Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] first generation error
[EEF] first generation error [message #723851] Fri, 09 September 2011 12:48 Go to next message
I am thinking of using EEF to generate tab property sheet for the Graphiti editor and work on a generic bridge.
So I installed EEF 1.0 from the market place.
The generation gives me compilation errors.
The problem is that in my original model I have a class called Composite and EMF generated and CompositePropertiesEditionPart in my edit plugin or EEF has also a CompositePropertiesEditionPart and they clash.
I'll try to fix it manually, but I would recommend you prefix all your class with EEF or Eef to avoid naming clash.
I always wondered why emf prefixed all their class with E, now I understand Wink
Re: [EEF] first generation error [message #724977 is a reply to message #723851] Tue, 13 September 2011 12:17 Go to previous message
Originally posted by:
hi,
you should open a bug on bugzilla to track this problem, with
optionnally your plugins to reproduce easily the generation error.
Le 09/09/2011 18:48, S a écrit :
> Hello,
> understand ;)
Stéphane Bouchet, OBEO
Previous Topic:[EEF] Open references listed in the generated editor.
Next Topic:Where to download emf compare 1.1.2 ?
Current Time: Sat Jul 19 13:36:20 EDT 2025
Powered by FUDForum. Page generated in 0.03416 seconds
