Home » Archived » BIRT » Adhoc Reporting in Open Source BIRT
Adhoc Reporting in Open Source BIRT [message #724824] Tue, 13 September 2011 05:57 Go to next message
Hi All
Here is my requirement.
I have a finite list of columns (say 30). Here are the steps the user might perform
1) Clicks a link.
2) App shows all the 30 columns and all the rows (page wise)
3) User can remove and later add columns to the results
4) User can apply filters
5) User can select a column to sort
6) User can select a column to group
req's 5/6 can be done later. But 1-4 are must.
I am looking at birt to help me achieve this.
I am thinking to do this. Once the user clicks on the main link, show all the data (page wise). At this point generate the rptDocument. And then, apply filters / add / remove columns over the rptDocument. My question is can we query over an existing rptDocument. Or add / remvoe columns in rptDocument.
Pl note that I am going to use an appserver and use RE API.
Is my thinking in the right direction. Pl let me know if there are any other options available.
Re: Adhoc Reporting in Open Source BIRT [message #725027 is a reply to message #724824] Tue, 13 September 2011 14:18 Go to previous messageGo to next message
Actuate's interactive viewer does items 1-6 in addition to adding charts
etc. It is not open source though, but will work with reports created
in open source.
Jason
On 9/13/2011 5:57 AM, sam wrote:
> Hi All
> might perform
> 1) Clicks a link. 2) App shows all the 30 columns and all the rows (page
> wise)
> Thanks
Re: Adhoc Reporting in Open Source BIRT [message #725124 is a reply to message #725027] Tue, 13 September 2011 23:08 Go to previous messageGo to next message
Thanks Jason for the reply.
I understand Actuate Interactive Viewer has those features. I would like to know if we can achieve using ONLY open source. Thats our current requirement. I just need a direction.
Re: Adhoc Reporting in Open Source BIRT [message #725139 is a reply to message #725124] Wed, 14 September 2011 00:46 Go to previous messageGo to next message
Sam,
I have several example that apply filters and sorting using client side
script that re-run the reports. Would these be useful?
Jason
> Thanks
Re: Adhoc Reporting in Open Source BIRT [message #725152 is a reply to message #725139] Wed, 14 September 2011 01:52 Go to previous messageGo to next message
Definitely
Re: Adhoc Reporting in Open Source BIRT [message #725348 is a reply to message #725152] Wed, 14 September 2011 10:53 Go to previous messageGo to next message
Sam,
Take a look at some of these.
Jason
On 9/14/2011 1:52 AM, sam wrote:
> Definitely
Re: Adhoc Reporting in Open Source BIRT [message #725744 is a reply to message #725348] Thu, 15 September 2011 12:28 Go to previous messageGo to next message
Thank you for your examples.
I am thinking of the following approach. Our database is huge and regenerating the report from database may not be feasible.
The first time when the user clicks on the main screen, all the database rows (accessible by that user) will be shown with all the columns (30). We will generate this by Run + Render task. This will generate an rptdocument.
All the subsequent searches / filters / sorts / grouping will be in a new report, for which the backend will be the rptdocument created first. We will use scripted dataset for this and the filters / sorts / groups will be added dynamically to the table.
I have tested a basic flow with this and seems like it works.
Would there be any challenges in this approach with large amounts of data?
Re: Adhoc Reporting in Open Source BIRT [message #726113 is a reply to message #725744] Fri, 16 September 2011 11:38 Go to previous messageGo to next message
I am not certain. I have not tried this approach before.
Jason
> rptdocument.
> Thanks
Re: Adhoc Reporting in Open Source BIRT [message #894129 is a reply to message #725348] Fri, 06 July 2012 15:04 Go to previous messageGo to next message
filter doesnt filter data at the client side? AM I missing something?
Re: Adhoc Reporting in Open Source BIRT [message #894159 is a reply to message #894129] Fri, 06 July 2012 23:17 Go to previous message
Filters modify the available data at run time on the server.
Jason
On 7/6/12 3:04 PM, Suresh Martha wrote:
Previous Topic:Output Format
Next Topic:how to change export file name
Current Time: Sun Jul 20 09:39:11 EDT 2025
Powered by FUDForum. Page generated in 0.03699 seconds
