Re: [EEF] first generation error [message #724977 is a reply to message #723851] |
Tue, 13 September 2011 12:17  |
Originally posted by:
hi,
you should open a bug on bugzilla to track this problem, with
optionnally your plugins to reproduce easily the generation error.
Le 09/09/2011 18:48, S a écrit :
> Hello,
> I am thinking of using EEF to generate tab property sheet for the
> Graphiti editor and work on a generic bridge.
> So I installed EEF 1.0 from the market place.
> The generation gives me compilation errors.
> The problem is that in my original model I have a class called Composite
> and EMF generated and CompositePropertiesEditionPart in my edit plugin
> or EEF has also a CompositePropertiesEditionPart and they clash.
> I'll try to fix it manually, but I would recommend you prefix all your
> class with EEF or Eef to avoid naming clash.
> I always wondered why emf prefixed all their class with E, now I
> understand ;)
Stéphane Bouchet, OBEO
FUDForum. Page generated in 0.03858 seconds
