Home » Eclipse Projects » Eclipse 4 » Dialog from Handler
Dialog from Handler [message #724327] Mon, 12 September 2011 02:05 Go to next message
I want to show a Dialog from a Handler, but after
dialog.open()
I get a
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
This is my Handler:
public class PreferenceHandler {
	@Execute
	public void execute(IEclipseContext context, IWorkbench workbench) {
		PreferenceDialog dialog = ContextInjectionFactory.make(PreferenceDialog.class, context);
		dialog.open();
and this is my Dialog:
public class PreferenceDialog extends TitleAreaDialog {
	@Inject
	public PreferenceDialog(
		@Named(IServiceConstants.ACTIVE_SHELL) Shell parentShell) {
		super(parentShell);
	protected Control createDialogArea(Composite parent) {
		Composite area = (Composite) super.createDialogArea(parent);
		getShell().setText("Connection informations");
		return area;
My Enviroment:
windows 7
jdk 1.6.0_27 (32 bit)
Eclipse SDK 4.1.0
[Updated on: Mon, 12 September 2011 02:08] by Moderator
Re: Dialog from Handler [message #724333 is a reply to message #724327] Mon, 12 September 2011 02:24 Go to previous messageGo to next message
Can we see the complete stacktrace please.
Tom
Am 12.09.11 08:05, schrieb dwestermann:
> Hello,
> I want to show a Dialog from a Handler, but after dialog.open() I get a
> org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException.
> This is my Handler:
> @Execute
> dialog.open();
> @Inject
> super(parentShell);
> @Override
> return area;
Re: Dialog from Handler [message #724338 is a reply to message #724333] Mon, 12 September 2011 02:37 Go to previous messageGo to next message
Wow, rally fast response! Very Happy
@Tom Schindel: The code is from your tutorial.
!SESSION 2011-09-12 08:32:37.328 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_27
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.e4.demo.mailapp.product
Command-line arguments: -product org.eclipse.e4.demo.mailapp.product -data C:\Users\xxx.yyy\workspace/../runtime-MailDemo-4.0.product -dev file:C:/Users/xxx.yyy/workspace/.metadata/.plugins/org.eclipse.pde.core/MailDemo-4.0.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench 4 0 2011-09-12 08:32:44.247
!MESSAGE Internal Error
!STACK 0
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:226)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:196)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:86)
at org.eclipse.e4.ui.workbench.renderers.swt.DirectContributionItem.executeItem(DirectContributionItem.java:409)
at org.eclipse.e4.ui.workbench.renderers.swt.DirectContributionItem.handleWidgetSelection(DirectContributionItem.java:334)
at org.eclipse.e4.ui.workbench.renderers.swt.DirectContributionItem.access$1(DirectContributionItem.java:318)
at org.eclipse.e4.ui.workbench.renderers.swt.DirectContributionItem$2.handleEvent(DirectContributionItem.java:283)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:969)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:885)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:87)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:145)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener.getShellContext(ShellActivationListener.java:193)
at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener.activate(ShellActivationListener.java:114)
at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener.handleEvent(ShellActivationListener.java:73)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1647)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2137)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4525)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:230)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
at org.eclipse.jface.window.Window.open(Window.java:797)
at org.eclipse.e4.demo.mailapp.PreferenceHandler.execute(PreferenceHandler.java:14)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 29 more
at org.eclipse.jface.dialogs.ErrorDialog.open(ErrorDialog.java:360)
at org.eclipse.e4.ui.internal.workbench.swt.WorkbenchStatusReporter.openDialog(WorkbenchStatusReporter.java:97)
at org.eclipse.e4.ui.internal.workbench.swt.WorkbenchStatusReporter.report(WorkbenchStatusReporter.java:54)
at org.eclipse.e4.core.services.statusreporter.StatusReporter.show(StatusReporter.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.safeHandle(PartRenderingEngine.java:1006)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.handle(PartRenderingEngine.java:990)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:978)
Re: Dialog from Handler [message #725250 is a reply to message #724327] Wed, 14 September 2011 07:25 Go to previous messageGo to next message
i have the same problem with the E4 tutorial of Lars Vogel!
My Enviroment:
Windows 7 64 Bit
jdk 1.6.0_26 (32 bit)
Eclipse SDK 4.1.0 Build id: I20110620-1631
public class ExitDialog extends Dialog {
	@Inject
	public ExitDialog(@Named(IServiceConstants.ACTIVE_SHELL) Shell shell) {
		super(shell);
		Label label = new Label(parent, SWT.NONE);
		label.setText("Closing this application may result in data loss. Are you sure you want that");
		return parent;
public class ExitHandlerWithCheck {
	@Execute
		ExitDialog dialog = ContextInjectionFactory.make(ExitDialog.class, context);
		dialog.create();
		if (dialog.open() == Window.OK) {
			workbench.close();
Stacktrace:
!SESSION 2011-09-14 13:24:23.781 -----------------------------------------------
java.version=1.6.0_26
Framework arguments:  -product de.vogella.e4.todo.product
Command-line arguments:  -product de.vogella.e4.todo.product -data T:\eclipse4\wspace\wspace/../runtime-Todo.product -dev file:T:/eclipse4/wspace/wspace/.metadata/.plugins/org.eclipse.pde.core/Todo.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench 1 0 2011-09-14 13:24:25.699
!MESSAGE Start building UI
TodoOveriew has now the focus.
!ENTRY org.eclipse.e4.ui.workbench 4 0 2011-09-14 13:24:27.895
!STACK 0
	at de.vogella.e4.todo.contribute.handler.ExitHandlerWithCheck.execute(ExitHandlerWithCheck.java:16)
	... 29 more
Re: Dialog from Handler [message #725254 is a reply to message #724327] Wed, 14 September 2011 07:29 Go to previous messageGo to next message
sorry for double post.
[Updated on: Wed, 14 September 2011 07:32] by Moderator
Re: Dialog from Handler [message #725270 is a reply to message #725250] Wed, 14 September 2011 07:36 Go to previous messageGo to next message
To me this looks like a problem in the ShellActivationListener. Please
file a bugzilla if one does not already exist.
Tom
Am 14.09.11 13:25, schrieb krazun:
> My Enviroment:
> Windows 7 64 Bit
> @Inject
> super(shell);
> @Override
> return parent;
> @Execute
> ExitDialog dialog =
> dialog.create();
> workbench.close();
> Stacktrace:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 29 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Dialog from Handler [message #725273 is a reply to message #724327] Wed, 14 September 2011 08:06 Go to previous messageGo to next message
After comparing the minimal project which is generated by the E4 Application Project Wizard with the "de.vogella.e4.todo" project where the following code works fine:
public class QuitHandler {
	@Execute
	public void execute(IWorkbench workbench, IEclipseContext context,
			throws InvocationTargetException, InterruptedException {
		if (MessageDialog.openConfirm(shell, "Confirmation",
				"Do you want to exit?")) {
			workbench.close();
i found out that the NPE can fixed by adding the addons from the Wizard-Project to the Application.e4xmi:
platform:/plugin/org.eclipse.e4.core.commands/org.eclipse.e4.core.commands.CommandServiceAddon
platform:/plugin/org.eclipse.e4.ui.services/org.eclipse.e4.ui.services.ContextServiceAddon
platform:/plugin/org.eclipse.e4.ui.bindings/org.eclipse.e4.ui.bindings.BindingServiceAddon
platform:/plugin/org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.CommandProcessingAddon
platform:/plugin/org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.ContextProcessingAddon
platform:/plugin/org.eclipse.e4.ui.workbench.swt/org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon
does someone knows a tutorial where i can read what E4 Addons are and how to use them?
Re: Dialog from Handler [message #725279 is a reply to message #725273] Wed, 14 September 2011 08:19 Go to previous messageGo to next message
Yes, that works!
Re: Dialog from Handler [message #725311 is a reply to message #725279] Wed, 14 September 2011 09:47 Go to previous messageGo to next message
If one creates an "e4 Application Project" with the e4 Project Wizard, the application.e4xml is correct. But if one creates a Plugin Project and later adds a "New Application Model" with the wizard, the *Addon entries are missing.
Re: Dialog from Handler [message #725324 is a reply to message #725311] Wed, 14 September 2011 09:55 Go to previous messageGo to next message
Well technically addons are not needed. E.g. you don't need a
CommandAddon if you are NOT using commands and handlers.
I think the NPE you get if you are NOT adding the addons is a bug
because the workbench-code itself should NOT expect an addon to be there.
So while it might be the case 99% of the time that you need addons
there's not must. The "e4 Application Project"-wizard creates them
because there commands, ... are used whereas the "New Application Model"
does not because it creates a completely empty model IIRC.
It might make sense to add a checkbox to the allow the wizard to insert
the standard fragments or give you a list of commonly known addons. Can
you please file a bugzilla and cc me on it.
Tom
Am 14.09.11 15:47, schrieb dwestermann:
Re: Dialog from Handler [message #725330 is a reply to message #725324] Wed, 14 September 2011 10:27 Go to previous messageGo to next message
I´ve filled a Bugzilla.
Id is 351421
Re: Dialog from Handler [message #725345 is a reply to message #725330] Wed, 14 September 2011 10:33 Go to previous messageGo to next message
This is not the correct id.
Tom
Am 14.09.11 16:27, schrieb dwestermann:
> Id is 351421
Re: Dialog from Handler [message #728368 is a reply to message #725345] Fri, 23 September 2011 02:51 Go to previous messageGo to next message
I get the below error while while running the application(eclipse.exe) file generated using product export wizard on E4 platform. Can some body help me
Parvez
java.version=1.6.0_11
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2011-09-23 11:07:50.609
!MESSAGE Product org.cord.client.dms.mainapp.e4.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2011-09-23 11:07:50.625
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:126)
[Updated on: Fri, 12 August 2022 12:44] by Moderator
Re: Dialog from Handler [message #728385 is a reply to message #728368] Fri, 23 September 2011 03:18 Go to previous messageGo to next message
Please don't hijack unrelated threads! You've hijacked 2 threads and
opened a 3rd one! I already answered in "problem opening
Application.e4xmi in e4 windows 64bit".
Tom
Am 23.09.11 08:51, schrieb Parvez Ahmad Hakim:
> help me
> Parvez Ahmad Hakim
> Srinagar Kashmir
> http://www.abobjects.com
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> at
> at
> at
> at
> at
> at
Re: Dialog from Handler [message #742297 is a reply to message #728385] Thu, 20 October 2011 07:15 Go to previous messageGo to next message
Hello Tom
The problem got solved by adding plugins manually to exported product.
we are showing progress dialogs in non-ui code in classes.
for some code, i made below change:
I created a Shell shell
Showed a progress dialo
closed shell
code:
// PlatformUI.getWorkbench().getActiveWorkbenchWindow(); // old code
// Shell shell = win != null ? win.getShell() : null; / old code
Shell shell = new Shell();
if (showProgress) {
new ProgressMonitorDialog(shell).run(true, true, op);
} else {
op.run(null);
shell.close();
I do not want to create and close shell.
I do not feel that this may be good idea, to do it at every place in code.
So can we get E4 display/shell in non-UI code or just use Display.asyn....
Can we get the shell of running E4 plugin at run-time using any inject logic.
I searched google but no luck in that so far.
Please help
regards
Parvez Ahmad Hakim
[Updated on: Fri, 12 August 2022 12:43] by Moderator
Re: Dialog from Handler [message #937858 is a reply to message #724333] Tue, 09 October 2012 06:28 Go to previous message
any solution so far
[Updated on: Fri, 12 August 2022 12:45] by Moderator
Previous Topic:Views not created
Next Topic:Renaming default commands
Current Time: Sun Jul 20 17:38:44 EDT 2025
Powered by FUDForum. Page generated in 0.06923 seconds
