Home » Eclipse Projects » EclipseLink » JPA Relationship + Multi-Tenancy
JPA Relationship + Multi-Tenancy [message #726213] Fri, 16 September 2011 16:13 Go to next message
I'm not sure whether I've run into a bug with eclipse link's tenant discriminator or if I'm modeling my entities incorrectly.
Currently our database schema is setup to use relationship tables to model a relationship from one table to another, the table type indicates the type of relationship. If I execute a query on the entire table (Select e from Relationship e) it works. However if I try and query on any field within (Select e from Relationship e where e.id=123) eclipse link complains about the TENANT_ID parameter not being set (I've verified it has been set and this particular exception arrises on a per query basis).
Here's a code example of what the entities look like:
@Entity
public class User {
... some fields
@Entity
public class Order {
...some fields
@Entity
public class UserOrderRelationship {
@Id
private long id;
@ManyToOne
@PrimaryKeyJoinColumn
private User user;
@ManyToOne
private Order order;
Any chance someone could point me in the right direction?
Re: JPA Relationship + Multi-Tenancy [message #730520 is a reply to message #726213] Wed, 28 September 2011 10:32 Go to previous message
Can you post the exception? And the code you are executing that results in the exception being thrown?
Where is your TENANT_ID set?
Also, you may want to try the latest 2.3.1 nightly.
http://www.eclipse.org/eclipselink/downloads/nightly.php
Previous Topic:Adding a mapped-superclass via orm.xml fails
Next Topic:JPA Relationship + Multi-Tenancy
Current Time: Sun Jul 20 07:13:50 EDT 2025
Powered by FUDForum. Page generated in 0.04523 seconds
