Is it possible to import a debug configuration? [message #723136] |
Wed, 07 September 2011 14:24  |
I'm trying to make the Eclipse IDE as simple as possible for my users, and I was wondering if I could import existing debug configuration. I'm looking under 'import' and I only see 'Launch Configurations'... On 'export' choosing 'Launch Configurations' does allow the exporting of debugging configurations, but I have not been able to select them after importing them on a different session of Eclipse.
Are there some caveats that say "If something in the debugging configuration isn't correct- meaning that I have a source path that doesn't exist or something- Eclipse will throw the entire debug config out"?
Re: Is it possible to import a debug configuration? [message #723272 is a reply to message #723143] |
Thu, 08 September 2011 04:33  |
Quote:Off that topic, if I rearrange my screen and exit out of Eclipse, I notice that future sessions have that screen orientation saved. For example, I like to debug with certain windows open in the debugging perspective, and I have those windowsorganized nicely. My thought was that by copying the Eclipse folder and the corresponding workspace, I should be seeing the exact same setup assuming that this setup is saved in either of the two places. This also hasn't seemed to work. Is there a third location for saving this config that I'm not aware of?
After you customized your windows go to the main menu ->Windows->Save Perspective as.. and overwrite the default (e.g. debug). When you export/import your preferences this will be saved.
FUDForum. Page generated in 0.05802 seconds
