Setup of Environment [message #725143] |
Wed, 14 September 2011 01:09 |
I have been working this for days and can't seem to get the correct environment setup. I have cleaned and started fresh. Here is what I have. I will be developing web applications. There are existing projects which i am importing and trying to get running in my environment
- downloaded and installed Java EE 6 SDK updates 3 with JDK 6 update 27. This created a glassfish directory with the jdk and jre within. so I have the paths
C:\glassfish3\jdk\lib
C:\glassfish3\jdk\jre\lib
- downloaded eclipse IDE for Java EE Developer - indigo - this has been unzipped and saved to my C drive.
After importing the projects and looking at the properties the J2EE runtime library did not automatically display. So I went into the preferences and chose server/runtime environments. I chose basic and added it. I mapped it to the C:\glassfish3\jdk\lib folder - this is where the build properties are pointing.
the problem is that i dont have a jar file called j2ee.jar anywhere!
Am I supposed to? Shouldn't that have been part of the Java EE 6 SDK that was installed???
Any help you can provide will be greatly appreciated.
FUDForum. Page generated in 0.06858 seconds
