Require suggestion in RCP [message #724085] |
Sat, 10 September 2011 13:41 |
Hi ,
Requesting for your suggestion on the approach I should use for solving my problem in RCP which is mentioned below .
I would like to create a View which is very dynamic in the sense that it is user defined template and can be sliced/split into multiple formats horizontally and vertically, basically sectional formatting of pane kind .Now the data in this should listen to main window sheet grid table . Also on copy button click i should be able to get the data from this dynamic view to clipboard .
Just to be more clear
A user want to arrange the data to be displayed in his own format , like set of data vertically aligned then a space separator vertically and then next set. Now horizontally another set of data which spans across the above 2 vertically aligned data with no split in between . Now from this view the user clicks a button the data should be in clipboard arranged in same format .
Eg.
Header1 V Header2
Set1 Set1 Set1 Set1 H Set2 Set2 Set2 Set2
Set1 Set1 Set1 Set1 E Set2 Set2 Set2 Set2
Set1 Set1 Set1 Set1 A Set2 Set2 Set2 Set2
Set1 Set1 Set1 Set1 D Set2 Set2 Set2 Set2
Set1 Set1 Set1 Set1 R Set2 Set2 Set2 Set2
B L A N K L I N E S E P A R A T O R
Header 3
Set3 Set3 Set3 Set3 Set3 Set3 Set3 Set3 Set3 Set3
The above is one of examples but its upto user to arrange data in anyway he/she wants , so how can i acheive this in RCP .
Your valuable suggestions will surely help me .
Thanks in advance
VK
FUDForum. Page generated in 0.04232 seconds
