSTANCE.getEModelElement_EAnnotations(),
							element.getEAnnotation(ea.getSource())).execute();
				SetCommand.create(getEditingDomain(), ea,
						EcorePackage.eINSTANCE.getEAnnotation_EModelElement(),
						element).execute();
				return CommandResult.newOKCommandResult();
		return new ICommandProxy(command);
Every time the command is dispatched (so the function returns CommandResult.newOKCommandResult() ), the views are shut down.. after that I get the error
org.eclipse.swt.SWTException: Widget is disposed
but I think it's logic because the views have been closed by "something"
I've searched a lot but found nothing, might this be a gmf bug?
Re: Weird bug with Eclipse BPMN modeler in SetCommand.create [message #726364 is a reply to message #726360] Sat, 17 September 2011 12:29 Go to previous message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Paul,<br>
<br>
Comments below.<br>
<br>
On 17/09/2011 8:59 AM, Paul Keryon wrote:
<blockquote cite="mid:j52fg0$n4e$1@news.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
ea, final EModelElement element)     {
<br>
EasyCommand(element)         {
<br>
<br>
<br>
<br>
<br>
            throws ExecutionException             {
<br>
null)                 {
<br>
element,
<br>
<br>
</blockquote>
Note that EcorePackage.Literals.EMODEL_ELEMENT__EANNOTATIONS is a
little more efficient...<br>
<br>
</blockquote>
So if there's an annotation with the same source URI you remove
it.   I'm not sure why these are being done as nested commands.  Why
not just operate directly via the APIs.  After all, there's nothing
being done with these commands here that's going to help support
undo.<br>
<br>
<br>
<br>
                        element).execute();
<br>
</blockquote>
I could see this resulting in a command that's not executable.  It
would be better to operate on the multi-valued side using an
AddCommand. Is the ea contained somewhere else at this point?<br>
<br>
Also note this important statement in the Javadoc for
Command.execute.<br>
<br>
  /**<br>
   * Performs the command activity required for the effect.<br>
<b>   * The effect of calling &lt;code&gt;execute&lt;/code&gt; when
&lt;code&gt;canExecute&lt;/code&gt; returns
&lt;code&gt;false&lt;/code&gt;, <br>
   * or when &lt;code&gt;canExecute&lt;/code&gt; hasn't been
called, is undefined.</b><br>
   */<br>
<br>
Commands should be executed on the command stack, and that always
checks to see if they are in fact executable.   Also, as I mentioned
already, here your use of commands doesn't really seem to make sense
to me.<br>
<br>
                <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
"something"
<br>
<br>
<br>
</blockquote>
</body>
</html>
Previous Topic:Same type of diagram in the compartments
Next Topic:[solved] Connection Label from Reference Attribute
Current Time: Sat Jul 19 13:34:42 EDT 2025
Powered by FUDForum. Page generated in 0.03246 seconds
